Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Convert to the new function names. Automated with coccinelle.
This patch makes the various mach dirs that use the plat-orion time
code pass in timer and bridge addresses explicitly, instead of having
plat-orion get those values by including a mach dir include file --
the latter mechanism is problematic if you want to support multiple
ARM platforms in the same kernel image.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Currently, there are two different fields in the
mv643xx_eth_platform_data struct that together describe the PHY
address -- one field (phy_addr) has the address of the PHY, but if
that address is zero, a second field (force_phy_addr) needs to be
set to distinguish the actual address zero from a zero due to not
having filled in the PHY address explicitly (which should mean
'use the default PHY address').
If we are a bit smarter about the encoding of the phy_addr field,
we can avoid the need for a second field -- this patch does that.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This patch performs the equivalent include directory shuffle for
plat-orion, and fixes up all users.
This just leaves include/asm-arm/plat-* to deal with.
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1].
Remove them completely. Sed script for the reference:
s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g
s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g
s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g
s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g
s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g
s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g
s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g
s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g
s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g
s/IRQT_PROBE/IRQ_TYPE_PROBE/g
s/IRQT_NOEDGE/IRQ_TYPE_NONE/g
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Nuke the Orion-specific orion5x_{read,write} wrappers.
The mv643xx_eth platform data field ->force_phy_addr only needs
to be set if the passed-in ->phy_addr field is zero (to distinguish
the case of not having specified a phy address
(force_phy_addr = 0) from the case where a phy address of zero needs
to be used (force_phy_addr = 1.))
Also, the ->force_phy_addr field will hopefully disappear in a
future mv643xx_eth reorganisation.
Therefore, this patch deletes the ->force_phy_addr field initialiser
from all Orion board code.
Instead of having board code poke directly into the MPP configuration
registers, and separately calling orion5x_gpio_set_valid_pins() to
indicate which MPP pins can be used as GPIO pins, introduce a helper
function for configuring the roles of each of the MPP pins, and have
that helper function handle gpio validity internally.
Acked-by: Sylver Bruneau <sylver.bruneau@googlemail.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
This patch moves initialisation of EHCI/I2C/UART platform devices
from the common orion5x_init() into the board support code.
The rationale behind this is that only the board support code knows
whether certain peripherals have been brought out on the board, and
not initialising peripherals that haven't been brought out is
desirable for example:
- to reduce user confusion (e.g. seeing both 'eth0' and 'eth1'
appear while there is only one ethernet port on the board); and
- to allow for future power savings (peripherals that have not
been brought out can be clock gated off entirely).
More cosmetic cleanup:
- Replace 8-space indents by proper tab indents.
- In structure initialisers, use a trailing comma for every member.
- Collapse "},\n{" in structure initialiers to "}, {".
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits)
[ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945b
[ARM] serial: s3c2410: platform_get_irq() may return signed unnoticed
[ARM] am79c961a: platform_get_irq() may return signed unnoticed
[ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page()
[ARM] Feroceon: fix function alignment in proc-feroceon.S
[ARM] Orion: catch a couple more alternative spellings of PCIe
[ARM] Orion: fix orion-ehci platform resource end addresses
[ARM] Orion: fix ->map_irq() PCIe bus number check
[ARM] Orion: fix ioremap() optimization
[ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN check
[ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH check
kprobes/arm: fix decoding of arithmetic immediate instructions
kprobes/arm: fix cache flush address for instruction stub
[ARM] 5022/1: Race in ARM MMCI PL18x driver, V2
[ARM] 5021/1: at91: buildfix for sam9263 + PM
[ARM] 5018/1: RealView: Fix the ARM11MPCore Oprofile compilation
[ARM] 5016/1: AT91: typo in mci configuration for at91cap at91sam9263
[ARM] 5017/1: pxa3xx: Report unsupported wakeup sources in pxa3xx_set_wake()
[ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_info
[ARM] 5014/1: Cleanup reset state before entering suspend or resetting.
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
The current orion5x board ->map_irq() routines check whether a
given bus number lives on the PCIe controller by comparing it with
the PCIe controller's primary bus number. This doesn't work in
case there are multiple buses in the PCIe domain, i.e. if there
exists a PCIe bridge on the primary PCIe bus.
This patch adds a helper function (orion5x_pci_map_irq()) that
returns the IRQ number for the given PCI device if that device has
a hard-wired IRQ, or -1 otherwise, and makes each board's
->map_irq() function use this helper function.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Do a global s/orion/orion5x/ of the Orion 5x-specific bits (i.e.
not the plat-orion bits.)
Reviewed-by: Tzachi Perelstein <tzachi@marvell.com>
Acked-by: Saeed Bishara <saeed@marvell.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
