path: root/arch/arm/mach-mv78xx0/mpp.c
2011-05-16ARM: orion: Refactor the MPP code common in the orion platformAndrew Lunn
mv78xx0 and kirkwood use identical mpp code. It should also be possible to rewrite the orion5x mpp to use this platform code. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion GPIO code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion GPIO code pass in GPIO-related platform info (GPIO controller base address, secondary base IRQ number, etc) explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-05ARM: orion5x/kirkwood/mv78xx0: fix MPP configuration corner casesMike Rapoport
Wrong MPP configuration would cause <cpu>_mpp_conf loop infinitely because the mpp list iterator would not be incremented. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-02-23[ARM] MV78XX0: MPP routines and definitionsSebastien Requiem
This patch is composed of two new files : - mpp.c which is mainly inspired by the same file as in mach-kirkwood - mpp.h that is written from the documentation provided by Marvell http://www.marvell.com/products/processors/embedded/discovery_innovation/HW_MV78100_OpenSource.pdf Moreover, due to some implementation problem, I have defined some MPPX_UNUSED that offer developers the possibility to SET MPP to some unused value (such as for Buffalo WXL). Note: This patch doesn't support MV78200 yet (only 78100 MPP lines have been written) Signed-off-by: Sebastien Requiem <sebastien@kolios.dk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
