path: root/arch/arm/mach-omap1/Makefile.boot
2005-07-10[PATCH] ARM: 2798/1: OMAP update 2/11: Change ARM Kconfig to support omap1 ↵Tony Lindgren
and omap2 Patch from Tony Lindgren This patch by Paul Mundt and other OMAP developers modifies ARM specific Kconfig to allow sharing code between OMAP1 and OMAP2 architectures. In order to share code between OMAP1 and OMAP2, all OMAP1 specific code is moved into mach-omap1 directory in the following patch. A new mach-omap2 directory will be added later on. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
