This patch moves the contents of arch/arm/mach-mx5 to arch/arm/mach-imx
and adjusts the Makefile/Kconfig entries in a way that it's possible
to compile i.MX5 together with i.MX3/6.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
The board changes in the imx/devel branch conflict with other changes in
the device imx/dt branch.
arch/arm/mach-mx5/board-mx53_loco.c
arch/arm/mach-mx5/board-mx53_smd.c
arch/arm/plat-mxc/include/mach/common.h
arch/arm/plat-mxc/include/mach/memory.h
git://git.pengutronix.de/git/imx/linux-2.6 into imx/devel
arch/arm/mach-mx5/clock-mx51-mx53.c
arch/arm/mach-mx5/devices-imx53.h
It adds device tree support for imx53 boards.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Richard Zhu <richard.zhu@linaro.org>
Also, add handle_irq callbacks to machine descriptors.
The patch makes necessary changes on gpio-mxc as below to turn it
into an upstanding gpio driver.
* Add a list to save all mx2 ports references, so that
mx2_gpio_irq_handler can walk through all interrupt status
registers
* Use readl/writel to replace mach-specific accessors
__raw_readl/__raw_writel
* Change mxc_gpio_init into mxc_gpio_probe function
* Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to
be public at all, and also make some other cleanup on
plat-mxc/include/mach/gpio.h at the same time
And the patch then migrates mach-imx and mach-mx5 to the updated
driver by adding corresponding platform devices.
Acked-by: Olof Johansson <olof@lixom.net>
LAKML-Reference: 1301921449-32194-1-git-send-email-fabio.estevam@freescale.com
Most machine files include "devices-imxXX.h" which in turn includes
<mach/devices-common.h>. The latter already includes many headers
that the machine files don't need to include again.
These were found by:
$ grep \#include arch/arm/plat-mxc/include/mach/devices-common.h > tmpfile
$ git grep -l 'devices-imx' arch/arm | xargs grep -f tmpfile -F
(but I kept linux/init.h, linux/kernel.h and linux/platform_device.h)
LAKML-Reference: 1298912674-15153-2-git-send-email-u.kleine-koenig@pengutronix.de
On mx53_smd board only RX/TX pins are used on UART2.
This used to be done in .map_io which is supposed to only setup the
memory mapping.
Fix UART1 IOMUX settings and configure UART1 to work with only RX/TX pins.
Commit 816ad74 (ARM: i.MX53: Add full iomux support for mx53) renamed some of the pad names.
Make the changes accordingly so that mx53_loco and mx53_cmd can build without errors.
Acked-by: Richard Zhao <richard.zhao@freescale.com>
1. Add Kconfig and Makefile entries
2. Add board definition
3. enable uart and fec for SMD board
Signed-off-by: Yong Shen <yong.shen@freescale.com>
