path: root/arch/arm/mach-omap2/board-apollon.c
2013-02-01ARM: OMAP2+: Remove apollon board supportKyungmin Park
As apollon board doesn't used anymore, remove it. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> [tony@atomide.com: dropped uncompress.h changes, it's gone] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-08ARM: OMAP2+: board files: use SoC-specific system restart functionsPaul Walmsley
Modify the board files to use the SoC-specific system restart functions. At this point it's possible to remove omap_prcm_restart() from mach-omap2/prcm.c. While removing the prototypes for the now-unused restart functions, clean up a few more obsolete prototypes in mach-omap2/clock.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-10-17ARM: OMAP: Move plat/led.h to include/linux/platform_dataTony Lindgren
We need to move this away from plat for ARM common zImage support. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP2+: gpmc: localize gpmc headerAfzal Mohammed
Requirement of gpmc header outside of mach-omap2 has been cutoff, move gpmc header file in plat-omap folder to local mach-omap2 folder Objective - common zImage participation of omap Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-09-22ARM: omap: clk: add clk_prepare and clk_unprepareRajendra Nayak
As part of Common Clk Framework (CCF) the clk_enable() operation was split into a clk_prepare() which could sleep, and a clk_enable() which should never sleep. Similarly the clk_disable() was split into clk_disable() and clk_unprepare(). This was needed to handle complex cases where in a clk gate/ungate would require a slow and a fast part to be implemented. None of the clocks below seem to be in the 'complex' clocks category and are just simple clocks which are enabled/disabled through simple register writes. Most of the instances also seem to be called in non-atomic context which means its safe to move all of those from using a clk_enable() to clk_prepare_enable() and clk_disable() to clk_disable_unprepare(). For some others, mainly the ones handled through the hwmod framework there is a possibility that they get called in either an atomic or a non-atomic context. The way these get handled below work only as long as clk_prepare is implemented as a no-op (which is the case today) since this gets called very early at boot while most subsystems are unavailable. Hence these are marked with a *HACK* comment, which says we need to re-visit these once we start doing something meaningful with clk_prepare/clk_unprepare like doing voltage scaling or something that involves i2c. This is in preparation of OMAP moving to CCF. Based on initial changes from Mike Turquette. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-12ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+Tony Lindgren
As the plat and mach includes need to disappear for single zImage work, we need to remove plat/hardware.h. Do this by splitting plat/hardware.h into omap1 and omap2+ specific files. The old plat/hardware.h already has omap1 only defines, so it gets moved to mach/hardware.h for omap1. For omap2+, we use the local soc.h that for now just includes the related SoC headers to keep this patch more readable. Note that the local soc.h still includes plat/cpu.h that can be dealt with in later patches. Let's also include plat/serial.h from common.h for all the board-*.c files. This allows making the include files local later on without patching these files again. Note that only minimal changes are done in this patch for the drivers/watchdog/omap_wdt.c driver to keep things compiling. Further patches are needed to eventually remove cpu_is_omap usage in the drivers. Also only minimal changes are done to sound/soc/omap/* to remove the unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's no need to include omap44xx.h. While at it, also sort some of the includes in the standard way. Cc: linux-watchdog@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10ARM: OMAP: remove plat/board.h fileIgor Grinberg
plat/board.h file is now empty - remove it. Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: linux-mmc@vger.kernel.org Cc: linux-mtd@lists.infradead.org Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
2012-07-20mach-omap2: Fix typo in debug message and commentMasanari Iida
Correcting spelling typo in mach-omap2 Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-04ARM: OMAP2: Remove legacy USB FS supportTony Lindgren
The FS (Full Speed) USB controller is available on 2420 and 2430, but not being used. Out of the 2420 based boards only Nokia N8X0 are seeing active development and they have external HS (High Speed) TUSB controller. On omap 2430sdp there is MUSB HS controller, so there's no need to use the legacy USB FS controller. That leaves only H4 and Apollon boards that could use the FS USB controller. As both H4 and Apollon boards are old proprietary development boards, it's unlikely that we have any active developers working on those boards using the USB. So remove the FS USB support for omap2 machines. Patches are welcome if somebody wants to instead fix it all up to the current standards. Cc: linux-usb@vger.kernel.org Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-08ARM: omap2: use machine specific hook for late initShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2012-03-29ARM: OMAP: boards: Fix OMAP_GPIO_IRQ usage with gpio_to_irq()Tarun Kanti DebBarma
The following commits change gpio-omap to use dynamic IRQ allocation: 25db711 gpio/omap: Fix IRQ handling for SPARSE_IRQ 384ebe1 gpio/omap: Add DT support to GPIO driver With dynamic allocation of IRQ the usage of OMAP_GPIO_IRQ is no longer valid. We must be using gpio_to_irq() instead. Signed-off-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: omap: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-21Merge branch 'irqchip-consolidation' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into devel-stable Conflicts: arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-omap4panda.c arch/arm/mach-omap2/include/mach/omap4-common.h arch/arm/plat-omap/include/plat/irqs.h The changes to omap4-common.h were moved to arch/arm/mach-omap2/common.h and the other trivial conflicts resolved. The now empty ifdef in irqs.h was also eliminated.
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: omap2plus: convert to CONFIG_MULTI_IRQ_HANDLERMarc Zyngier
Convert the omap2plus platforms to be using CONFIG_MULTI_IRQ_HANDLER. Each machine is modified to provide either omap2_intc_handle_irq(), omap3_intc_handle_irq() or gic_handle_irq(). This allows for a major cleanup, removing the MULTI_OMAP setup from the interrupt path. Tested on both Panda and IGEPv2 (single kernel image) Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2011-10-31Merge branch 'depends/omap2_dss' into next/cleanupArnd Bergmann
Omap cleanups conflicted with omap2_dss work in a nontrivial way, this is the most logical fixup. Conflicts: arch/arm/mach-omap2/board-2430sdp.c arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-apollon.c arch/arm/mach-omap2/board-h4.c arch/arm/mach-omap2/board-ldp.c arch/arm/mach-omap2/board-rx51.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-09-30OMAP: Apollon: Port the display driver to new DSS2Tomi Valkeinen
Port the old omapfb panel driver to DSS2. This patch changes the board file only, the driver is ported in separate patch. Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-26ARM: OMAP2+: Use SoC specifc map_ioTony Lindgren
There's no longer any need for the board specific map_io. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Introduce SoC specific early_initTony Lindgren
Introduce them for each omap variant and just make them all call omap2_init_common_infrastructure for now. Do this for each board-*.c file except for board-generic and board-omap3beagle as they use the same machine ID for multiple SoCs. No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Move omap2_init_common_devices out of init_earlyTony Lindgren
There's no need to call omap2_init_common_devices from init_early. It no longer does anything else except reprogram the memory timings for some boards, so it's better to do it later so we have a chance to get console messages if something goes wrong. Move it to happen after omap_serial_init gets called. And while patching it anyways, rename it to omap_sdrc_init as suggested by Benoit Cousson <b-cousson@ti.com>. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-21ARM: mach-omap2: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-05-31ARM: OMAP2: Add missing include of linux/gpio.hAxel Lin
I got some build error like below while executing "make omap2plus_defconfig". CC arch/arm/mach-omap2/board-2430sdp.o arch/arm/mach-omap2/board-2430sdp.c: In function 'omap_2430sdp_init': arch/arm/mach-omap2/board-2430sdp.c:247: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function) arch/arm/mach-omap2/board-2430sdp.c:247: error: (Each undeclared identifier is reported only once arch/arm/mach-omap2/board-2430sdp.c:247: error: for each function it appears in.) This patch fixes the build error by include linux/gpio.h instead of mach/gpio.h. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Syed Mohammed Khasim <x0khasim@ti.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12arm: omap2plus: GPIO cleanupIgor Grinberg
use gpio_request_<one|array>() instead of multiple gpiolib calls, remove unneeded variables, etc. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-25omap2+: Minimize board specific init_early callsTony Lindgren
We should only call init_common_infrastructure and init_common_devices from init_early. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-14ARM: OMAP2: use early init hookRussell King - ARM Linux
Move non-mapping and non-irq initialization code out of .map_io and .init_irq respectively into the new init_early hook. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-21OMAP2+: io: split omap2_init_common_hw()Paul Walmsley
Split omap2_init_common_hw() into two functions. The first, omap2_init_common_infrastructure(), initializes the hwmod code and data, the OMAP PM code, and the clock code and data. The second, omap2_init_common_devices(), handles any other early device initialization that, for whatever reason, has not been or cannot be moved to initcalls or early platform devices. This patch is required for the hwmod postsetup patch, which allows board files to change the state that hwmods should be placed into at the conclusion of the hwmod _setup() function. For example, for a board whose creators wish to ensure watchdog coverage across the entire kernel boot process, code to change the watchdog's postsetup state will be added in the board-*.c file between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-12-17omap: kill all section mismatch warning for omap2plus_defconfigBryan Wu
This patch will kill following section mismatch warnings: WARNING: vmlinux.o(.text+0x24a00): Section mismatch in reference from the function zoom_twl_gpio_setup() to the (unknown reference) .init.data:(unknown) The function zoom_twl_gpio_setup() references the (unknown reference) __initdata (unknown). This is often because zoom_twl_gpio_setup lacks a __initdata annotation or the annotation of (unknown) is wrong. WARNING: vmlinux.o(.text+0x24bfc): Section mismatch in reference from the function cm_t35_twl_gpio_setup() to the (unknown reference) .init.data:(unknown) The function cm_t35_twl_gpio_setup() references the (unknown reference) __initdata (unknown). This is often because cm_t35_twl_gpio_setup lacks a __initdata annotation or the annotation of (unknown) is wrong. WARNING: vmlinux.o(.data+0x1d3e0): Section mismatch in reference from the variable h4_config to the (unknown reference) .init.data:(unknown) The variable h4_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: vmlinux.o(.data+0x1dc08): Section mismatch in reference from the variable sdp2430_config to the (unknown reference) .init.data:(unknown) The variable sdp2430_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: vmlinux.o(.data+0x1e1d8): Section mismatch in reference from the variable apollon_config to the (unknown reference) .init.data:(unknown) The variable apollon_config references the (unknown reference) __initdata (unknown) If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-10Merge branch 'devel-gpio' into omap-for-linusTony Lindgren
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-07omap: Fix gpio_request calls to happen as arch_initcallTony Lindgren
Looks like some boards are calling gpio_request from init_irq. This will make the request_irq fail, as GPIO will be initialized as postcore_initcall. Reported-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-02arm: mach-omap2: remove NULL board_mux from board filesAaro Koskinen
If CONFIG_OMAP_MUX is not enabled, we can define board_mux in the header file instead of forcing every single board to define it. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [tony@atomide.com: updated for combined board-zoom files] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-25Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits) omap: complete removal of machine_desc.io_pg_offst and .phys_io omap: UART: fix wakeup registers for OMAP24xx UART2 omap: Fix spotty MMC voltages ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h serial: omap-serial: fix signess error OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish omap: dma: Fix buffering disable bit setting for omap24xx omap: serial: Fix the boot-up crash/reboot without CONFIG_PM OMAP3: PM: fix scratchpad memory accesses for off-mode omap4: pandaboard: enable the ehci port on pandaboard omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set omap4: pandaboard: remove unused hsmmc definition OMAP: McBSP: Remove null omap44xx ops comment OMAP: McBSP: Swap CLKS source definition OMAP: McBSP: Fix CLKR and FSR signal muxing OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks OMAP: control: move plat-omap/control.h to mach-omap2/control.h OMAP: split plat-omap/common.c OMAP: McBSP: implement functional clock switching via clock framework OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c ... Fixed up trivial conflicts in arch/arm/mach-omap2/ {board-zoom-peripherals.c,devices.c} as per Tony
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-08OMAP: control: move plat-omap/control.h to mach-omap2/control.hPaul Walmsley
Only OMAP2+ platforms have the System Control Module (SCM) IP block. In the past, we've kept the SCM header file in plat-omap. This has led to abuse - device drivers including it; includes being added that create implicit dependencies on OMAP2+ builds; etc. In response, move the SCM headers into mach-omap2/. As part of this, remove the direct SCM access from the OMAP UDC driver. It was clearly broken. The UDC code needs an indepth review for use on OMAP2+ chips. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-04Merge branch 'devel-map-io' into omap-for-linusTony Lindgren
2010-07-16ARM: OMAP: Convert to use ->reserve method to reserve boot time memoryRussell King
2010-07-05omap: mux: Convert 2420 platform init code to use new mux codeTony Lindgren
Convert 2420 platform init code to use new mux code Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Mux Apollon LCD power in board-apollon.cTony Lindgren
Use the new mux function for that. Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tomi Valkeinen <tomi.valkeinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Select POP package for ApollonTony Lindgren
Select POP package for Apollon Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: Move omap2 FS USB platform init code into mach-omap2/usb-fs.cTony Lindgren
Move omap2 FS USB platform init code into mach-omap2/usb-fs.c. This will allow further work later on to use omap hwmod for initializing the device. Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: Fix omap2_map_common_io for multi-omapTony Lindgren
Fix omap2_map_common_io for multi-omap Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: use smc91x_platdata to setup smc91xLadislav Michl
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff in smc91x driver Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: Fix DEBUG_LL UART io addressSantosh Shilimkar
This patch fixes the low level debug UART io address as per this series. The change is essential to have CONFIG_DEBUG_LL working. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-20Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Merged in order that I can apply the Nomadik nand/onenand support patches.
