path: root/arch/arm/mach-omap2/clkt2xxx_virt_prcm_set.c
2010-12-21OMAP2/3: PRM/CM: prefix OMAP2 PRM/CM functions with "omap2_"Paul Walmsley
Now that OMAP4-specific PRCM functions have been added, distinguish the existing OMAP2/3-specific PRCM functions by prefixing them with "omap2_". This patch should not result in any functional change. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-05-20OMAP2 clock: fix recursive spinlock attempt when CONFIG_CPU_FREQ=yPaul Walmsley
The OMAP2 MPU virtual clock node code attempted to call clk_get_rate() while the clockfw_lock spinlock was held. Fix by reading the sys_ck rate directly. Signed-off-by: Paul Walmsley <paul@pwsan.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-26OMAP2xxx clock: move the DVFS virtual clock code into ↵Paul Walmsley
mach-omap2/clkt2xxx_virt_prcm_set.c Move the DVFS virtual clock functions from clock2xxx.c to mach-omap2/clkt2xxx_virt_prcm_set.c. This is intended to make the clock code easier to understand, since all of the functions needed to manage the virt_prcm_set clock are now located in their own file, rather than being mixed with other, unrelated functions. Clock debugging is also now more finely-grained, since the DEBUG macro can now be defined for the virt_prcm_set clock alone. This should reduce unnecessary console noise when debugging. Also, if at some future point the mach-omap2/ directory is split into OMAP2/3/4 variants, this clkt file can be placed in the mach-omap2xxx/ directory, rather than shared with other chip types that don't use this clock type. Thanks to Alexander Shishkin <virtuoso@slind.org> for his comments. Thanks also to Kevin Hilman <khilman@deeprootsystems.com> for finding and fixing a bug with the CONFIG_CPU_FREQ portion of this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Richard Woodruff <r-woodruff2@ti.com> Cc: Alexander Shishkin <virtuoso@slind.org> Cc: Kevin Hilman <khilman@deeprootsystems.com>
