path: root/arch/arm/mach-msm/devices-msm7x00.c
2013-08-27msm_serial: Switch clock consumer strings and simplify codeStephen Boyd
In downstream kernel we've standardized the clock consumer names that MSM device drivers use. Replace the uart specific clock names in this driver with the more standard 'core' and 'iface' names. Also simplify the code by assuming that clk_prepare_enable and clk_disable_unprepare() will properly check for NULL pointers (it will because MSM uses the common clock framework). Cc: David Brown <davidb@codeaurora.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-24ARM: msm: Migrate to common clock frameworkStephen Boyd
Move the existing clock code in mach-msm to the common clock framework. We lose our capability to set the rate of and enable a clock through debugfs. This is ok though because the debugfs features are mainly used for testing and development of new clock code. To maintain compatibility with the original MSM clock code we make a wrapper for clk_reset() that calls the struct msm_clk specific reset function. This is necessary for the usb and sdcc devices on MSM until a better suited API is made available. Cc: Saravana Kannan <skannan@codeaurora.org> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2013-06-24ARM: msm: Make proc_comm clock control into a platform driverStephen Boyd
To move closer to the generic struct clock framework move the proc_comm based clock code to a platform driver. The data describing the struct clks still live in the devices-$ARCH file, but the clock initialization is done at driver binding time. Cc: Saravana Kannan <skannan@codeaurora.org> Reviewed-by: Pankaj Jangra <jangra.pankaj9@gmail.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2013-03-05gpio: Make gpio-msm-v1 into a platform driverStephen Boyd
Doing this removes the dependence of this driver on the msm_iomap.h and cpu.h mach include headers provied by MSM. This is necessary to support single zImage work in the future and allows us to remove cpu.h entirely and brings us closer to removing msm_iomap.h. Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Rohit Vaswani <rvaswani@codeaurora.org> Acked-by: Rohit Vaswani <rvaswani@codeaurora.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2012-09-14ARM: msm: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the msm include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Chris Ball <cjb@laptop.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-arm-msm@vger.kernel.org
2011-10-26msm: mmc: Remove "pio_irq" resourceSahitya Tummala
On some targets, MCI_IRQ_MASK1 is not routed to the MSM in which case only "cmd_irq" must be used even for PIO. With this change, all the targets will use only "cmd_irq" for both CMD and PIO. Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-02-28msm: clock: Migrate to clkdevStephen Boyd
Migrating to clkdev has several advantages: * Less code in mach-msm/clock.c * A more robust clk_get() implementation * clk_add_alias() support * clk_get_sys() support In general, this will help board authors setup clock aliases and break the dependency on device pointers in the clock tables. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-01-28Merge branch 'msm-core' into for-nextDavid Brown
* msm-core: msm: Clean up useless ifdefs msm: clock: Add support for more proc_comm clocks msm: clock: Invert debugfs directory layout msm: clock: Move debugfs code from clock.c to clock-debug.c msm: clock: Remove 7x30 and pcom includes from clock.h msm: clock: Remove unused code and definitions msm: Warning fix in trout gpio board file msm: Remove broken register definition from trout
2011-01-28msm: clock: Remove 7x30 and pcom includes from clock.hStephen Boyd
clock.h includes clock-pcom.h and clock-7x30.h when it really doesn't need to. Remove the includes and fixup breakages. Reviewed-By: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-01-21msm: Add name field to UART resourcesStepan Moskovchenko
Add a name field to the I/O resources for the UARTs on MSM targets in preparation for updates to the msm_serial driver. The driver assumed there is one I/O resource per UART, which is not the case on all targets. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-12-15msm: initial framebuffer supportDaniel Walker
Initial framebuffer components. Add board-trout-panel.c as well as platform parts to enable the framebuffer. This code comes directly from Google's tree. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-12-15msm: trout: change name of pmdh_clk to mddi_clkDaniel Walker
This clock is used in the framebuffer driver as mddi_clk. This just changes the name to match that. This also mirrors a change in Google tree. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-12-15msm: add CLK_MINMAX to pmdh_clkDaniel Walker
This adds in the CLK_MINMAX flag to the pmdh_clk since it's actual a min/max clock instead of a single frequency clock. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-08-09msm: mmc: Add msm prefix to platform data structureSahitya Tummala
Rename mmc_platform_data to msm_mmc_platform_data as it is used only by MSM platform. Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-05-13msm: generalize clock support.Daniel Walker
The 'PCOM' method of clock control (commands issued to the radio CPU) is shared across several (but not all) Qualcomm SOCs. Generalize this clock mechanism so these other SOCs can be added. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
2010-05-13msm: generalization to support multiple SOCs.Gregory Bean
devices.c is specific to the MSM7x00 series of SOCs. Rename appropriately in preparation to support more devices. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
