path: root/arch/arm/mach-orion5x/ls-chl-setup.c
2011-05-16ARM: orion5x: Refactor mpp code to use common orion platform mpp.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-12-07[ARM] Orion: added Buffalo LS-CHL supportAsh Hughes
Adds support for Buffalo Linkstation Live v3 (LS-CHL) NAS drives. Signed-off-by: Ash Hughes <ashley.hughes@blueyonder.co.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
