As we already did for Armada XP switch from virt_to_phys() to
__pa_symbol().
The reason for it was well explained by Mark Rutland so let's quote him:
"virt_to_phys() is intended to operate on the linear/direct mapping of
RAM.
__pa_symbol() is intended to operate on the kernel mapping, which may
not be in the linear/direct mapping on all architectures. e.g. arm64 and
x86_64 map the kernel image and RAM separately.
On 32-bit ARM the kernel image mapping is tied to the linear/direct
mapping, so that works, but as it's semantically wrong (and broken for
generic code), the DEBUG_VIRTUAL checks complain."
Fixes: db88977894ab ("arm: mvebu: support for SMP on 98DX3336 SoC")
Cc: <stable@vger.kernel.org>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Compared to the armada-xp the 98DX3336 uses different registers to set
the boot address for the secondary CPU so a new enable-method is needed.
This will only work if the machine definition doesn't define an overall
smp_ops because there is not currently a way of overriding this from the
device tree if it is set in the machine definition.
Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Acked-by: Rob Herring <robh@kernel.org>
This node pointer is returned by of_find_compatible_node() in this
function. It should be put before exitting this function.
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
into next/soc
Pull "mvebu SoC suspend changes for v3.19" from Jason Cooper:
- Armada 370/XP suspend/resume support
- mvebu SoC driver suspend/resume support
- irqchip
- clocksource
- mbus
- clk
* tag 'mvebu-soc-suspend-3.19' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: add SDRAM controller description for Armada XP
ARM: mvebu: adjust mbus controller description on Armada 370/XP
ARM: mvebu: add suspend/resume DT information for Armada XP GP
ARM: mvebu: synchronize secondary CPU clocks on resume
ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume
ARM: mvebu: Armada XP GP specific suspend/resume code
ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume
ARM: mvebu: implement suspend/resume support for Armada XP
clk: mvebu: add suspend/resume for gatable clocks
bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration
bus: mvebu-mbus: suspend/resume support
clocksource: time-armada-370-xp: add suspend/resume support
irqchip: armada-370-xp: Add suspend/resume support
Documentation: dt-bindings: minimal documentation for MVEBU SDRAM controller
The Armada XP has multiple cores clocked by independent clocks. The
SMP startup code contains a function called set_secondary_cpus_clock()
called in armada_xp_smp_prepare_cpus() to ensure the clocks of the
secondary CPUs match the clock of the boot CPU.
With the introduction of suspend/resume, this operation is no longer
needed when booting the system, but also when existing the suspend to
RAM state. Therefore this commit reworks a bit the logic: instead of
configuring the clock of all secondary CPUs in
armada_xp_smp_prepare_cpus(), we do it on a per-secondary CPU basis in
armada_xp_boot_secondary(), as this function gets called when existing
suspend to RAM for each secondary CPU.
Since the function now only takes care of one CPU, we rename it from
set_secondary_cpus_clock() to set_secondary_cpu_clock(), and it looses
its __init marker, as it is now used beyond the system initialization.
Note that we can't use smp_processor_id() directly, because when
exiting from suspend to RAM, the code is apparently executed with
preemption enabled, so smp_processor_id() is not happy (prints a
warning). We therefore switch to using get_cpu()/put_cpu(), even
though we pretty much have the guarantee that the code starting the
secondary CPUs is going to run on the boot CPU and will not be
migrated.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1416585613-2113-14-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch removes the unneeded include of the armada-370-xp.h header.
It also moves some declarations from this file into more accurate
places.
Finally, it also adds a comment explaining that we can't remove yet the
smp field in the dt machine struct due to backward compatibly of the
device tree.
In a few releases, when the old device tree will be obsolete, we will be
able to remove the smp field and then the armada-370-xp.h header.
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1414669184-16785-2-git-send-email-gregory.clement@free-electrons.com
arch/arm/mach-mvebu/pmsu.c
Most of the function related to the PMSU are not specific to the
Armada 370 or Armada XP SoCs. They can also be used for most of the
other mvebu ARMv7 SoCs, and will actually be used to support cpuidle
on Armada 38x.
Link: https://lkml.kernel.org/r/1406120453-29291-6-git-send-email-thomas.petazzoni@free-electrons.com
In the Armada XP SMP support code, we are reading the clock frequency
of the booting CPU, and use that to assign the same frequency to the
other CPUs, and we do this while the clocks are disabled.
However, the CPU clocks are in fact never prepared/enabled, and to
support cpufreq, we now have two code paths to change the frequency of
the CPU clocks in the CPU clock driver: one when the clock is enabled
(dynamic frequency scaling), one when the clock is disabled (adjusting
the CPU frequency before starting the CPU). In order for this to work,
the CPU clocks now have to be prepared and enabled after the initial
synchronization of the clock frequencies is done, so that all future
rate changes of the CPU clocks will trigger a dynamic frequency
scaling transition.
Link: https://lkml.kernel.org/r/1404920715-19834-2-git-send-email-thomas.petazzoni@free-electrons.com
This commit implements CPU hotplug support for the Marvell Armada XP
platform. The CPU hotplug stub functions from hotplug.c are moved into
platsmp.c, as it doesn't make much sense to have a separate file just
for these two functions.
In addition, this commit:
* Implements the ->cpu_die() function of SMP operations by calling
armada_370_xp_pmsu_idle_enter() to enter the deep idle state for
CPUs going offline.
* Implements a dummy ->cpu_kill() function, simply needed for the
kernel to know we have CPU hotplug support.
* The armada_xp_boot_secondary() function makes sure to wake up the
CPU if waiting in deep idle state by sending an IPI. This is
because armada_xp_boot_secondary() is now used in two different
situations: for the initial boot of secondary CPUs (where CPU reset
deassert is used to wake up CPUs) and for CPU hotplug (where an IPI
is used to take CPU out of deep idle).
* At boot time, we exit from the idle state in the
->smp_secondary_init() hook.
This commit has been tested using CPU hotplug through sysfs
(/sys/devices/system/cpu/cpuX/online) and using kexec.
Link: https://lkml.kernel.org/r/1401481098-23326-5-git-send-email-thomas.petazzoni@free-electrons.com
set_cpu_coherent() took the SMP group ID as parameter. But this
parameter was never used, and the CPU always uses the SMP group 0. So
we can remove this parameter.
Link: https://lkml.kernel.org/r/1397488214-20685-5-git-send-email-gregory.clement@free-electrons.com
ll_set_cpu_coherent is always used on the current CPU, so instead of
passing the CPU id as argument, ll_set_cpu_coherent() can find it by
itself.
Link: https://lkml.kernel.org/r/1397488214-20685-4-git-send-email-gregory.clement@free-electrons.com
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This commit adds the CPU_METHOD_OF_DECLARE declaration for the Armada
XP SMP operations. Note that the .smp_ops field of Armada XP
DT_MACHINE structure is kept, in order to ensure we remain compatible
with older Device Trees that do not include the "enable-method"
property for the CPUs.
Link: https://lkml.kernel.org/r/1397483648-26611-3-git-send-email-thomas.petazzoni@free-electrons.com
The pmsu.c driver contained an armada_xp_boot_cpu() function that sets
the boot address of a secondary CPUs and deasserts the reset. However,
the Armada 375 needs a slightly different logic, so it makes more
sense to move this code into the Armada XP specific platsmp.c.
In order to achieve this, the mvebu_pmsu_set_cpu_boot_addr() function
is exported. It will be needed for both the Armada XP and Armada 38x
SMP implementations.
Link: https://lkml.kernel.org/r/1397483648-26611-2-git-send-email-thomas.petazzoni@free-electrons.com
Some irqchip initialization must be done on secondary CPUs. On mvebu
platforms, this is currently achieved by having the
arch/arm/mach-mvebu/platsmp.c code directly call into a function
exported by the irqchip driver, which isn't really nice.
This commit changes this by using the same solution as the one used in
the GIC driver: the irqchip driver registers a CPU notifier, which is
used to do the secondary CPU IRQ initialization. This way, the irqchip
driver is completely autonomous, and the function no longer needs to
be exposed from the irqchip driver to the SoC code.
Link: https://lkml.kernel.org/r/1397483648-26611-6-git-send-email-thomas.petazzoni@free-electrons.com
Instead of having the SoC code in arch/arm/mach-mvebu/platsmp.c do the
set_smp_cross_call() to register the IPI-triggering function, it makes
more sense to do exactly what the GIC driver is doing: let the irqchip
driver do it. This way, it avoids having to expose the
armada_mpic_send_doorbell() function between the irqchip driver and
the SoC code.
Link: https://lkml.kernel.org/r/1397483648-26611-5-git-send-email-thomas.petazzoni@free-electrons.com
This patch fixes conflicting types for 'set_cpu_coherent' and fixes the
following sparse warnings.
arch/arm/mach-mvebu/system-controller.c:42:38:
warning: symbol 'armada_370_xp_system_controller' was not declared. Should it be static?
arch/arm/mach-mvebu/system-controller.c:49:38:
warning: symbol 'orion_system_controller' was not declared. Should it be static?
arch/arm/mach-mvebu/system-controller.c:67:6:
warning: symbol 'mvebu_restart' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:31:15:
warning: symbol 'coherency_phys_base' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:48:5:
warning: symbol 'set_cpu_coherent' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:123:12:
warning: symbol 'coherency_init' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:38:5: warning:
symbol 'armada_xp_boot_cpu' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:61:12: warning:
symbol 'armada_370_xp_pmsu_init' was not declared. Should it be static?
arch/arm/mach-mvebu/platsmp.c:49:13: warning:
symbol 'set_secondary_cpus_clock' was not declared. Should it be static?
arch/arm/mach-mvebu/platsmp.c:97:13: warning:
symbol 'armada_xp_smp_prepare_cpus' was not declared. Should it be static?
arch/arm/mach-mvebu/hotplug.c:24:12: warning:
symbol 'armada_xp_cpu_die' was not declared. Should it be static?
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Pull ARM SoC platform changes from Olof Johansson:
"This branch contains mostly additions and changes to platform
enablement and SoC-level drivers. Since there's sometimes a
dependency on device-tree changes, there's also a fair amount of
those in this branch.
Pieces worth mentioning are:
- Mbus driver for Marvell platforms, allowing kernel configuration
and resource allocation of on-chip peripherals.
- Enablement of the mbus infrastructure from Marvell PCI-e drivers.
- Preparation of MSI support for Marvell platforms.
- Addition of new PCI-e host controller driver for Tegra platforms
- Some churn caused by sharing of macro names between i.MX 6Q and 6DL
platforms in the device tree sources and header files.
- Various suspend/PM updates for Tegra, including LP1 support.
- Versatile Express support for MCPM, part of big little support.
- Allwinner platform support for A20 and A31 SoCs (dual and quad
Cortex-A7)
- OMAP2+ support for DRA7, a new Cortex-A15-based SoC.
The code that touches other architectures are patches moving MSI
arch-specific functions over to weak symbols and removal of
ARCH_SUPPORTS_MSI, acked by PCI maintainers"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits)
tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE
PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource
ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list
ARM: dts: vf610-twr: enable i2c0 device
ARM: dts: i.MX51: Add one more I2C2 pinmux entry
ARM: dts: i.MX51: Move pins configuration under "iomuxc" label
ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog
ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator
ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX
ARM: dts: i.MX27: Disable AUDMUX in the template
ARM: dts: wandboard: Add support for SDIO bcm4329
ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template
ARM: dts: imx53-qsb: Make USBH1 functional
ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module
ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module
ARM: dts: imx6qdl-sabresd: Add touchscreen support
ARM: imx: add ocram clock for imx53
ARM: dts: imx: ocram size is different between imx6q and imx6dl
ARM: dts: imx27-phytec-phycore-som: Fix regulator settings
ARM: dts: i.MX27: Remove clock name from CPU node
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
Currently set_secondary_cpus_clock assume the CPU logical ordering
and the MPDIR in DT are same, which is incorrect.
Since the CPU device nodes can be retrieved in the logical ordering
using the DT helper, we can remove the devices tree parsing.
This patch removes DT parsing by making use of of_get_cpu_node.
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Jason Cooper <jason@lakedaemon.net>
Acked-by: Gregory Clement <gregory.clement@free-electrons.com>
Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
From Jason Cooper:
mvebu soc changes for v3.12
- mvebu
- cleanup redundant code
* tag 'soc-3.12' of git://git.infradead.org/linux-mvebu:
From Jason Cooper:
mvebu drivers changes for v3.12
- MBus devicetree bindings
- devbus update for address decoding window, cleanup
* tag 'drivers-3.12' of git://git.infradead.org/linux-mvebu: (35 commits)
memory: mvebu-devbus: Remove unused variable
ARM: mvebu: Relocate PCIe node in Armada 370 RD board
ARM: mvebu: Fix AXP-WiFi-AP DT for MBUS DT binding
ARM: mvebu: add support for the AXP WiFi AP board
ARM: mvebu: use dts pre-processor for mv78230
PCI: mvebu: Adapt to the new device tree layout
bus: mvebu-mbus: Add devicetree binding
ARM: kirkwood: Relocate PCIe device tree nodes
ARM: kirkwood: Introduce MBUS_ID
ARM: kirkwood: Introduce MBus DT node
ARM: kirkwood: Use the preprocessor on device tree files
ARM: kirkwood: Split DT and legacy MBus initialization
ARM: mvebu: Relocate Armada 370/XP PCIe device tree nodes
ARM: mvebu: Relocate Armada 370/XP DeviceBus device tree nodes
ARM: mvebu: Add BootROM to Armada 370/XP device tree
ARM: mvebu: Add MBus to Armada 370/XP device tree
ARM: mvebu: Use the preprocessor on Armada 370/XP device tree files
ARM: mvebu: Initialize MBus using the DT binding
ARM: mvebu: Remove the harcoded BootROM window allocation
bus: mvebu-mbus: Factorize Armada 370/XP data structures
arm_dt_init_cpu_maps parses the device tree, validates and sets the
cpu_possible_mask appropriately. It is unnecessary to do another DT
parse to get the number of cpus, use num_possible_cpus instead.
Cc: Gregory Clement <gregory.clement@free-electrons.com>
The address decoding window to access the BootROM should not be
allocated programatically, but instead declared in the device tree.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
This removes all the ARM uses of the __cpuinit macros from C code,
and all __CPUINIT from assembly code. It also had two ".previous"
section statements that were paired off against __CPUINIT
(aka .section ".cpuinit.text") that also get removed here.
[1] https://lkml.org/lkml/2013/5/20/589
The ->smp_init_cpus() function is called very early during boot, at a
point where dynamic I/O mappings are not yet possible. However, in the
Armada 370/XP implementation of this function, we have to get the
number of CPUs. We used to do that by accessing a hardware register,
which requires relying on a static I/O mapping set up by
->map_io(). Not only this requires hardcoding a virtual address, but
it also prevents us from removing the static I/O mapping.
So this commit changes the way used to get the number of CPUs: we now
use the Device Tree, which is a representation of the hardware, and
provides us the number of available CPUs. This is also more accurate,
because it potentially allows to boot the Linux kernel on only a
number of CPUs given by the Device Tree, instead of unconditionally on
all CPUs.
As a consequence, the coherency_get_cpu_count() function becomes no
longer used, so we remove it.
The changes needed to migrate the mach-mvebu (Armada 370 and Armada
XP) to the mvebu-mbus driver are fairly minimal, since not many
devices currently supported on those SoCs use address decoding
windows. The only one being the BootROM window, used to bring up
secondary CPUs.
However, this BootROM window needed for SMP brings an important
requirement: the mvebu-mbus driver must be initialized at the
->early_init() time, otherwise the BootROM window cannot be setup
early enough to be ready before the secondary CPUs are started.
This enables SMP support on the Armada XP processor. It adds the
mandatory functions to support SMP such as: the SMP initialization
functions in platsmp.c, the secondary CPU entry point in headsmp.S and
the CPU hotplug initial support in hotplug.c.
Signed-off-by: Yehuda Yitschak <yehuday@marvell.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
