path: root/arch/arm/mach-omap2/clkt_dpll.c
2011-03-10Merge remote branches 'remotes/origin/pwrdm_clkdm_b_2.6.39', ↵Paul Walmsley
'remotes/origin/pwrdm_add_can_lose_context_fns_2.6.39', 'remotes/origin/omap_device_a_2.6.39', 'remotes/origin/mmc_a_2.6.39', 'remotes/origin/hwmod_b_2.6.39', 'remotes/origin/dmtimer_a_2.6.39', 'remotes/origin/pwrdm_clkdm_a_2.6.39', 'remotes/origin/clkdm_statdep_omap4_2.6.39', 'remotes/origin/clk_a_2.6.39', 'remotes/origin/clk_autoidle_a_2.6.39', 'remotes/origin/clk_autoidle_b_2.6.39', 'remotes/origin/clk_b_2.6.39', 'remotes/origin/clk_clkdm_a_2.6.39', 'remotes/origin/misc_a_2.6.39', 'remotes/origin/for_2.6.39/omap3_hwmod_data' and 'remotes/origin/wdtimer_a_2.6.39' into tmp-integration-2.6.39-20110310-024
2011-03-07OMAP2+: clock: remove the DPLL rate tolerance codePaul Walmsley
Remove the DPLL rate tolerance code that is called during rate rounding. As far as I know, this code is never used, since it's been more important for callers of the DPLL round_rate()/set_rate() functions to obtain an exact rate than it is to save a relatively small amount of power. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-02-22OMAP2/3: clock: fix fint calculation for DPLL_FREQSELJohn Ogness
In OMAP35X TRM Rev 2010-05 Figure 7-18 "DPLL With EMI Reduction Feature", it is shown that the internal frequency is calculated by CLK_IN/(N+1). However, the value passed to _dpll_test_fint() is already "N+1" since Linux is using the values to divide by. In the technical reference manual, "N" is referring to the divider's register value (0-127). During power management testing, it was observed that programming the wrong jitter correction value can cause the system to become unstable and eventually crash. Signed-off-by: John Ogness <john.ogness@linutronix.de> [paul@pwsan.com: added second paragraph to commit message] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-24OMAP2/3/4 clock: fix DPLL multiplier value errors; also copyrights, ↵Paul Walmsley
includes, documentation The maximum DPLL multiplier (M) values for OMAP2xxx and OMAP3xxx are one increment higher than they should be. See for example the OMAP242x TRM Rev X Section 5.10.6 "Clock Generator Registers" and the OMAP36xx TRM Rev C Table 3-202 "CM_CLKSEL1_PLL". Programming a 0 into the DPLL's M register bitfield is valid for OMAP2/3 and indicates that the DPLL should enter MN-bypass mode. Also, increase the minimum multiplier (M) value for the DPLL rate rounding code from 1 to 2, to ensure that it does not inadvertently put the DPLL into bypass. Note that the register documentation in the OMAP2xxx and OMAP3xxx TRMs does not make clear that the actual DPLL divider value (the "N") is the content of the appropriate register bitfield for the N value, _plus one_. (In other words, an N register bitfield of 0 indicates a DPLL divider value of 1.) This is only clearly documented in the OMAP4430 TRM, in, for example, OMAP4430 TRM Rev A Table 3-1167 "CM_CLKSEL_DPLL_USB". While here, update copyrights, add kerneldoc for struct dpll_data, drop the unused struct dpll_data.max_tolerance field, remove some unnecessary #includes in DPLL-related code, and replace the #include of <linux/module.h> with <linux/list.h>, which is what was really needed. The OMAP4 clock autogenerator script has been updated accordingly. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com>
2010-01-26OMAP2/3/4 clock: move DPLL clock functions into mach-omap2/clkt_dpll.cPaul Walmsley
Move all DPLL-related clock functions from mach-omap2/clock.c to mach-omap2/clkt_dpll.c. This is intended to make the clock code easier to understand, since all of the functions needed to manage DPLLs are now located in their own file, rather than being mixed with other, unrelated functions. Clock debugging is also now more finely-grained, since the DEBUG macro can now be defined for DPLLs alone. This should reduce unnecessary console noise when debugging. Also, if at some future point the mach-omap2/ directory is split into OMAP2/3/4 variants, this clkt file can be moved to the plat-omap/ directory to be shared. Thanks to Alexander Shishkin <virtuoso@slind.org> for his comments to improve the patch description. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Alexander Shishkin <virtuoso@slind.org>
