path: root/arch/arm/mach-omap2
2010-08-16OMAP3: PM: ensure IO wakeups are properly disabledKevin Hilman
Commit 5a5f561 (convert OMAP3 PRCM macros to the _SHIFT/_MASK suffixes) mistakenly removed the check for PER when disabling the IO chain. During idle, if the PER powerdomain transitions into a lower state and CORE does not, the IO pad wakeups are not being disabled in the idle path after they are enabled. This can happen with the lower C-states when using CPUidle for example. This patch ensures that the check for disabling IO wakeups also checks for PER transitions, matching the check done to enable IO wakeups. Found when debugging PM/CPUidle related problems reported by Ameya Palande <ameya.palande@nokia.com>. Problems were triggered particularily on boards with UART2 consoles (n900, Overo) since UART2 is in the PER powerdomain. Tested on l-o master (omap3_defonfig + CONFIG_CPU_IDLE=y) as well as with current PM branch. Boards tested: n900, Overo, omap3evm. Cc: Paul Walmsley <paul@pwsan.com> Cc: Ameya Palande <ameya.palande@nokia.com> Tested-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated description to clarify the transistion] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-16omap: Use CONFIG_SMP for test_for_ipi and test_for_ltirqTony Lindgren
Otherwise we get the following error when enabling CONFIG_SMP for omap3_defconfig: arch/arm/kernel/entry-armv.S: Assembler messages: arch/arm/kernel/entry-armv.S:48: Error: bad instruction `test_for_ipi r0,r6,r5,lr' arch/arm/kernel/entry-armv.S:48: Error: bad instruction `test_for_ltirq r0,r6,r5,lr' arch/arm/kernel/entry-armv.S:48: Error: bad instruction `test_for_ipi r0,r6,r5,lr' arch/arm/kernel/entry-armv.S:48: Error: bad instruction `test_for_ltirq r0,r6,r5,lr' Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-08-16omap: Fix sev instruction usage for multi-omapTony Lindgren
Otherwise we get the following error with omap3_defconfig and CONFIG_SMP: Error: selected processor does not support `sev' Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-08-16OMAP3: Fix a cpu type check problemstanley.miao
cpu_is_omap3517() and cpu_is_omap3505() are the subgroups of cpu_is_omap34xx(), so we should check cpu_is_omap3517() and cpu_is_omap3505() first, then check cpu_is_omap34xx(). Otherwise, All AM35XX (Sitara) clocks do not get registered and device drivers (ti_hecc, etc...) that depend on those clocks are failing to get the clock and end up with non working device. Signed-off-by: Stanley.Miao <stanley.miao@windriver.com> Tested-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-16omap3: id: fix 3630 rev detectionNishanth Menon
Wrong placement of break causes all revisions of 3630 to be detected as 3630 es1.2, we need to break main loop if we have an identified chip, default falls through as in the rest of the switches in this function. Cc: Paul Walmsley <paul@pwsan.com> Cc: Sanjeev Premi <premi@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Manjunath K <manjugk@ti.com> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-11omap: pandora: pass wl1251 information to SDIO coreGrazvydas Ignotas
Pandora has TI WL1251 attached on MMC3, which is non-standard SDIO chip. Make use MMC_QUIRK_NONSTD_SDIO to tell SDIO core about it. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Bob Copeland <me@bobcopeland.com> Cc: Kalle Valo <kvalo@adurom.com> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Kishore Kadiyala <kishore.kadiyala@ti.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-08Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: (64 commits) OMAP: DSS2: OMAPFB: add support for FBIO_WAITFORVSYNC OMAP: DSS2: Replace strncmp() with sysfs_streq() in overlay_manager_store() OMAP: DSS2: Fix error path in omap_dsi_update() OMAP: DSS2: TDO35S: fix video signaling OMAP: DSS2: OMAPFB: Fix invalid bpp for PAL and NTSC modes OMAP: DSS2: OMAPFB: Fix probe error path OMAP3EVM: Replace vdvi regulator supply with vdds_dsi OMAP: DSS2: Remove extra return statement OMAP: DSS2: adjust YUV overlay width to be even OMAP: DSS2: OMAPFB: Fix sysfs mirror input check OMAP: DSS2: OMAPFB: Remove redundant color register range check OMAP: DSS2: OMAPFB: Remove redundant rotate range check OMAP: DSS2: OMAPFB: Check fb2display() return value OMAP: DSS2: Taal: Optimize enable_te, rotate, mirror when value unchanged OMAP: DSS2: DSI: detect unsupported update requests OMAP: DSS2: DSI: increase FIFO low threshold OMAP: DSS2: DSI: Add error IRQ mask for DSI complexIO OMAP: DSS2: DSI: Remove BTA after set_max_rx_packet_size OMAP: DSS2: change manual update scaling setup OMAP: DSS2: DSI: use BTA to end the frame transfer ...
2010-08-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (143 commits) omap: mailbox: reorganize headers omap: mailbox: standarize on 'omap-mailbox' omap: mailbox: only compile for configured archs omap: mailbox: simplify omap_mbox_register() omap: mailbox: reorganize registering omap: mailbox: add IRQ names omap: mailbox: remove unecessary fields omap: mailbox: don't export unecessary symbols omap: mailbox: update omap1 probing omap: mailbox: use correct config for omap1 omap: mailbox: 2420 should be detected at run-time omap: mailbox: reorganize structures omap: mailbox: trivial cleanups omap mailbox: Set a device in logical mbox instance for traceability omap: mailbox: convert block api to kfifo omap: mailbox: remove (un)likely macros from cold paths omap: mailbox cleanup: split MODULE_AUTHOR line omap: mailbox: convert rwlocks to spinlock Mailbox: disable mailbox interrupt when request queue Mailbox: new mutext lock for h/w mailbox configuration ...
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-05OMAP3EVM: Replace vdvi regulator supply with vdds_dsiVaibhav Hiremath
With recent changes happened in OMAP2/3 DSS library for regulator interface, it is required to define DSI regulator supply, without this DSS (in turn Fbdev) fails to get regulator. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2010-08-05Merge branch 'topic/asoc' into for-linusTakashi Iwai
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-04Merge branch 'v2.6.35-omap-mailbox-for-next' of ↵Tony Lindgren
git://gitorious.org/~doyu/lk/mainline into omap-for-linus Conflicts: arch/arm/mach-omap1/devices.c
2010-08-04omap: mailbox: reorganize headersFelipe Contreras
Remove kernel.h and module.h since they are not used correctly anyway. Also, remove device.h since it comes along with platform_device.h (always will I guess). Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: standarize on 'omap-mailbox'Felipe Contreras
omap{1,2}-mailbox are modules that provide the 'omap-mailbox' driver. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: only compile for configured archsFelipe Contreras
2010-08-04omap: mailbox: simplify omap_mbox_register()Felipe Contreras
No need to dynamically register mailboxes one by one. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: reorganize registeringFelipe Contreras
It's more extensible this way. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: add IRQ namesFelipe Contreras
Will be useful to identify them later. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: don't export unecessary symbolsFelipe Contreras
2010-08-04omap: mailbox: 2420 should be detected at run-timeFelipe Contreras
2010-08-04omap: mailbox: reorganize structuresFelipe Contreras
OMAP4 ones messed up the organization. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: trivial cleanupsFelipe Contreras
And fix a few compilation warnings. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox cleanup: split MODULE_AUTHOR lineOhad Ben-Cohen
use multiple MODULE_AUTHOR lines for multiple authors Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: 3630: disable TLL SAR on 3630 ES1Anand Gadiyar
USBTLL Save-and-Restore is broken in 3630 ES1.0. Having it enabled could result in incorrect register restores as the OMAP exits off-mode. This could potentially result in unexpected wakeup events. (Refer 3630 errata ID i579) This is fixed in ES1.1. So disable it for ES1.0s. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04OMAP3630: Add ES1.1 and ES1.2 detectionAnand Gadiyar
Add revision detection for ES1.1 and ES1.2. Set default revision as ES1.2. Add CHIP_GE_OMAP3630ES1_1 to detect revisions 1.1 and later. This is needed for at least one feature that is broken in 3630ES1.0 but exists on older (3430 ES3.1) and newer revisions. Additionally, update some of the CHIP_GE_* macros to use other macros for ease of maintenance. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: Manjunatha GK <manjugk@ti.com> [tony@atomide.com: update to remove fallthrough handling] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04Merge branch 'devel-map-io' into omap-for-linusTony Lindgren
2010-08-04omap3: introduce omap3_map_ioMike Rapoport
Most OMAP3-based boards use exactly the same code for .map_io method in the machine_desc structure. This patch introduces omap3_map_io and updates board-* files to use it as .map_io method. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04omap3: Unify omap2_set_globals_3[43,6x]x functionsSergio Aguirre
The only difference between them is the physical address of the uart4 port, which is only present in 36xx chips. We don't really need to care about keeping these 2 functions, since the decision to use uart4 is more cleanly done later when we do have access to omap_revision variable. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: added comment for the uart4_phys] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04omap: Fix DEBUG_LL uart to access phys addr when MMU isn't enableJason Wang
Now we use a memory address to store the debug port info, So we need to read/write this address when we choose DEBUG_LL. When MMU isn't enable(I.E. the begining part of init stage of the linux kernel boot), we need to access physical address instead of virtual address, otherwise the kernel will crash. Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-04Merge branch 'for_2.6.36' of git://git.pwsan.com/linux-2.6 into omap-for-linusTony Lindgren
2010-08-03OMAP2: powerdomain: Add break in switch statementThomas Weber
Add a missing break at end of switch statement. At the moment it is a fall through to WARN_ON(1) and return -EEXIST. Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3: add support for NAND on LDP boardSukumar Ghorai
patch adds NAND support to LDP board. Signed-off-by: Vimal Singh <vimalsingh@ti.com> Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap-3630-sdp : Add support for FlashSukumar Ghorai
add support for NAND, OneNAND, NOR on omap 3630-sdp board. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3: add support for NAND on zoom3 boardSukumar Ghorai
patch adds NAND support to zoom3 board. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Vimal Singh <vimalsingh@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3: add support for NAND on zoom2 boardSukumar Ghorai
This patch adds NAND support to ZOOM2 board. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Vimal Singh <vimalsingh@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3 flash: rename board-sdp-flash.c to be use by other boardsSukumar Ghorai
rename board-sdp-flash.c(board-flash.c) and board-sdp.h(board-flash.h) to used by other board e.g. zoom Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3 nand: fix issue in board file to detect nandSukumar Ghorai
Board file modified for not to provide gpmc phys_base address to nand driver. The gpmc_nand_init funciton is now used to detect the nand and required to adopt _prob function as in nand/omap2.c Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3 nand: cleanup virtual address usagesSukumar Ghorai
This patch removes direct reference of gpmc address from generic nand platform code. Nand platform code now uses wrapper functions which are implemented in gpmc module. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap3 gpmc: functionality enhancementSukumar Ghorai
few functions added in gpmc module and to be used by other drivers like NAND. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02Merge branch 'devel-misc' into omap-for-linusTony Lindgren
2010-08-02omap: mux: fix multipath gpio handlingGrazvydas Ignotas
OMAP3530 CBB package can have GPIO126 muxed on 2 pins: mmc1_dat4 and cam_strobe. This causes a problem with current multipath GPIO mux handling, which muxes both pins as GPIO126 and makes the GPIO unusable. Fix this by not muxing any pins if multipath GPIO is detected and just print a warning instead. It's up to board files to set correct mux using omap_mux_init_signal and pin name. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap: Devkit8000: Use DIE id to initialize dm9000 MAC addressKan-Ru Chen
The devkit8000 boards often come with empty EEPROM thus without valid ethernet MAC address. The DIE id to MAC formula is copied from u-boot. Signed-off-by: Kan-Ru Chen <kanru@0xlab.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap: Use omap_get_die_id() to get the DIE idsKan-Ru Chen
2010-08-02omap: Add new interface omap_get_die_idKan-Ru Chen
Allow DIE id to be get and used by others. Signed-off-by: Kan-Ru Chen <kanru@0xlab.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02OMAP3: AM3505/3517 do not have IO wakeup capabilitystanley.miao
AM3505/3517 doesn't have IO wakeup capability, so we do not need to set the bit OMAP3430_EN_IO and the bit OMAP3430_EN_IO_CHAIN in the register PM_WKEN_WKUP when the system enters suspend state. Tested on AM3517EVM and OMAP3530EVM. Signed-off-by: Stanley.Miao <stanley.miao@windriver.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap2/3: id: fix sparse warningNishanth Menon
omap24xx_check_revision, omap3_check_features, omap3_check_revision, omap4_check_revision, omap3_cpuinfo are not used elsewhere, it should be static Also fixes the following sparse warnings: arch/arm/mach-omap2/id.c:105:13: warning: symbol 'omap24xx_check_revision' was not declared. Should it be static? arch/arm/mach-omap2/id.c:167:13: warning: symbol 'omap3_check_features' was not declared. Should it be static? arch/arm/mach-omap2/id.c:189:13: warning: symbol 'omap3_check_revision' was not declared. Should it be static? arch/arm/mach-omap2/id.c:270:13: warning: symbol 'omap4_check_revision' was not declared. Should it be static? arch/arm/mach-omap2/id.c:300:13: warning: symbol 'omap3_cpuinfo' was not declared. Should it be static? Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap: Overo: Fix support for second ethernet portSteve Sakoman
The original patch got truncated when applied from patchwork.kernel.org as discussed at: http://www.mail-archive.com/linux-omap@vger.kernel.org/msg28953.html This patch supplies the missing chunks. Signed-off-by: Steve Sakoman <sakoman@gmail.com> [tony@atomide.com: added more info to the patch description] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap2: Fix GPIO numbers and smc91x for 2430sdpTony Lindgren
Fix GPIO numbers and smc91x for 2430sdp. The earlier code had cut and paste errors from 3430sdp code. Also, 2430 has five GPIO banks for a total of 160 GPIO lines. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-08-02omap4: hotplug: Add basic CPU hotplug supportSantosh Shilimkar
This patch adds cpu hotplug support for OMAP4430. Only CPU inactive state is supported as a low power state in the basic hot-plug support Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
