uninitialized
[ Upstream commit dc30e70391376ba3987aeb856ae6d9c0706534f1 ]
In function omap4_dsi_mux_pads(), local variable "reg" could
be uninitialized if function regmap_read() returns -EINVAL.
However, it will be used directly in the later context, which
is potentially unsafe.
Signed-off-by: Yizhuo <yzhai003@ucr.edu>
Add platform code to detect DRA7 DSS.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Simplify the DSS detection logic by creating a list of the omapdss
compat strings, instead of checking each separately with an 'if'.
The legacy control module APIs will be gone, thus convert the display
driver to use syscon. This change should eventually be moved to
display driver from the board directory.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Use the more common pr_warn.
Other miscellanea:
o Realign arguments
Move the panel/encoder driver compatible-string converter from
arch/arm/mach-omap2/display.c to omapdss driver. That is a more logical
place for it, as it's really an omapdss internal hack.
The code is rewritten to follow the video node graph, starting from
omapdss. This removes the need to have the device compatible-string
database.
Add detection of omap5-dss nodes so that the related devices get
initialized.
Add DSS features for AM43xx.
Signed-off-by: Sathya Prakash M R <sathyap@ti.com>
Signed-off-by: Marek Belisko <marek@goldelico.com>
Merge OMAP DSS DT support
As there is no common panel framework in the kernel, we have OMAP
specific panel drivers. However, the DT data should be generic. This
brings the issue that some other platform could use the same panels, and
would need to create a driver with the same 'compatible' string as the
OMAP driver.
In the long run, we have to get a common panel framework. For the time
being, this patch solves the issue:
At early boot time, we go through the DT nodes looking for the panels
the kernel supports for OMAP. For each found node, the 'compatible'
string is prepended with "omapdss,", i.e. "sony,acx565akm" becomes
"omapdss,sony,acx565akm". The OMAP display drivers all have "omapdss,"
at the beginning of their compatible field.
This allows us to have generic DT data, but OMAP specific display
drivers.
Reviewed-by: Archit Taneja <archit@ti.com>
The OMAP display architecture requires a bunch of platform devices which
are not created via .dts (for now). We also need to pass a few function
pointers and the DSS hardware version from the arch code to omapdss
driver.
This patch adds omapdss_init_of() function, called from board-generic at
init time, which handles those tasks.
The omapdss driver no longer uses get_context_loss_count call, so we can
remove it.
Commit e30b06f4d5f000c31a7747a7e7ada78a5fd419a1 (ARM: OMAP2+: Remove
legacy mux code for display.c) removed non-DT DSI and HDMI pinmuxing.
However, DSI pinmuxing is still needed, and removing that caused DSI
displays not to work.
This reverts the DSI parts of the commit.
This is all omap4 specific, which is device tree based
nowadays and should use pinctrl-single instead.
Move omap_vout device creation inside the omap_display_init so that we can
correctly create the device based on the presence of omapdss within the
platform.
For example, on a kernel image supporting multiple platforms, omap_init_vout
will create a omapdrm platform device on a AM33xx platform even though it
doesn't have a DSS block.
Signed-off-by: Archit Taneja <archit@ti.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
omap_display_init
Move omapfb and omapvrfb device creation inside the omap_display_init so that
we can correctly create the device based on the presence of omapdss within the
platform.
For example, on a kernel image supporting multiple platforms, omap_init_vrfb and
omap_init_fb will create omapvrfb and omapfb platform devices respectively on a
AM33xx platform even though it doesn't have a VRFB or DSS block.
Move omapdrm device creation inside the omap_display_init so that we can
platform.
For example, on a kernel image supporting multiple platforms, omap_init_drm
Originally worked on by Andy Gross.
Cc: Andy Gross <andygro@gmail.com>
The DPI and SDI platform devices are currently created with the ID of
-1. The ID doesn't currently affect anything.
However, we have added regulator supply entries for "omapdss_dpi.0" and
"omapdss_sdi.0" to the board files, although these supply entries are
not yet used. As the ID used for the devices is -1, these regulator
supply entries will not work.
To fix the issue, assign ID of 0 to the devices. In the future there may
be more than one DPI or SDI output, so it makes sense to have a proper
ID for them.
Remove now-obsolete code from arch/arm/mach-omap2/omap_device.c. This
mostly consists of removing the first attempt at device PM latency
handling. This was never really used, has been replaced by the common
dev_pm_qos code, and needs to go away as part of the DT conversion.
Also, the early platform_device creation code has been removed, as it
appears to be unused.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Pull fbdev changes from Tomi Valkeinen:
"OMAPDSS changes, including:
- use dynanic debug prints
- OMAP platform dependency removals
- Creation of compat-layer, helping us to improve omapdrm
- Misc cleanups, aiming to make omadss more in line with the upcoming
common display framework
Exynos DP changes for the 3.8 merge window:
- Device Tree support for Samsung Exynos DP
- SW Link training is cleaned up.
- HPD interrupt is supported.
Samsung Framebuffer changes for the 3.8 merge window:
- The bit definitions of header file are updated.
- Some minor typos are fixed.
- Some minor bugs of s3c_fb_check_var() are fixed.
FB related changes for SH Mobile, Freescale DIU
Add support for the Solomon SSD1307 OLED Controller"
* tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits)
OMAPDSS: fix TV-out issue with DSI PLL
Revert "OMAPFB: simplify locking"
OMAPFB: remove silly loop in fb2display()
OMAPFB: fix error handling in omapfb_find_best_mode()
OMAPFB: use devm_kzalloc to allocate omapfb2_device
OMAPDSS: DISPC: remove dispc fck uses
OMAPDSS: DISPC: get dss clock rate from dss driver
drivers/video/console/softcursor.c: remove redundant NULL check before kfree()
drivers/video: add support for the Solomon SSD1307 OLED Controller
OMAPDSS: use omapdss_compat_init() in other drivers
OMAPDSS: export dispc functions
OMAPDSS: export dss_feat functions
OMAPDSS: export dss_mgr_ops functions
OMAPDSS: separate compat files in the Makefile
OMAPDSS: move display sysfs init to compat layer
OMAPDSS: DPI: use dispc's check_timings
OMAPDSS: DISPC: add dispc_ovl_check()
OMAPDSS: move irq handling to dispc-compat
OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c
OMAPDSS: move blocking mgr enable/disable to compat layer
arch/arm/mach-davinci/devices-da8xx.c
arch/arm/plat-omap/common.c
drivers/media/platform/omap/omap_vout.c
Consolidate all of the copies of MAX_MODULE_HARDRESET_WAIT and
MAX_MODULE_SOFTRESET_WAIT into one place, arch/arm/mach-omap2/prm.h.
Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
Split the omap4_hdmi_mux_pads() function into two parts, one handles the
tpd12s015 gpio muxing, the other handles the hdmi pins.
This is clearer, as hdmi and tpd12s015 are separate devices, and it also
allows us to mux those separately with DT.
Cc: Ricardo Neri <ricardo.neri@ti.com>
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
We must move this for ARM common zImage support.
Note that neither drivers/media/rc/ir-rx51.c or
drivers/media/platform/omap3isp/ispvideo.c need
to include omap-pm.h, so this patch removes the
include for those files.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Timo Kokkonen <timo.t.kokkonen@iki.fi>
Cc: linux-media@vger.kernel.org
Let's make omap_hwmod local to mach-omap2 for
Let's make omap_device local to mach-omap2 for
Add new enum, omapdss_version, that is used to tell which DSS hardware
version the SoC has. This enum is initialized during platform init, and
passed in the platform data to omapdss driver.
Note that the versions are not "continuous", that is, you cannot check
if the version is less or greater than something, but you need to check
for exact version match. In other words, this is invalid:
/* test if DSS is 3630 or earlier */
if (ver <= OMAPDSS_VER_OMAP3630)
Pull fbdev updates from Florian Tobias Schandinat:
"This includes:
- large updates for OMAP
- basic OMAP5 DSS support for DPI and DSI outputs
- large cleanups and restructuring
- some update to Exynos and da8xx-fb
- removal of the pnx4008 driver (arch removed)
- various other small patches"
Fix up some trivial conflicts (mostly just include line changes, but
also some due to the renaming of the deferred work functions by Tejun).
* tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits)
gbefb: fix compile error
video: mark nuc900fb_map_video_memory as __devinit
video/mx3fb: set .owner to prevent module unloading while being used
video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare
drivers/video/exynos/exynos_mipi_dsi.c: fix error return code
drivers/video/savage/savagefb_driver.c: fix error return code
video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare
da8xx-fb: save and restore LCDC context across suspend/resume cycle
da8xx-fb: add pm_runtime support
video/udlfb: fix line counting in fb_write
OMAPDSS: add missing include for string.h
OMAPDSS: DISPC: Configure color conversion coefficients for writeback
OMAPDSS: DISPC: Add manager like functions for writeback
OMAPDSS: DISPC: Configure writeback FIFOs
OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup()
OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup
OMAPDSS: DISPC: Add function to set channel in for writeback
OMAPDSS: DISPC: Don't set chroma resampling bit for writeback
OMAPDSS: DISPC: Downscale chroma if plane is writeback
OMAPDSS: DISPC: Configure input and output sizes for writeback
In case of error, the function omap_device_alloc() returns ERR_PTR()
not NULL pointer. The NULL test in the return value check should
be replaced with IS_ERR().
dpatch engine is used to auto generated this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pull late ARM soc platform updates from Olof Johansson:
"This branch contains updates to OMAP and Marvell platforms (kirkwood,
dove, mvebu) that came in after we had done the big multiplatform
merges, so they were kept separate from the rest, and not separated
into the traditional topics of cleanup/driver/platform features.
For OMAP, the updates are:
- Runtime PM conversions for the GPMC and RNG IP blocks
- Preparation patches for the OMAP common clock framework conversion
- clkdev alias additions required by other drivers
- Performance Monitoring Unit (PMU) support for OMAP2, 3, and
non-4430 OMAP4
- OMAP hwmod code and data improvements
- Preparation patches for the IOMMU runtime PM conversion
- Preparation patches for OMAP4 full-chip retention support
For Kirkwood/Dove/mvebu:
- New driver for "address decoder controller" for mvebu, which is a
piece of hardware that configures addressable devices and
peripherals. First user is the boot rom aperture on armada XP
since it is needed for SMP support.
- New device tree bindings for peripherals such as gpio-fan, iconnect
nand, mv_cesa and the above address decoder controller.
- Some defconfig updates, mostly to enable new DT boards and a few
drivers.
- New drivers using the pincontrol subsystem for dove, kirkwood and
mvebu
- New clean gpio driver for mvebu"
* tag 'soc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (98 commits)
ARM: mvebu: fix build breaks from multi-platform conversion
ARM: OMAP4460/4470: PMU: Enable PMU for OMAP4460/70
ARM: OMAP2+: PMU: Add runtime PM support
ARM: OMAP4430: PMU: prepare to create PMU device via HWMOD
ARM: OMAP2+: PMU: Convert OMAP2/3 devices to use HWMOD
ARM: OMAP3: hwmod data: Add debugss HWMOD data
ARM: OMAP2+: clockdomain/hwmod: add workaround for EMU clockdomain idle problems
ARM: OMAP: Add a timer attribute for timers that can interrupt the DSP
hwrng: OMAP: remove SoC restrictions from driver registration
ARM: OMAP: split OMAP1, OMAP2+ RNG device registration
hwrng: OMAP: convert to use runtime PM
hwrng: OMAP: store per-device data in per-device variables, not file statics
ARM: OMAP2xxx: hwmod/CM: add RNG integration data
ARM: OMAP2+: gpmc: minimal driver support
ARM: OMAP2+: gpmc: Adapt to HWMOD
ARM: OMAP2/3: hwmod data: add gpmc
ARM: OMAP4: hwmod data: add mmu hwmod for ipu and dsp
ARM: OMAP3: hwmod data: add mmu data for iva and isp
ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selected
ARM: OMAP4: hwmod data: add missing HWMOD_NO_IDLEST flags to some PRCM IP blocks
As part of Common Clk Framework (CCF) the clk_enable() operation
was split into a clk_prepare() which could sleep, and a clk_enable()
which should never sleep. Similarly the clk_disable() was
split into clk_disable() and clk_unprepare(). This was
needed to handle complex cases where in a clk gate/ungate
would require a slow and a fast part to be implemented.
None of the clocks below seem to be in the 'complex' clocks
category and are just simple clocks which are enabled/disabled
through simple register writes.
Most of the instances also seem to be called in non-atomic
context which means its safe to move all of those from
using a clk_enable() to clk_prepare_enable() and clk_disable() to
clk_disable_unprepare().
For some others, mainly the ones handled through the hwmod framework
there is a possibility that they get called in either an atomic
or a non-atomic context.
The way these get handled below work only as long as clk_prepare
is implemented as a no-op (which is the case today) since this gets
called very early at boot while most subsystems are unavailable.
Hence these are marked with a *HACK* comment, which says we need
to re-visit these once we start doing something meaningful with
clk_prepare/clk_unprepare like doing voltage scaling or something
that involves i2c.
This is in preparation of OMAP moving to CCF.
Based on initial changes from Mike Turquette.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
This is a alternative to "HACK: OMAP: DSS2: VENC: disable VENC on OMAP4 to
prevent crash" (ba02fa37de) by Tomi Valkeinen <tomi.valkeinen@ti.com> to prevent
VENC from crashing OMAP4 kernel. This prevents OMAPDSS from initial registration
of a device for VENC on OMAP4.
Signed-off-by: Chandrabhanu Mahapatra <cmahapatra@ti.com>
The dispc_disable_outputs() function currently disables all LCD managers except
LCD3. This patch adds disabling functionality for LCD3 manager thereby
maintaining consistency of Display Subsystem for in case Display Controller is
reset when LCD3 manager is in use.
The omapdss arch initialization code registers all the output devices as
omap_devices. However, DPI and SDI are not proper omap_devices, as they
do not have any corresponding HWMOD. This leads to crashes or problems
when the platform code tries to use omap_device functions for DPI and
SDI devices.
One such crash was reported by John Stultz <johnstul@us.ibm.com>:
[ 18.756835] Unable to handle kernel NULL pointer dereference at
virtual addr8
[ 18.765319] pgd = ea6b8000
[ 18.768188] [00000018] *pgd=aa942831, *pte=00000000, *ppte=00000000
[ 18.774749] Internal error: Oops: 17 [#1] SMP ARM
[ 18.779663] Modules linked in:
[ 18.782836] CPU: 0 Not tainted (3.5.0-rc1-dirty #456)
[ 18.788482] PC is at _od_resume_noirq+0x1c/0x78
[ 18.793212] LR is at _od_resume_noirq+0x6c/0x78
[ 18.797943] pc : [<c00307ec>] lr : [<c003083c>] psr: 20000113
[ 18.797943] sp : ec3abe80 ip : ec3abdb8 fp : 00000006
[ 18.809936] r10: ec1148b8 r9 : c08a48f0 r8 : c00307d0
[ 18.815368] r7 : 00000000 r6 : 00000000 r5 : ec114800 r4 :
ec114808
[ 18.822174] r3 : 00000000 r2 : 00000000 r1 : ec154fe8 r0 :
00000006
[ 18.829010] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM
Segment user
[ 18.836456] Control: 10c5387d Table: aa6b804a DAC: 00000015
[ 18.842437] Process sh (pid: 1139, stack limit = 0xec3aa2f0)
[ 18.848358] Stack: (0xec3abe80 to 0xec3ac000)
DPI and SDI can be plain platform_devices. This patch changes the
registration from omap_device_register() to platform_device_add().
Reported-by: John Stultz <johnstul@us.ibm.com>
Tested-by: Jean Pihet <jean.pihet@newoldbits.com>
Currently the higher level omapdss platform driver gets the list of
displays in its platform data, and uses that list to create the
omap_dss_device for each display.
With DT, the logical way to do the above is to list the displays under
each individual output, i.e. we'd have "dpi" node, under which we would
have the display that uses DPI. In other words, each output driver
handles the displays that use that particular output.
To make the current code ready for DT, this patch modifies the output
drivers so that each of them creates the display devices which use that
output. However, instead of changing the platform data to suit this
method, each output driver is passed the full list of displays, and the
drivers pick the displays that are meant for them. This allows us to
keep the old platform data, and thus we avoid the need to change the
board files.
We currently have separate device/driver for each DSS HW module. The DPI
and SDI outputs are more or less parts of the DSS or DISPC hardware
modules, but in SW it makes sense to represent them as device/driver
pairs similarly to all the other outputs. This also makes sense for
device tree, as each node under dss will be a platform device, and
handling DPI & SDI somehow differently than the rest would just make the
code more complex.
This patch modifies arch/arm/mach-omap2/display.c to create platform
devices for DPI and SDI, and later patches will implement driver for
them.
Instead of using omap_device_build() to create the omap_devices for DSS
hwmods, create them with a custom function. This will allow us to create
a parent-child hierarchy for the devices so that the omapdss_core device
is parent for the rest of the dss hwmod devices.
The omapdss pdata handling is a mess. This is more evident when trying
to use device tree for DSS, as we don't have platform data anymore in
that case. This patch cleans the pdata handling by:
- Remove struct omap_display_platform_data. It was used just as a
wrapper for struct omap_dss_board_info.
- Pass the platform data only to omapdss device. The drivers for omap
dss hwmods do not need the platform data. This should also work better
for DT, as we can create omapdss device programmatically in generic omap
boot code, and thus we can pass the pdata to it.
- Create dss functions for get_ctx_loss_count and dsi_enable/disable_pads
that the dss hwmod drivers can call.
omapdss driver needs to use the omap_pm_set_min_bus_tput(), so add a new
entry for that in omapdss's platform data, and set it.
Cc: Paul Walmsley <paul@pwsan.com>
Acked-by: Kevin Hilman <khilman@ti.com>
Commit d1589f0912533e6cb2ac8fd6f1feb3d5989fe8cb (ARM: OMAP2+: Mark
omap_hsmmc_init and omap_mux related functions as __init) changed DSI
muxing functions to __init. This doesn't work, as the muxing functions
are used every time a DSI display is enabled or disabled.
This patch removes the __inits from DSI mux functions that were
accidentally marked as __init, and makes omap4_hdmi_mux_pads __init
like it should be.
[tony@atomide.com: update comments, mark omap4_hdmi_mux_pads __init]
Now that omap hsmmc init is split into two functions, it's safe
to mark omap_hsmmc_init and omap_mux related functions to __init.
This basically reverts the following fixes for the case where
TWL was compiled as a module:
a98f77b (ARM: omap: fix section mismatch warning for sdp3430_twl_gpio_setup())
8930b4e (ARM: omap: fix section mismatch warnings in mux.c caused by hsmmc.c)
Additionally it fixes up the remaining section warnings for
all callers of omap_mux functions.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
There's no need to have these defines in plat/io.h.
Note that we now need to ifdef omap_read/write calls
as they will be available for omap1 only.
While at it, clean up the includes to group them like
they typically are grouped.
fbdev fixes for 3.3
It includes:
- compile fix for fsl-diu-fb
- fix for a suspend/resume issue in atmel_lcdfb
- fix for a suspend/resume issue in OMAP
- workaround for a hardware bug to avoid physical damage in OMAP
- really trivial dead code removal in intelfb
* tag 'fbdev-fixes-for-3.3-1' of git://github.com/schandinat/linux-2.6:
atmel_lcdfb: fix usage of CONTRAST_CTR in suspend/resume
intelfb: remove some dead code
drivers/video: compile fixes for fsl-diu-fb.c
OMAPDSS: HDMI: PHY burnout fix
OMAP: 4430SDP/Panda: add HDMI HPD gpio
OMAP: 4430SDP/Panda: setup HDMI GPIO muxes
OMAPDSS: remove wrong HDMI HPD muxing
OMAP: 4430SDP/Panda: rename HPD GPIO to CT_CP_HPD
OMAP: 4430SDP/Panda: use gpio_free_array to free HDMI gpios
OMAPDSS: use sync versions of pm_runtime_put
"hdmi_hpd" pin is muxed to INPUT and PULLUP, but the pin is not
currently used, and in the future when it is used, the pin is used as a
GPIO and is board specific, not an OMAP4 wide thing.
So remove the muxing for now.
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (175 commits)
module_param: make bool parameters really bool (drivers/video/i810)
Revert "atmel_lcdfb: Adjust HFP calculation so it matches the manual."
OMAPDSS: HDMI: Disable DDC internal pull up
OMAPDSS: HDMI: Move duplicate code from boardfile
OMAPDSS: add OrtusTech COM43H4M10XTC display support
OMAP: DSS2: Support for UMSH-8173MD TFT panel
ASoC: OMAP: HDMI: Move HDMI codec trigger function to generic HDMI driver
OMAPDSS: HDMI: Create function to enable HDMI audio
ASoC: OMAP: HDMI: Correct signature of ASoC functions
ASoC: OMAP: HDMI: Introduce driver data for audio codec
grvga: fix section mismatch warnings
video: s3c-fb: Don't keep device runtime active when open
video: s3c-fb: Hold runtime PM references when touching registers
video: s3c-fb: Take a runtime PM reference when unblanked
video: s3c-fb: Disable runtime PM in error paths from probe
video: s3c-fb: Use s3c_fb_enable() to enable the framebuffer
video: s3c-fb: Make runtime PM functional again
drivers/video: fsl-diu-fb: merge fsl_diu_alloc() into map_video_memory()
drivers/video: fsl-diu-fb: add default platform ops functions
drivers/video: fsl-diu-fb: remove broken reference count enabling the display
Disables the internal pull resistor for SDA and SCL which are enabled by
default, as there are external pull up's in 4460 and 4430 ES2.3
SDP, Blaze and Panda Boards, It is done to avoid the EDID read failure.
Signed-off-by: Ricardo Salveti de Araujo <ricardo.salveti@linaro.org>
Signed-off-by: Mythri P K <mythripk@ti.com>
