path: root/arch/arm/mach-msm/acpuclock-arm11.c
2010-08-12Merge branch 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msmLinus Torvalds
* 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: msm: mmc: Add msm prefix to platform data structure msm: trout: Remove extern declaration from source file arm: msm: Fix section mismatch in smd.c. arm: msm: trout add mmc support arm: msm: trout: add trout specific gpio interrupts arm: msm: remove unused #include <linux/version.h>
2010-06-17arm: msm: remove unused #include <linux/version.h>Huang Weiyi
Remove unused #include <linux/version.h>('s) in arch/arm/mach-msm/acpuclock-arm11.c arch/arm/mach-msm/clock.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-12arm: msm: warning fix in acpuclock.cDaniel Walker
Fixes the following warning, arch/arm/mach-msm/acpuclock-arm11.c:138: warning: 'freq_table' defined but not used when CONFIG_CPU_FREQ_TABLE is not enabled. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-05-12arm: msm: add cpu frequency controlsDaniel Walker
This adds acpuclock-arm11.c from Google. This provides control over the cpu frequency for arm11 cpu's. This has shared authorship between Google, and Qualcomm. Most of it was written by Mike Chan at Google. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
