path: root/arch/arm/mach-omap2/cminst44xx.c
2011-07-10OMAP4: cm: Add two new APIs for modulemode controlBenoit Cousson
In OMAP4, a new programming model based on module control instead of clock control was introduced. Expose two APIs to allow the upper layer (omap_hwmod) to control the module mode independently of the parent clocks management. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: renamed 'omap4_cm_' fns to 'omap4_cminst_'; cleaned up kerneldoc] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-07-10OMAP: hwmod: Wait the idle status to be disabledBenoit Cousson
It is mandatory to wait for a module to be in disabled state before potentially disabling source clock or re-asserting a reset. omap_hwmod_idle and omap_hwmod_shutdown does not wait for the module to be fully idle. Add a cm_xxx accessor to wait the clkctrl idle status to be disabled. Fix hwmod_[idle|shutdown] to use this API. Based on Rajendra's initial patch. Please note that most interconnects hwmod will return one timeout because it is impossible for them to be in idle since the processor is accessing the registers though the interconnect. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Todd Poynor <toddpoynor@google.com> [paul@pwsan.com: move cpu_is_*() tests to the top of _wait_target_disable(); incorporate some feedback from Todd] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-07-10OMAP4: hwmod: Replace CLKCTRL absolute address with offset macrosBenoit Cousson
The CLKCTRL register was accessed using an absolute address. The usage of hardcoded macros to calculate virtual address from physical one should be avoided as much as possible. The usage of a offset will allow future improvement like migration from the current architecture code toward a module driver. Update cm_xxx accessor, move definition to the proper header file and update copyrights. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Todd Poynor <toddpoynor@google.com> [paul@pwsan.com: renamed 'omap4_cm_' fns to 'omap4_cminst_'; removed empty fn prototype section from cm44xx.h; incorporated comments from Todd; documented some functions] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-02-25OMAP4: CM: Add CM accesor api for bitwise controlRajendra Nayak
Add new OMAP4 CM accesor apis to set/clear and read bitfields (based on mask) from CM registers. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-12-21OMAP4: clockdomains: add OMAP4 PRCM data and OMAP4 supportPaul Walmsley
Add PRCM partition, CM instance register address offset, and clockdomain register address offset to each OMAP4 struct clockdomain record. Add OMAP4 clockdomain code to use this new data to access registers properly. While here, clean up some nearby clockdomain code to allocate auto variables in my recollection of Linus's preferred style. The autogeneration scripts have been updated. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Benoît Cousson <b-cousson@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP4: PRCM: add OMAP4-specific accessor/mutator functionsPaul Walmsley
In some ways, the OMAP4 PRCM register layout is quite different than the OMAP2/3 PRCM register layout. For example, on OMAP2/3, from a register layout point of view, all CM instances were located in the CM subsystem, and all PRM instances were located in the PRM subsystem. OMAP4 changes this. Now, for example, some CM instances, such as WKUP_CM and EMU_CM, are located in the system PRM subsystem. And a "local PRCM" exists for the MPU - this PRCM combines registers that would normally appear in both CM and PRM instances, but uses its own register layout which matches neither the OMAP2/3 PRCM layout nor the OMAP4 PRCM layout. To try to deal with this, introduce some new functions, omap4_cminst* and omap4_prminst*. The former is to be used when writing to a CM instance register (no matter what subsystem or hardware module it exists in), and the latter, similarly, with PRM instance registers. To determine which "PRCM partition" to write to, the functions take a PRCM instance ID argument. Subsequent patches add these partition IDs to the OMAP4 powerdomain and clockdomain definitions. As far as I can see, there's really no good way to handle these types of register access inconsistencies. This patch seemed like the least bad approach. Moving forward, the long-term goal is to remove all direct PRCM register access from the PM code. PRCM register access should go through layers such as the powerdomain and clockdomain code that can hide the details of how to interact with the specific hardware variant. While here, rename cm4xxx.c to cm44xx.c to match the naming convention of the other OMAP4 PRCM files. Thanks to Santosh Shilimkar <santosh.shilimkar@ti.com>, Rajendra Nayak <rnayak@ti.com>, and Benoît Cousson <b-cousson@ti.com> for some comments. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
