path: root/arch/arm/mach-kirkwood
2010-09-19ARM: kirkwood: Unbreak PCIe I/O portArnaud Patard
The support for the 2 pcie port of the 6282 has broken i/o port by switching *_IO_PHYS_BASE and *_IO_BUS_BASE. In fact, the patches reintroduced the same bug solved by commit 35f029e2514be209eb0e88c7d927f3bcc42a5cc2. So, I'm adding back *_IO_BUS_BASE in resource declaration and fix definition of KIRKWOOD_PCIE1_IO_BUS_BASE. With this change, the xgi card on my t5325 is working again. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Cc: stable@kernel.org
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-05Merge branch 'topic/asoc' into for-linusTakashi Iwai
2010-07-29Merge branch 'wells/lpc32xx-arch_v2' of git://git.lpclinux.com/linux-2.6-lpc ↵Russell King
into devel-stable
2010-07-26ARM: 6265/1: kirkwood: move qnap_tsx1x_register_flash() to .init.textUwe Kleine-König
qnap_tsx1x_register_flash is only called by qnap_ts219_init and qnap_ts41x_init which both live in .init.text, too. So the move is OK. This fixes the following warning in kirkwood_defconfig: WARNING: vmlinux.o(.text+0x9334): Section mismatch in reference from the function qnap_tsx1x_register_flash() to the variable .init.data:qnap_tsx1x_spi_slave_info The function qnap_tsx1x_register_flash() references the variable __initdata qnap_tsx1x_spi_slave_info. This is often because qnap_tsx1x_register_flash lacks a __initdata annotation or the annotation of qnap_tsx1x_spi_slave_info is wrong. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-16[ARM] Kirkwood: update LED support for Network Space v2Simon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16leds: add LED driver for Network Space v2 LEDsSimon Guinot
This patch add a LED class driver for the dual-GPIO LEDs found on the Network Space v2 board (and parents). This include Internet Space v2, Network Space (Max) v2 and d2 Network v2 boards. This dual-GPIO LED is wired to a CPLD and can blink in relation with the SATA activity. The driver expose this capability through a "sata" sysfs attribute. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: add LaCie Network Space Max v2 supportSimon Guinot
2010-07-16[ARM] Kirkwood: more factorization of the PCIe init codeNicolas Pitre
2010-07-16[ARM] Kirkwood: add support for PCIe1Saeed Bishara
This patch extends the kirkwood's PCIe support up to 2 controllers as in the 6282 devices. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: Add support for 88f6282Saeed Bishara
The 6282 SoC is compatible to 6280 and features faster CPU, DDR3, additional PCIe interface, and LCD controller. More information can be found here: http://www.marvell.com/products/processors/embedded/armada_300/armada_310.pdf Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: add support for rev A1 of the 88f6192 and 88f6180 chips.Saeed Bishara
2010-07-16[ARM] Kirkwood: configure NAND mpp's for db88f6281Saeed Bishara
In case the board is configured to boot from spi flash, the mpps will not be configured to select the NAND I/Os. This patch makes sure to select the NAND I/O's regardless to the boot device type. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Marvell OpenRD-Ultimate machine supportDmytro Milinevskyy
This patch adds support for the OpenRD Ultimate machine (could be found at http://www.arm.linux.org.uk/developer/machines/list.php?id=2884) Signed-off-by: Dmytro Milinevskyy <milinevskyy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: fix HP t5325 after commit 6605742f2aNicolas Pitre
2010-07-16[ARM] Kirkwood: Add support for HP t5325 Thin ClientMartin Michlmayr
Add support for the HP t5325 Thin Client. This thin client is based on a Marvell Kirkwood chip at 1.2 GHz and features 512 MB RAM, 512 MB SATA-attached flash and an XGI Volari Z11 GPU. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: Add MPP44 (board ID) on TS-219Martin Michlmayr
MPP44 can be used to differentiate between one-bay (TS-11x) and two-bay (TS-21x) devices. According to an engineer from QNAP, the setting of MPP44 depends on the firmware rather than hardware. Presumably, this means that you could fake the MPP44 value by changing the boot loader. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: update MPP definition.Benjamin Zores
Add MPP definitions for Marvell Kirkwood 88F6282 revision. Update some defines to reflect datasheet's MPP names. Signed-off-by: Benjamin Zores <benjamin.zores@alcatel-lucent.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: Fix explanation of MPP45 for QNAP TS41xMartin Michlmayr
On the QNAP TS-41x, MPP45 is used to show the setting of jumper JP1. Fix the documentation to explain what the settings really indicate. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: Export GPIO indicating jumper setting of JP1Martin Michlmayr
Export GPIO 45 which is used to indicate the setting of the JP1 jumper. This is useful for userland tools, such as qcontrol, to see whether the LCD or a serial console is connected. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] qnap tsx1x: fix section mismatchArnaud Patard
Fix the following warning : WARNING: vmlinux.o(.text+0x95a0): Section mismatch in reference from the function qnap_tsx1x_register_flash() to the (unknown reference) .init.data:(unknown) The function qnap_tsx1x_register_flash() references the (unknown reference) __initdata (unknown). This is often because qnap_tsx1x_register_flash lacks a __initdata annotation or the annotation of (unknown) is wrong. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-31openrd-client: initialise audioapatard@mandriva.com
This patch is reponsible for enabling audio on the openrd client board Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-31orion/kirkwood: add audio functions.apatard@mandriva.com
This patch add audio related definitions and functions Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Nicolas Pitre <nico@fluxnic.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-21Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (154 commits) mtd: cfi_cmdset_0002: use AMD standard command-set with Winbond flash chips mtd: cfi_cmdset_0002: Fix MODULE_ALIAS and linkage for new 0701 commandset ID mtd: mxc_nand: Remove duplicate NAND_CMD_RESET case value mtd: update gfp/slab.h includes jffs2: Stop triggering block erases from jffs2_write_super() jffs2: Rename jffs2_erase_pending_trigger() to jffs2_dirty_trigger() jffs2: Use jffs2_garbage_collect_trigger() to trigger pending erases jffs2: Require jffs2_garbage_collect_trigger() to be called with lock held jffs2: Wake GC thread when there are blocks to be erased jffs2: Erase pending blocks in GC pass, avoid invalid -EIO return jffs2: Add 'work_done' return value from jffs2_erase_pending_blocks() mtd: mtdchar: Do not corrupt backing device of device node inode mtd/maps/pcmciamtd: Fix printk format for ssize_t in debug messages drivers/mtd: Use kmemdup mtd: cfi_cmdset_0002: Fix argument order in bootloc warning mtd: nand: add Toshiba TC58NVG0 device ID pcmciamtd: add another ID pcmciamtd: coding style cleanups pcmciamtd: fixing obvious errors mtd: chips: add SST39WF160x NOR-flashes ... Trivial conflicts due to dev_node removal in drivers/mtd/maps/pcmciamtd.c
2010-05-14mtd: kirkwood: allow machines to register RnB callbackBen Dooks
Add a kirkwood_nand_init_rnb() call to allow boards which have RnB line detection to register this instead of a static delay. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-03[ARM] Kirkwood: merge net2big_v2 and net5big_v2 board setupsSimon Guinot
2010-05-03[ARM] Kirkwood: add LaCie 5Big Network v2 supportSimon Guinot
2010-05-03[ARM] Kirkwood: add LaCie 2Big Network v2 supportSimon Guinot
2010-05-03[ARM] Kirkwood: Marvell GuruPlug supportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23[ARM] Kirkwood: WPS button keycode mappingChristian Lamparter
Commit "Input: add KEY_WPS_BUTTON definition" added a generic keycode for WPS button. Let's use it, instead of "F1" mapping. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-25Merge branch 'for-rmk' of git://git.marvell.com/orion into devel-stableRussell King
2010-02-23[ARM] eSATA SheevaPlug: correlate MPP to SD CD and SD WPJohn Holland
Accept SD CD and SD WP in accordance to http://plugcomputer.org/data/docs/Sheeva-PowerPlug-V1.3-GTI-090906.pdf on MPP 47 and 44 respectively on the eSATA SheevaPlug Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-23[ARM] eSATA SheevaPlug: configure SoC SATA interfaceJohn Holland
Enable the kirkwood SATA SoC interface on the eSATA SheevaPlug. Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-23[ARM] eSATA SheevaPlug basic board supportJohn Holland
Allow basic eSATA SheevaPlug board configuration and build. Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-09[ARM] Kirkwood: define SATA LED for netspace_v2Simon Guinot
This patch add a GPIO LED named "ns_v2:blue:sata" which can be used to enable or disable SATA activity LED blinking. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-09[ARM] Kirkwood: add LaCie Internet Space v2 supportSimon Guinot
The Internet and Network Space v2 boards are very close. The only difference is that there is no USB type B plug wired on the Internet Space v2. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-05[ARM] kirkwood: combine support for openrd base/client supportAlexander Clouter
Inspired by the mach-ep93xx flattening work, there is really not much difference between the OpenRD base and client board support so they should be merged together. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-02-04mach-kirkwood/common.c: remove unnecessary (void *) castsH Hartley Sweeten
The (void *) cast is not needed when setting dev.platform_data to the address of the data. Remove the casts. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-01-10[ARM] Kirkwood: drive USB VBUS pin on rd88f6192-nas high on bootSaeed Bishara
Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-12-10[ARM] Kirkwood: Add LaCie Network Space v2 supportSimon Guinot
2009-11-13[ARM] Kirkwood: Remove code duplication in QNAP setup filesMartin Michlmayr
Remove the code duplication found in the setup files of TS-219 and TS-41x. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-13[ARM] Kirkwood: Add QNAP TS-110/TS-210 to Kconfig help textMartin Michlmayr
Add two new models from QNAP to the help text. They are compatible with the TS-119/TS-219 and therefore supported by the current code. The only difference is that they have less RAM (256 MB instead of 512 MB), a slower CPU (800 MHz vs 1.2 GHz) and a plastic case. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-13[ARM] Kirkwood: Add MPP36 for QNAP TS-11x/TS-21xMartin Michlmayr
MPP36 is used on the QNAP TS-11x/TS-21x devices to indicate how much RAM there is: it's high for 512 MB RAM (TS-x19) and low for 256 MB (TS-x10). While this may not be very useful, let's add it for completeness. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-13[ARM] Kirkwood: Add support for QNAP TS-41x Turbo NASMartin Michlmayr
Add support for the QNAP TS-410, TS-410U, TS-419P and TS-419U Turbo NAS. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
