path: root/arch/arm/mach-netx
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Remove references to "make dep"Adrian Bunk
"make dep" is no longer required in kernel 2.6, but was still mentioned in some places. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-05[ARM] 4641/2: netX: fix kobject_name typeRobert Schwebel
With commit 5984a2fc7e7c9ab118e78ae9799e98fc4ade40f9 kobject_name() is correctly being used to access the name field of kobj, but that function needs a pointer to a kobject, not the kobject itself. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-31[ARM] Fix netx_defconfig regressionRussell King
Fix: CC arch/arm/mach-netx/xc.o arch/arm/mach-netx/xc.c: In function 'request_xc': arch/arm/mach-netx/xc.c:192: error: 'struct kobject' has no member named 'name' arch/arm/mach-netx/xc.c:196: error: 'struct kobject' has no member named 'name' arch/arm/mach-netx/xc.c:200: error: 'struct kobject' has no member named 'name' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: fixup is_continous changes on ARMThomas Gleixner
Fixup the is_contionous replacement by a flag field. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[ARM] 4013/1: clocksource driver for netxSascha Hauer
Add a clocksource driver for netx systems Signed-off-by: Luotao Fu <lfu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[ARM] Include asm/hardware.h not asm/arch/hardware.hRussell King
2006-06-19[ARM] 3576/1: netX: board support for NXEB500HMI development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXEB500HMI development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3575/1: netX: board support for NXDB500 development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXDB500 development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3574/1: netX: board support for NXDKN development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXDKN development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3569/2: netX: driver for XMAC/XPEC enginesSascha Hauer
Patch from Sascha Hauer The netX processors have generic network bitstream engines (XMAC/XPEC). This driver adds support for firmware loading and start, stop, reset commands. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3568/2: netX: pointer fifo driverSascha Hauer
Patch from Sascha Hauer This patch adds support for the pointer FIFOs on netX. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3567/2: arm: base support for Hilscher netXSascha Hauer
Patch from Sascha Hauer This patch adds the base support for Hilscher's netX network processors. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3572/1: netX: framebuffer driver for Hilscher netXSascha Hauer
Patch from Sascha Hauer This patch adds framebuffer support for Hilscher's netX network processors. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
