Otherwise multi-omap1 configurations may set wrong clock speed.
Created and tested against l-o master on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
The convention for omap device naming is omap_XXX.
Rename the device and driver name in order to stick
to this naming convention.
Change device name in clock nodes as well.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Ben Dooks <ben-i2c@fluff.org>
Acked-by: Paul Walmsley <paul@pwsan.com>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Implement GPIO as a platform device.
GPIO APIs are used in machine_init functions. Hence it is
required to complete GPIO probe before board_init. Therefore
GPIO device register and driver register are implemented as
postcore_initcalls.
omap_gpio_init() does nothing now and this function would be
removed in the next patch as it's usage is spread across most
of the board files.
Inorder to convert GPIO as platform device, modifications are
required in clockxxxx_data.c file for OMAP1 so that device names
can be used to obtain clock instead of getting clocks by
name/NULL ptr.
Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling
or disabling the clocks, modify sysconfig settings and remove usage
of clock FW APIs.
Note 1: Converting GPIO driver to use runtime PM APIs is not done as a
separate patch because GPIO clock names are different for various OMAPs
and are different for some of the banks in the same CPU. This would need
usage of cpu_is checks and bank id checks while using clock FW APIs in
the gpio driver. Hence while making GPIO a platform driver framework,
PM runtime APIs are used directly.
Note 2: While implementing GPIO as a platform device, pm runtime APIs
are used as mentioned above and modification is not done in gpio's
prepare for idle/ resume after idle functions. This would be done
in the next patch series and GPIO driver would be made to use dev_pm_ops
instead of sysdev_class in that series only.
Due to the above, the GPIO driver implicitly relies on
CM_AUTOIDLE = 1 on its iclk for power management to work, since the
driver never disables its iclk.
This would be taken care in the next patch series (see Note 3 below).
Refer to
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html
for more details.
Note 3: only pm_runtime_get_sync is called in gpio's probe() and
pm_runtime_put* is never called. This is to make the implementation
similar to the existing GPIO code. Another patch series would be sent
to correct this.
In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They
are enabled/ disabled whenever required using clock framework APIs
TODO:
1. Cleanup the GPIO driver. Use function pointers and register
offest pointers instead of using hardcoded values
2. Remove all cpu_is_ checks and OMAP specific macros
3. Remove usage of gpio_bank array so that only
instance specific information is used in driver code
4. Rename 'method'/ avoid it's usage
5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4
6. Modify gpio's prepare for idle/ resume after idle functions
to use runtime pm implentation.
Signed-off-by: Charulatha V <charu@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Basak, Partha <p-basak2@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: updated for bank specific revision and updated boards]
This change adds in the necessary clocks and mux pins for UART
control on omap7xx devices. I also made a change in the serial
code to only try and initialize two UARTs in omap_serial_init, as
these devices don't have three.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
Convert most of the magic numbers in mach-omap1/clock_data.c to use
macros. Clean up a few comments to conform with Documentation/CodingStyle.
Mark the current clkops_uart as being OMAP16xx-only, and add some comments
to indicate that it does not belong there, for future cleanup.
This patch should not cause any functional changes.
On OMAP4 platform the iclk control is completly under hardware control
and no software control is available.
This difference w.r.t previous OMAP's needs all the common driver
accross OMAP's , cpu_is_xxxx() checks. To avoid poulluting the
drivers dummy clock nodes are created (The autogeneration
script has been updated accordingly).
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
[paul@pwsan.com: made OMAP1 dummy_ck common and edited patch to reuse that]
The RATE_FIXED clock flag is pointless. In the OMAP1 clock code, it
simply causes the omap1_clk_round_rate() function to return the
current rate of the clock. omap1_clk_round_rate(), however, should
never be called for a fixed-rate clock, since none of these clocks
have a .round_rate function pointer set in their struct clk records.
Similarly, in the OMAP2+ clock code, the RATE_FIXED flag just causes
the clock code to emit a warning if the OMAP clock maintainer was
foolish enough to add a .round_rate function pointer to a fixed-rate
clock. "Doctor, it hurts when I pretend that a fixed-rate clock is
rate-changeable." "Then don't pretend that a fixed-rate clock is
rate-changeable." It has no functional value. This patch drops the
RATE_FIXED clock flag, removing it from all clocks that are so marked.
Cc: Richard Woodruff <r-woodruff2@ti.com>
After the clkdev conversion, the struct clk.id field became
superfluous, so, drop it. Bring the clock names closer to the TRMs
and ensure they are unique for debugfs.
The armwdt_ck clock uses a fixed divisor, so it can use the OMAP clock
fixed divisor recalculation code, rather than a custom function.
omap-fixes-for-linus
Commit 52650505fbf3a6ab851c801f54e73e76c55ab8da added an __initdata
decoration to the structure containing the clk_enable and clk_disable
functions. Once init data was freed, these pointers went to null, and
the next enable or disable call caused the kernel to crash. This
change removes this decoration.
[paul@pwsan.com: patch manually split and commit message edited]
This change adds in some missing clocks that were needed as a result
of 526505... (OMAP1 clock: convert mach-omap1/clock.h to
mach-omap1/clock_data.c). Prior to this, it was just assumed that
these clocks existed for all devices, and it was used directly instead
of calling it out with a clock_get call or similar. So, not having
the CK_7XX meant these clocks weren't being used anymore for omap 7xx
devices, which broke things badly.
[paul@pwsan.com: commit message edited]
Commit 35c9049b27040d09461bc90928ad770be7ddf661 added
drivers/spi/omap_spi_100k.c.
This patch add the related clocks and pin muxing
entries to make the driver work on omap7xx platforms.
This change adds MUX pin configuration and clocks for I2C support
to OMAP 730 and 850-based devices.
The OMAP1 clock code currently #includes a large .h file full of static
data structures. Instead, define the data in a .c file.
Russell King <linux@arm.linux.org.uk> proposed this new arrangement:
http://marc.info/?l=linux-omap&m=125967425908895&w=2
This patch also deals with most of the flagrant checkpatch violations.
While here, separate the mpu_rate data structures out into their own
files, opp.h and opp_data.c. In the long run, these mpu_rate tables
should be replaced with OPP code.
Also includes a patch from Felipe Balbi <felipe.balbi@nokia.com> to
mark omap1_clk_functions as __initdata to avoid a section warning:
http://patchwork.kernel.org/patch/64366/
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Cc: Nishanth Menon <nm@ti.com>
