"Input: add KEY_WPS_BUTTON definition" introduced
a generic keycode for WPS input events.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
arch/arm/mach-mx2/devices.c
arch/arm/mach-mx2/devices.h
sound/soc/pxa/pxa-ssp.c
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
Makes it consistent with VMALLOC_START
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
This patch fixes the power LED on DNS-323 revision A1, and adds timer
support for (hopefully) both A1 and B1 revisions.
Power LED on revision A1 is active low and also requires GPIO 4 to be
low to work.
Tested on my DNS-323 revision A1.
I have set the default trigger to timer as that replicates the
behaviour of the original firmware, userspace can change the trigger
at the end of the boot process providing a useful indication that
booting has completed.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
This patch allow user-space to configure the switch power-off behaviour
via the gpiolib sysfs interface.
... and replace misuse of arch_reset() with arm_machine_restart().
Signed-off-by: Zhu Qingsen <zhuqs@cn.fujitsu.com>
The (void *) cast is not needed when setting dev.platform_data to the
address of the data. Remove the casts.
Cc: Lennert Buytenhek <buytenh@marvell.com>
This patch fixes power LED blinking and power-off on DNS-323 rev. B1.
GPIO pin 3 has to be set to 1 to stop power LED blinking and to allow the LED to be controlled via leds-gpio. This pin has to be also set to 1 for power-off to work.
To power-off the rev. B1 machine, pin 8 has to be set to 1 and then set to 0 to do actual power-off.
Tested on my DNS-323 rev. B1
Signed-off-by: Erik Benada <erikbenada@yahoo.ca>
Signed-off-by: Dirk Teurlings <dirk@upexia.nl>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
This patch add support for the 2Big Network LaCie boards.
On the 88f6183, orion5x's setup_cpu_win() fails to ever program any
mbus bridge remap registers, which causes transactions for PCI/PCIe
IO/MEM space to get sent to random mbus targets. Adding a check for
the 6183 in orion5x_cpu_win_can_remap() is necessary and sufficient
to make PCIe wlan cards work on the 6183 reference design.
This patch add support for the d2 Network and the Big Disk Network
LaCie boards.
Acked-by: Christopher Moore <moore@free.fr>
Not all Orion variants do implement the crypto unit.
Without incrementing the counter the next window setup will overwrite
the SRAM mapping.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
The security accelerator which can act as a puppet player for the crypto
engine requires its commands in the sram. This patch adds support for the
phys mapping and creates a platform device for the actual driver.
[ nico: renamed device name from "mv,orion5x-crypto" to "mv_crypto"
so to match the module name and be more generic for Kirkwood use ]
This patch adds support for the switch found on the Netgear
WNR854T router.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
The Orion watchdog driver is also used on Kirkwood.
Convention is to use orion5x for stuff specific to 88F5xxx Orion chips
and simply "orion" for shared stuff across SoCs including Kirkwood.
The name of the define for the Reset-Out-Mask register as well as its
bit for the watchdog reset are changed to match the names used for
Kirkwood (which in turn match the processor specification more
closely). There is no functional change.
This patch prepares for adding orion5x_wdt as a platform device to
Kirkwood.
Signed-off-by: Thomas Reitmayr <treitmayr@devbase.at>
[ nico: fix locking, additional cleanups ]
Add hook so that the HW RNG source on the TS-78xx is available.
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
Since commit eb0519b5a1cf, mv643xx_eth is non functional on ARM because
the platform device declaration does not include any coherent DMA mask
and coherent memory allocations fail.
Remove explicit names from platform device resources since they will
automatically be named after the platform device they're associated
with.
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
Symbols like SOFT_RESET are way too generic to be exported at large.
To avoid this, let's move the mbus bridge register defines into a
separate file and include it where needed. This affects mach-kirkwood,
mach-loki, mach-mv78xx0 and mach-orion5x simultaneously as they all
share code in plat-orion which relies on those defines.
Some other defines have been moved to narrower scopes, or simply deleted
when they had no user.
This fixes compilation problem with mpt2sas on the above listed
platforms.
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
sound/soc/pxa/pxa2xx-i2s.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1750 commits)
ixgbe: Allow Priority Flow Control settings to survive a device reset
net: core: remove unneeded include in net/core/utils.c.
e1000e: update version number
e1000e: fix close interrupt race
e1000e: fix loss of multicast packets
e1000e: commonize tx cleanup routine to match e1000 & igb
netfilter: fix nf_logger name in ebt_ulog.
netfilter: fix warning in ebt_ulog init function.
netfilter: fix warning about invalid const usage
e1000: fix close race with interrupt
e1000: cleanup clean_tx_irq routine so that it completely cleans ring
e1000: fix tx hang detect logic and address dma mapping issues
bridge: bad error handling when adding invalid ether address
bonding: select current active slave when enslaving device for mode tlb and alb
gianfar: reallocate skb when headroom is not enough for fcb
Bump release date to 25Mar2009 and version to 0.22
r6040: Fix second PHY address
qeth: fix wait_event_timeout handling
qeth: check for completion of a running recovery
qeth: unregister MAC addresses during recovery.
Manually fixed up conflicts in:
drivers/infiniband/hw/cxgb3/cxio_hal.h
drivers/infiniband/hw/nes/nes_nic.c
drivers/net/wimax/i2400m/usb-notif.c
The orion5x-wdt driver is now registered as a platform device and
receives the tclk value as platform data. This fixes a compile issue
cause by a previously removed define "ORION5X_TCLK".
Acked-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Kristof Provost <kristof@sigsegv.be>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Sylver Bruneau <sylver.bruneau@googlemail.com>
Cc: Kunihiko IMAI <bak@d2.dion.ne.jp>
Received official word finally from Technological Systems on which
FPGA ID's they have released unto the world. Also an additional of
a dummy entry matching the FPGA ID of the Verilog template on our
wiki.
The initial version of the DSA driver only supported a single switch
chip per network interface, while DSA-capable switch chips can be
interconnected to form a tree of switch chips. This patch adds support
for multiple switch chips on a network interface.
An example topology for a 16-port device with an embedded CPU is as
follows:
| |eth0 10| switch |9 10| switch |
| CPU +----------+ +-------+ |
| | | chip 0 | | chip 1 |
||1000baseT ||1000baseT
||ports 1-8 ||ports 9-16
This requires a couple of interdependent changes in the DSA layer:
- The dsa platform driver data needs to be extended: there is still
only one netdevice per DSA driver instance (eth0 in the example
above), but each of the switch chips in the tree needs its own
mii_bus device pointer, MII management bus address, and port name
array. (include/net/dsa.h) The existing in-tree dsa users need
some small changes to deal with this. (arch/arm)
- The DSA and Ethertype DSA tagging modules need to be extended to
use the DSA device ID field on receive and demultiplex the packet
accordingly, and fill in the DSA device ID field on transmit
according to which switch chip the packet is heading to.
(net/dsa/tag_{dsa,edsa}.c)
- The concept of "CPU port", which is the switch chip port that the
CPU is connected to (port 10 on switch chip 0 in the example), needs
to be extended with the concept of "upstream port", which is the
port on the switch chip that will bring us one hop closer to the CPU
(port 10 for both switch chips in the example above).
- The dsa platform data needs to specify which ports on which switch
chips are links to other switch chips, so that we can enable DSA
tagging mode on them. (For inter-switch links, we always use
non-EtherType DSA tagging, since it has lower overhead. The CPU
link uses dsa or edsa tagging depending on what the 'root' switch
chip supports.) This is done by specifying "dsa" for the given
port in the port array.
- The dsa platform data needs to be extended with information on via
which port to reach any given switch chip from any given switch chip.
This info is specified via the per-switch chip data struct ->rtable[]
array, which gives the nexthop ports for each of the other switches
in the tree.
For the example topology above, the dsa platform data would look
something like this:
static struct dsa_chip_data sw[2] = {
.mii_bus = &foo,
.sw_addr = 1,
.port_names[0] = "p1",
.port_names[1] = "p2",
.port_names[2] = "p3",
.port_names[3] = "p4",
.port_names[4] = "p5",
.port_names[5] = "p6",
.port_names[6] = "p7",
.port_names[7] = "p8",
.port_names[9] = "dsa",
.port_names[10] = "cpu",
.rtable = (s8 []){ -1, 9, },
.mii_bus = &foo,
.sw_addr = 2,
.port_names[0] = "p9",
.port_names[1] = "p10",
.port_names[2] = "p11",
.port_names[3] = "p12",
.port_names[4] = "p13",
.port_names[5] = "p14",
.port_names[6] = "p15",
.port_names[7] = "p16",
.port_names[10] = "dsa",
.rtable = (s8 []){ 10, -1, },
static struct dsa_platform_data pd = {
.netdev = &foo,
.nr_switches = 2,
.sw = sw,
Tested-by: Gary Thomas <gary@mlbassoc.com>
arch/arm/mach-mx1/devices.c
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
Fix some typos in the DNS-323 support code.
Stefan Agner found his board comes with 0x00b480/0x02 but the main
board also has Rev B printed on it like my 0x00b480/0x03. Some light
enum renaming was needed but it was to be expected.
This data should be passed to the xor driver in order to initialize
the address decoding windows of the xor unit. without this patch, the
self tests of the xor will fail unless the address decoding windows were
initialized by the boot loader.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
ts78xx add NAND support via plat_nand
Signed-off-by: Nicolas Pitre <nico@cam.org>
amend RTC registering to not depend on ifdef's
Added checks to the platform_device_(register|add) calls so that if
a device failed to load it would then not later be unloaded; also
added the hooks so that it would not try to unload when the RTC
driver support is compiled out.
The GPIO interrupts can be configured as either level triggered or edge
triggered, with a default of level triggered. When an edge triggered
interrupt is requested, the gpio_irq_set_type method is called which
currently switches the given IRQ descriptor between two struct irq_chip
instances: orion_gpio_irq_level_chip and orion_gpio_irq_edge_chip. This
happens via __setup_irq() which also calls irq_chip_set_defaults() to
assign default methods to uninitialized ones. The problem is that
irq_chip_set_defaults() is called before the irq_chip reference is
switched, leaving the new irq_chip (orion_gpio_irq_edge_chip in this
case) with uninitialized methods such as chip->startup() causing a kernel
oops.
Many solutions are possible, such as making irq_chip_set_defaults() global
and calling it from gpio_irq_set_type(), or calling __irq_set_trigger()
before irq_chip_set_defaults() in __setup_irq(). But those require
modifications to the generic IRQ code which might have adverse effect on
other architectures, and that would still be a fragile arrangement.
Manually copying the missing methods from within gpio_irq_set_type()
would be really ugly and it would break again the day new methods with
automatic defaults are added.
A better solution is to have a single irq_chip instance which can deal
with both edge and level triggered interrupts. It is also a good idea
to switch the IRQ handler instead, as the edge IRQ handler allows for
one edge IRQ event to be queued as the IRQ is actually masked only when
that second IRQ is received, at which point the hardware can queue an
additional IRQ event, making edge triggered interrupts a bit more
reliable.
Tested-by: Martin Michlmayr <tbm@cyrius.com>
the FPGA on the TS-7800 provides access to a number of devices
and so we have to be careful when reprogramming it. As we
are effectively turning a bus off/on we have to inform the
kernel that it should stop using anything provided by the
FPGA (currently only the RTC however the NAND, LCD, etc is
to come) before it's reprogrammed.
Once reprogramed, we can tell the kernel to (re)enable things
by checking the FPGA ID against a lookup table for what a
particular FPGA bitstream can provide.
