This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Makes it consistent with VMALLOC_START
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Since commit eb0519b5a1cf, mv643xx_eth is non functional on ARM because
the platform device declaration does not include any coherent DMA mask
and coherent memory allocations fail.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Symbols like SOFT_RESET are way too generic to be exported at large.
To avoid this, let's move the mbus bridge register defines into a
separate file and include it where needed. This affects mach-kirkwood,
mach-loki, mach-mv78xx0 and mach-orion5x simultaneously as they all
share code in plat-orion which relies on those defines.
Some other defines have been moved to narrower scopes, or simply deleted
when they had no user.
This fixes compilation problem with mpt2sas on the above listed
platforms.
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
When ISA_DMA_API is unset, we're not implementing the ISA DMA API,
so there's no point in publishing the prototypes via asm/dma.h, nor
including the machine dependent parts of that API.
This allows us to remove a lot of mach/dma.h files which don't contain
any useful code. Unfortunately though, some platforms put their own
private non-ISA definitions into mach/dma.h, so we leave these behind
and fix the appropriate #include statments.
Let's provide an overridable default instead of having every machine
class define __virt_to_bus and __bus_to_virt to the same thing. What
most platforms are using is bus_addr == phys_addr so such is the default.
One exception is ebsa110 which has no DMA what so ever, so the actual
definition is not important except only for proper compilation. Also
added a comment about the special footbridge bus translation.
Let's also remove comments alluding to set_dma_addr which is not
(and should not) be commonly used.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits)
[ARM] 5300/1: fixup spitz reset during boot
[ARM] 5295/1: make ZONE_DMA optional
[ARM] 5239/1: Palm Zire 72 power management support
[ARM] 5298/1: Drop desc_handle_irq()
[ARM] 5297/1: [KS8695] Fix two compile-time warnings
[ARM] 5296/1: [KS8695] Replace macro's with trailing underscores.
[ARM] pxa: allow multi-machine PCMCIA builds
[ARM] pxa: add preliminary CPUFREQ support for PXA3xx
[ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h
[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c
[ARM] pxa/zylonite: add support for USB OHCI
[ARM] ohci-pxa27x: use ioremap() and offset for register access
[ARM] ohci-pxa27x: introduce pxa27x_clear_otgph()
[ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource
[ARM] ohci-pxa27x: move OHCI controller specific registers into the driver
[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers
[ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c
[ARM] pxa: simplify DMA register definitions
[ARM] pxa: make additional DCSR bits valid for PXA3xx
[ARM] pxa: move i2c register and bit definitions into i2c-pxa.c
Fixed up conflicts in
arch/arm/mach-versatile/core.c
sound/soc/pxa/pxa2xx-ac97.c
sound/soc/pxa/pxa2xx-i2s.c
manually.
Currently, there are two different fields in the
mv643xx_eth_platform_data struct that together describe the PHY
address -- one field (phy_addr) has the address of the PHY, but if
that address is zero, a second field (force_phy_addr) needs to be
set to distinguish the actual address zero from a zero due to not
having filled in the PHY address explicitly (which should mean
'use the default PHY address').
If we are a bit smarter about the encoding of the phy_addr field,
we can avoid the need for a second field -- this patch does that.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This patch performs the equivalent include directory shuffle for
plat-orion, and fixes up all users.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
The Marvell Loki (88RC8480) is an ARM SoC based on a Feroceon CPU
core running at between 400 MHz and 1.0 GHz, and features a 64 bit
DDR controller, 512K of internal SRAM, two x4 PCI-Express ports,
two Gigabit Ethernet ports, two 4x SAS/SATA controllers, two UARTs,
two TWSI controllers, and IDMA/XOR engines.
This patch adds support for the Marvell LB88RC8480 Development
Board, enabling the use of the PCIe interfaces, the ethernet
interfaces, the TWSI interfaces and the UARTs.
