path: root/arch/arm/mach-orion5x/ts78xx-setup.c
2011-05-16ARM: orion5x: Refactor mpp code to use common orion platform mpp.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-06ARM: orion5x: replace printk with pr_{err,info,...} in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: fix compiler cast warnings in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> [np: used min_t() as suggested by Sergei Shtylyov <sshtylyov@mvista.com>] Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: use safer FPGA ID 'default' for TS-78xxAlexander Clouter
Originally the FPGA ID checking switch statement left disabled all the TS implemented FPGA devices if the ID was unknown to it. Michael Spang created a fix in f9b1184e that changed the default to enable the devices in the event TS silently release more revisions into the wild, this unfortunately breaks custom FPGA bitstreams. This patch amends the switch statement so that the TS devices are only enabled if on the revision number is unknown (whilst the magic matches). Changelog: v2: neater implementation and some cosmetic changes v1: initial release <20110305112937.GA22117@chipmunk> Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-04ARM: Enable TS-78XX features in unknown revisionsMichael Spang
When the manufacturer increases the revision number the platform devices for the RTC, NAND, and RNG disappear. We should assume new revisions have these devices instead of assuming they do not. Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] update FPGA revisions for TS-7800Alexander Clouter
New FPGA revisions have been released and seen in the wild on the platform, so it's time to update the list. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] orion5x: accelerate NAND on the TS-78xxAlexander Clouter
The NAND supports 32bit reads and writes so lets stop shunting 8bit chunks across the bus. Doing a dumb 'dd' benchmark, this increases performance roughly like so: * read: 1.3MB/s to 3.4MB/s * write: 614kB/s to 882kB/s Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orionRussell King
2010-11-05[ARM] TS-78xxx NAND resource type should be IORESOURCE_MEMMichael Spang
The type was IORESOURCE_IO which is not what is expected by plat_nand_probe(). This device has not worked since 2d098a72 ("mtd: plat_nand: request memory resource before doing ioremap"). Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-12ARM: Fix gen_nand probe structures contentsMarek Vasut
These three platforms didn't properly fill nr_chips in gen_nand registration and therefore depended on gen_nand bug fixed by commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for multiple chips") Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-03[ARM] orion: add hwrng timeriomem hook to TS-78xxAlexander Clouter
Add hook so that the HW RNG source on the TS-78xx is available. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-23[ARM] orion5x: update of FPGA ID's for the TS-78xxAlexander Clouter
Received official word finally from Technological Systems on which FPGA ID's they have released unto the world. Also an additional of a dummy entry matching the FPGA ID of the Verilog template on our wiki. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-04[ARM] orion5x: added a new FPGA ID set for the TS-78xxAlexander Clouter
Stefan Agner found his board comes with 0x00b480/0x02 but the main board also has Rev B printed on it like my 0x00b480/0x03. Some light enum renaming was needed but it was to be expected. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-02-25[ARM] orion5x: ts78xx add NAND support via plat_nandAlexander Clouter
ts78xx add NAND support via plat_nand Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@cam.org>
2009-02-25[ARM] orion5x: ts78xx amend RTC registering to not depend on ifdef'sAlexander Clouter
amend RTC registering to not depend on ifdef's Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@cam.org>
2009-02-24[ARM] orion5x: ts78xx make more bulletproof the RTC load/unload codeAlexander Clouter
Added checks to the platform_device_(register|add) calls so that if a device failed to load it would then not later be unloaded; also added the hooks so that it would not try to unload when the RTC driver support is compiled out. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@cam.org>
2009-02-06[ARM] orion5x: TS-78xx support for 'hotplug' of FPGA devicesAlexander Clouter
the FPGA on the TS-7800 provides access to a number of devices and so we have to be careful when reprogramming it. As we are effectively turning a bus off/on we have to inform the kernel that it should stop using anything provided by the FPGA (currently only the RTC however the NAND, LCD, etc is to come) before it's reprogrammed. Once reprogramed, we can tell the kernel to (re)enable things by checking the FPGA ID against a lookup table for what a particular FPGA bitstream can provide. Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
2009-02-06[ARM] orion5x: TS-78xx comment shiftingAlexander Clouter
moved the MPP comments to the mpp area of the platform code Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
2009-02-06[ARM] orion5x: remove TS-78xx NOR support as it does not existAlexander Clouter
The TS-7800's M25P40 is not available to the kernel, it's used to load the initial bitstream onto the FPGA and so these hooks point to nothing and need to be removed. Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
2008-09-05mv643xx_eth: remove force_phy_addr fieldLennert Buytenhek
Currently, there are two different fields in the mv643xx_eth_platform_data struct that together describe the PHY address -- one field (phy_addr) has the address of the PHY, but if that address is zero, a second field (force_phy_addr) needs to be set to distinguish the actual address zero from a zero due to not having filled in the PHY address explicitly (which should mean 'use the default PHY address'). If we are a bit smarter about the encoding of the phy_addr field, we can avoid the need for a second field -- this patch does that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: Instantiate mv_xor driver for 5182Saeed Bishara
Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-22[ARM] Orion: add Technologic Systems TS-78xx supportAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
