path: root/arch/arm/mach-msm/clock-pcom.c
2011-02-28msm: clock: Remove references to clk_ops_pcomStephen Boyd
Not all devices use proc_comm and determining if a clock is local vs. remote is fragile when done by comparing clk_ops pointers. Instead, implement an is_local() function for all clk_ops to determine if the clock is local. Doing this allows us to remove the last references to clk_ops_pcom from clock.c and compile it for targets with CONFIG_MSM_PROC_COMM=n. We don't need to set the clk_ops at runtime until 7x30 local clock detection comes in. Right now it's just complicating things so just set the ops pointer statically. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-01-28msm: clock: Remove 7x30 and pcom includes from clock.hStephen Boyd
clock.h includes clock-pcom.h and clock-7x30.h when it really doesn't need to. Remove the includes and fixup breakages. Reviewed-By: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-05-13msm: generalize clock support.Daniel Walker
The 'PCOM' method of clock control (commands issued to the radio CPU) is shared across several (but not all) Qualcomm SOCs. Generalize this clock mechanism so these other SOCs can be added. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
