During the refactoring of the Orion MPP code, the detection for
the 5181l as been used to select the 5181 MPP mask, which is wrong.
Select the 5181 mask for all 5181 variants.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
This patch makes the various mach dirs that use the plat-orion GPIO
code pass in GPIO-related platform info (GPIO controller base address,
secondary base IRQ number, etc) explicitly, instead of having
plat-orion get those values by including a mach dir include file --
the latter mechanism is problematic if you want to support multiple
ARM platforms in the same kernel image.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Wrong MPP configuration would cause <cpu>_mpp_conf loop infinitely
because the mpp list iterator would not be incremented.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Erik Benada <erikbenada@yahoo.ca>
[ nico: fix locking, additional cleanups ]
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Split off Orion GPIO handling code into plat-orion/, and add
support for multiple sets of (32) GPIO pins.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Instead of having board code poke directly into the MPP configuration
registers, and separately calling orion5x_gpio_set_valid_pins() to
indicate which MPP pins can be used as GPIO pins, introduce a helper
function for configuring the roles of each of the MPP pins, and have
that helper function handle gpio validity internally.
Acked-by: Sylver Bruneau <sylver.bruneau@googlemail.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
