path: root/arch/arm/mach-prima2
2011-09-11ARM: CSR: add missing sentinels to of_device_id tablesJamie Iles
The of_device_id tables used for matching should be terminated with empty sentinel values. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Barry Song <baohua.song@csr.com>
2011-07-09ARM: CSR: initializing L2 cacheRongjun Ying
Signed-off-by: Rongjun Ying <rongjun.ying@csr.com> Signed-off-by: Barry Song <baohua.song@csr.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-09ARM: CSR: mapping early DEBUG_LL uartBarry Song
2011-07-09ARM: CSR: Adding CSR SiRFprimaII board supportBinghua Duan
SiRFprimaII is the latest generation application processor from CSR’s Multifunction SoC product family. Designed around an ARM cortex A9 core, high-speed memory bus, advanced 3D accelerator and full-HD multi-format video decoder, SiRFprimaII is able to meet the needs of complicated applications for modern multifunction devices that require heavy concurrent applications and fluid user experience. Integrated with GPS baseband, analog and PMU, this new platform is designed to provide a cost effective solution for Automotive and Consumer markets. This patch adds the basic support for this SoC and EVB board based on device tree. It is following the ZYNQ of Xilinx in some degree. Signed-off-by: Binghua Duan <Binghua.Duan@csr.com> Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com> Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com> Signed-off-by: Yuping Luo <Yuping.Luo@csr.com> Signed-off-by: Bin Shi <Bin.Shi@csr.com> Signed-off-by: Huayi Li <Huayi.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
