Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
DRA7 uses OMAP5 IO table at the moment. This is purely spurious since
the OMAP5 and DRA7 register maps are different in many aspects.
AM57xx/DRA7 TRM Reference: http://www.ti.com/lit/ug/spruhz6/spruhz6.pdf
NOTE: Most of the drivers are already doing ioremap, so, there should'nt
be any functional improvement involved here, other than making the
initial iotable more accurate.
Fixes: a3a9384a1157 ("ARM: DRA7: Reuse io tables and add a new .init_early")
Signed-off-by: Nishanth Menon <nm@ti.com>
The IO descriptor tables for DRA7 are a complete reuse from OMAP5.
A new dra7xx_init_early() does the base address inits.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Update SAR RAM base address for OMAP5 based devices.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
These can now be moved to be local headers in mach-omap2.
Note that this patch removes arch/arm/plat-omap/devices.c as it
will get removed anyways with Paul Walmsley's patch
"ARM: OMAP: split OMAP1, OMAP2+ RNG device registration".
