path: root/arch/arm/mach-omap2/mailbox.c
2011-03-10Merge branch 'for_2.6.39/pm-misc' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
2011-03-03omap: mailbox: resolve hang issueHari Kanigeri
omap4 interrupt disable bits is different. On rx kfifo full, the mbox rx interrupts wasn't getting disabled, and this is causing the rcm stress tests to hang. Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Signed-off-by: Armando Uribe <x0095078@ti.com> Signed-off-by: Fernando Guzman Lugo <fernando.lugo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-03-02Merge branches 'devel-iommu-mailbox', 'devel-mcbsp', 'devel-board' and ↵Tony Lindgren
'devel-hsmmc' into omap-for-linus Conflicts: arch/arm/mach-omap2/omap_hwmod_44xx_data.c
2011-03-02Merge branch 'devel-cleanup' into omap-for-linusTony Lindgren
Conflicts: arch/arm/mach-omap2/timer-gp.c
2011-02-24OMAP: mailbox: use runtime pm for clk and sysc handlingOmar Ramirez Luna
Use runtime pm APIs to enable/disable mailbox clocks and to configure SYSC register. Based on the patch sent by Felipe Contreras: https://patchwork.kernel.org/patch/101662/ Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-24OMAP: mailbox: build device using omap_device/omap_hwmodFelipe Contreras
Remove static platform_device and resource data within omap mailbox driver; use the one defined in the hwmod database along with omap_device framework for device build and registration. Add device latency functions to be used, so clock can be enabled and sysconfig is configured. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-14OMAP2420: mailbox: fix IVA vs DSP IRQ numberingKevin Hilman
The IRQ numbering for the IVA and DSP mailboxes was switched due to the wrong ordering in the OMAP2 mbox list. Switch the ordering so DSP is first and matches all the other SoCs. Tested on OMAP2420/n810. Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-27omap: Start using CONFIG_SOC_OMAPTony Lindgren
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest are nowadays just subcategories of these. Search and replace the following: ARCH_OMAP2420 SOC_OMAP2420 ARCH_OMAP2430 SOC_OMAP2430 ARCH_OMAP3430 SOC_OMAP3430 No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Sourav Poddar <sourav.poddar@ti.com>
2010-12-02OMAP: mailbox: fix detection for previously supported chipsOmar Ramirez Luna
Fix the mailbox detection for OMAP3630 and 2430, also minor cleanup on conditional ifdef's that could affect it. Given that 2430 has an iva too, include it, as the same steps for omap3 apply. Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-12-02OMAP: mailbox: remove unreachable returnOmar Ramirez Luna
Remove unreachable return statement. Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-09-28arm: remove cast from void*matt mooney
Unnecessary cast from void* in assignment. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04omap: mailbox: reorganize headersFelipe Contreras
Remove kernel.h and module.h since they are not used correctly anyway. Also, remove device.h since it comes along with platform_device.h (always will I guess). Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: standarize on 'omap-mailbox'Felipe Contreras
omap{1,2}-mailbox are modules that provide the 'omap-mailbox' driver. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: only compile for configured archsFelipe Contreras
2010-08-04omap: mailbox: simplify omap_mbox_register()Felipe Contreras
No need to dynamically register mailboxes one by one. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: reorganize registeringFelipe Contreras
It's more extensible this way. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: don't export unecessary symbolsFelipe Contreras
2010-08-04omap: mailbox: 2420 should be detected at run-timeFelipe Contreras
2010-08-04omap: mailbox: reorganize structuresFelipe Contreras
OMAP4 ones messed up the organization. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: trivial cleanupsFelipe Contreras
And fix a few compilation warnings. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox cleanup: split MODULE_AUTHOR lineOhad Ben-Cohen
use multiple MODULE_AUTHOR lines for multiple authors Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-03-11omap2/3/4: mailbox: remove compiler warningSuman Anna
Remove a compiler warning in device-specific mailbox module. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-23omap: mailbox: correct OMAP4 SIDLEMODE logicSuman Anna
OMAP4 mailbox has a different MAILBOX_SYSCONFIG register. There is now no AutoIdle. The SIDLEMODE bits have been right-shifted by 1 bit and now occupy bits 2 & 3. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-23omap: mailbox: correct OMAP4 reset logicSuman Anna
OMAP4 mailbox has a different register set. There is no MAILBOX_SYSSTATUS register. The reset is indicated with the SOFTRESET bit of the MAILBOX_SYSCONFIG register itself. This bit should read 0 for a successful Reset. Also, the SOFTRESET bit occupies bit0 and not bit1 as with previous generations. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2/3/4: mailbox: kill compile warning in mailbox.cFelipe Balbi
Change %d to %ld to avoid the compile warning. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: Adds code changes to support OMAP4 mailboxC A Subramaniam
This patch adds code changes in the mailbox driver module to add support for OMAP4 mailbox. Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Ramesh Gupta G <grgupta@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22Merge 7xx-iosplit-plat-merge with omap-fixesTony Lindgren
Merge branch '7xx-iosplit-plat-merge' into omap-for-linus
2009-11-10omap: Use resource_sizeTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one errors and actually fixes one in mailbox.c. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-28omap: Fix wrong condition check in while loop for mailbox and iommu2Hiroshi DOYU
It's worked fine so far since reset is done for the first time. Reported-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: mailbox: Flush posted write when acking mailbox irqHiroshi DOYU
The only way to flush posted write to L4 bus is to do a read back of the same register right after the write. This seems to be mostly needed in interrupt handlers to avoid causing spurious interrupts. The earlier fix has been to mark the L4 bus as strongly ordered memory, which solves the problem, but causes performance penalties. Similar to the fix, 03803a71041e3bc3c077f4e7b92f6ceaa9426df3 Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: mailbox: Execute softreset at startupHiroshi DOYU
The softreset at startup is introduced as TRM describes and also some register bit definitions are added instead of magic number. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-06-23OMAP2/3: omap mailbox: platform_get_irq() error ignoredRoel Kluin
platform_get_irq may return -ENXIO. but struct omap_mbox mbox_dsp_info.irq is unsigned, so the error was not noticed. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23omap mailbox: add save_/restore_ctx() for PMHiroshi DOYU
To preserve the registers during off-mode Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2009-03-23omap mailbox: fix empty struct device for omap2Hiroshi DOYU
2009-03-23omap mailbox: print hardware revision at startupHiroshi DOYU
2009-03-23omap mailbox: add initial omap3 supportHiroshi DOYU
2009-03-23omap mailbox: cleanup omap2 register definition with macroHiroshi DOYU
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Fix Unbalanced enable for IRQ in omap mailboxHiroshi DOYU
2007-05-09ARM: OMAP: Add mailbox support for IVAHiroshi DOYU
This patch adds a generic mailbox interface for for DSP and IVA (Image Video Accelerator). This patch itself doesn't contain any IVA driver. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
