path: root/arch/arm/mach-mx5/board-cpuimx51sd.c
2011-06-06gpio/mxc: Change gpio-mxc into an upstanding gpio driverShawn Guo
The patch makes necessary changes on gpio-mxc as below to turn it into an upstanding gpio driver. * Add a list to save all mx2 ports references, so that mx2_gpio_irq_handler can walk through all interrupt status registers * Use readl/writel to replace mach-specific accessors __raw_readl/__raw_writel * Change mxc_gpio_init into mxc_gpio_probe function * Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to be public at all, and also make some other cleanup on plat-mxc/include/mach/gpio.h at the same time And the patch then migrates mach-imx and mach-mx5 to the updated driver by adding corresponding platform devices. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-19ARM: imx: remove #includes already available from devices-common.hUwe Kleine-König
Most machine files include "devices-imxXX.h" which in turn includes <mach/devices-common.h>. The latter already includes many headers that the machine files don't need to include again. These were found by: $ grep \#include arch/arm/plat-mxc/include/mach/devices-common.h > tmpfile $ git grep -l 'devices-imx' arch/arm | xargs grep -f tmpfile -F (but I kept linux/init.h, linux/kernel.h and linux/platform_device.h) LAKML-Reference: 1298912674-15153-2-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-01cpuimx51sd: mcp2515 supports up to 10MHz SPI clockEric Bénard
Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-01cpuimx51sd: fix tsc2007Eric Bénard
- wrong MUX was set before for IRQ - get_pendown_state is no more needed Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-01cpuimx51sd: add cpufreq supportEric Bénard
2011-02-11ARM i.MX ehci: do ehci init in board specific functionsSascha Hauer
The mxc-ehci driver calls SoC specific phy initialization right after calling board specific initialization. To offer greater flexibility for boards to setup the phy and to get rid of some unnecessary flags in platform data this patch lets the boards call the SoC specific phy initialization and remove it from the driver. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-02-10ARM: mx5: use .init_early to initialize cpu type, reset address and iomuxerUwe Kleine-König
This used to be done in .map_io which is supposed to only setup the memory mapping. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-12-15ARM i.MX51: Full iomux supportSascha Hauer
This iomux file has been constructed from the Freescale pinmux tool. It contains all pins from the tool, but the datasheet lists some configurations not present in the tool, these are not yet added. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-12-14ARM: mx5: check for error in ioremapFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-12-03iMX51: introduce IMX_GPIO_NRArnaud Patard (Rtp)
Currently, to define a GPIO number, we're using something like : #define EFIKAMX_PCBID0 (2*32 + 16) to define GPIO 3 16. This is not really readable and it's error prone imho (note the 3 vs 2). So, I'm introducing a new macro to define this in a better way. Now, the code sample become : #define EFIKAMX_PCBID0 IMX_GPIO_NR(3, 16) v2: - move to gpio.h - add parens & spaces - switch to IMX_GPIO_NR instead of MX51_GPIO_NR Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-11-24ARM i.MX51 boards: Do not use PHYS_OFFSETSascha Hauer
PHYS_OFFSET may become a variable once the runtime PHYS_OFFSET patch is merged, so use MX51_PHYS_OFFSET for boot_params. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-11-24ARM: i.MX IOMUX-V3 replace struct pad_desc with bitmapped cookieLothar Waßmann
The following patch is a first step to convert the 'struct pad_desc' to a bitmapped cookie to facilitate adding platform specific pullup or drive strength definitions to existing pad definitions without need to rewrite the complete pad def. The patch wraps 'struct pad_desc' in an opaque data type and introduces macros to access the individual members. This patch does not constitute any functional change! Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-19mx5: add cpuimx51sd module and its baseboardEric Bénard
