commit 02b4e2756e01c623cc4dbceae4b07be75252db5b upstream.
All ARMv5 and older CPUs invalidate their caches in the early assembly
setup function, prior to enabling the MMU. This is because the L1
cache should not contain any data relevant to the execution of the
kernel at this point; all data should have been flushed out to memory.
This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed,
these typically do not search their caches when caching is disabled (as
it needs to be when the MMU is disabled) so this change should be safe.
ARMv7 allows there to be CPUs which search their caches while caching is
disabled, and it's permitted that the cache is uninitialised at boot;
for these, the architecture reference manual requires that an
implementation specific code sequence is used immediately after reset
to ensure that the cache is placed into a sane state. Such
functionality is definitely outside the remit of the Linux kernel, and
must be done by the SoC's firmware before _any_ CPU gets to the Linux
kernel.
Changing the data cache clean+invalidate to a mere invalidate allows us
to get rid of a lot of platform specific hacks around this issue for
their secondary CPU bringup paths - some of which were buggy.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
Cc: Alexander Kochetkov <al.kochet@gmail.com>
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const structs in arch/arm as const, too.
While at it also add some __initconst annotations.
Acked-by: Jason Cooper <jason@lakedameon.net>
The definition
static const char *axxia_dt_match[] __initconst = {
defines a changable array of constant strings. That is you must not do:
*axxia_dt_match[0] = 'k';
but
axxia_dt_match[0] = "different string";
is fine. So the annotation __initconst is wrong and yields a compiler
error when other really const variables are added with __initconst.
As the struct machine_desc member dt_compat is declared as
const char *const *dt_compat;
making the arrays const is the better alternative over changing all
annotations to __initdata.
The new Atlas7 platform implicitly selects 'CONFIG_SMP_ON_UP',
which leads to problems if we enable building the platform without
MMU, as that combination is not allowed and causes a link error:
arch/arm/kernel/built-in.o: In function `c_show':
:(.text+0x1872): undefined reference to `smp_on_up'
:(.text+0x1876): undefined reference to `smp_on_up'
arch/arm/kernel/built-in.o: In function `arch_irq_work_raise':
:(.text+0x3d48): undefined reference to `smp_on_up'
:(.text+0x3d4c): undefined reference to `smp_on_up'
arch/arm/kernel/built-in.o: In function `smp_setup_processor_id':
:(.init.text+0x180): undefined reference to `smp_on_up'
This removes the 'select' statement.
Fixes: 4cba058526a7 ("ARM: sirf: add Atlas7 machine support")
Acked-by: Barry Song <Baohua.Song@csr.com>
Cc: Zhiwu Song <Zhiwu.Song@csr.com>
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Also included are some cleanups where
the platform maintainers hadn't separated cleanups from new developent
in separate branches.
Some of the larger things worth pointing out:
- A large set of changes from Alexandre Belloni and Nicolas Ferre
preparing at91 platforms for multiplatform and cleaning up quite a
bit in the process.
- Removal of CSR's "Marco" SoC platform that never made it out to the
market. We love seeing these since it means the vendor published
support before product was out, which is exactly what we want!
New platforms this release are:
- Conexant Digicolor (CX92755 SoC)
- Hisilicon HiP01 SoC
- CSR/sirf Atlas7 SoC
- ST STiH418 SoC
- Common code changes for Nvidia Tegra132 (64-bit SoC)
We're seeing more and more platforms having a harder time labelling
changes as cleanups vs new development -- which is a good sign that
we've come quite far on the cleanup effort. So over time we might
start combining the cleanup and new-development branches more"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits)
ARM: at91/trivial: unify functions and machine names
ARM: at91: remove at91_dt_initialize and machine init_early()
ARM: at91: change board files into SoC files
ARM: at91: remove at91_boot_soc
ARM: at91: move alternative initial mapping to board-dt-sama5.c
ARM: at91: merge all SOC_AT91SAM9xxx
ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init()
ARM: digicolor: select syscon and timer
ARM: zynq: Simplify SLCR initialization
ARM: zynq: PM: Fixed simple typo.
ARM: zynq: Setup default gpio number for Xilinx Zynq
ARM: digicolor: add low level debug support
ARM: initial support for Conexant Digicolor CX92755 SoC
ARM: OMAP2+: Add dm816x hwmod support
ARM: OMAP2+: Add clock domain support for dm816x
ARM: OMAP2+: Add board-generic.c entry for ti81xx
ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage
ARM: at91: remove unused mach/system_rev.h
ARM: at91: stop using HAVE_AT91_DBGUx
ARM: at91: fix ordering of SRAM and PM initialization
with the patchset to add CSR atlas7 support, the below stuff
has no user now:
SIRFSOC_VA
sirfsoc_map_lluart
sirfsoc_map_scu
the related patches missed to drop them.
Signed-off-by: Barry Song <Baohua.Song@csr.com>
CSRatlas7 is next-gen auto SoC from CSR.
It could bring to customers most integrated SoC solution:
- World leading Bluetooth 4.0 and GNSS baseband
- Audio processing, analog CODEC and ADC by DSP
- Analog video input
- SDR accelerators
- CAN bus support by Cortex-M3
Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com>
This patch moves to debug_ll_io_init(), then finally drops CSR map_io()
machine callbacks.
This patch breaks Marco SMP support, but Marco project has been dropped.
So it corrects cpu1 jump/flag address for Atlas7 and removes scu related
logic as scu doesn't expose in cortex-a7.
Marco will not be supported any more. it has been replaced by CSR
Atlas7.
Marco will not be supported any more. It has been replaced by CSR
Atlas7.
Atlas7.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The System Type menu is getting quite long with platforms and is
inconsistent in handling of sub-arch specific options. Tidy up the menu
by making platform options a menuconfig entry containing any platform
specific config items.
[arnd: change OMAP part according to suggestion from
Tony Lindgren <tony@atomide.com>]
Signed-off-by: Rob Herring <robh@kernel.org>
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
Remove the explicit call to l2x0_of_init(), converting to the generic
infrastructure instead. Along with this change, we can delete l2x0.c
from prima2.
The cache size should already be present in the L2 cache auxiliary
control register: it is part of the integration process to configure
the hardware IP. Most platforms get this right, yet still many
cargo-cult program, and assume that they always need specifying to
the L2 cache code. Remove them so we can find out which really need
this.
We have a mixture of different devices with different register layouts,
but we group all the bits together in an opaque mess. Split them out
into those which are L2C-310 specific and ones which refer to earlier
devices. Provide full auxiliary control register definitions.
outer_disable() is defined to safely turn the L2 cache off without data
loss: this means that outer_flush_all() should never be called unless
you need to implement some special L2 cache disabling, and even then
only from your replacement L2 cache disable function.
this patch fixes the below minor issues:
WARNING: line over 80 characters
39: FILE: arch/arm/mach-prima2/rstc.c:39:
+ * Writing 1 to this bit resets corresponding block. Writing 0 to this
41: FILE: arch/arm/mach-prima2/rstc.c:41:
+ * datasheet doesn't require explicit delay between the set and clear
44: FILE: arch/arm/mach-prima2/rstc.c:44:
+ writel(readl(sirfsoc_rstc_base + (reset_bit / 32) * 4) | (1 << reset_bit),
WARNING: msleep < 20ms can sleep for up to 20ms; see Documentation/timers/timers-howto.txt
46: FILE: arch/arm/mach-prima2/rstc.c:46:
+ msleep(10);
47: FILE: arch/arm/mach-prima2/rstc.c:47:
+ writel(readl(sirfsoc_rstc_base + (reset_bit / 32) * 4) & ~(1 << reset_bit),
52: FILE: arch/arm/mach-prima2/rstc.c:52:
+ * Writing 1 to SET register resets corresponding block. Writing 1 to CLEAR
54: FILE: arch/arm/mach-prima2/rstc.c:54:
57: FILE: arch/arm/mach-prima2/rstc.c:57:
+ writel(1 << reset_bit, sirfsoc_rstc_base + (reset_bit / 32) * 8);
58: FILE: arch/arm/mach-prima2/rstc.c:58:
+ msleep(10);
59: FILE: arch/arm/mach-prima2/rstc.c:59:
+ writel(1 << reset_bit, sirfsoc_rstc_base + (reset_bit / 32) * 8 + 4);
total: 0 errors, 10 warnings, 120 lines checked
Signed-off-by: Xianglong Du <Xianglong.Du@csr.com>
If the renamed symbol is defined lib/iomap.c implements ioport_map and
ioport_unmap and currently (nearly) all platforms define the port
accessor functions outb/inb and friend unconditionally. So
HAS_IOPORT_MAP is the better name for this.
Consequently NO_IOPORT is renamed to NO_IOPORT_MAP.
The motivation for this change is to reintroduce a symbol HAS_IOPORT
that signals if outb/int et al are available. I will address that at
least one merge window later though to keep surprises to a minimum and
catch new introductions of (HAS|NO)_IOPORT.
The changes in this commit were done using:
$ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/'
The prima2 platform code currently depends on the rstc
implementation and that in turn depends on the reset
controller framework. This removes the platform dependency
by letting the driver access arm_pm_restart directly
to turn the driver into a standalone entity, and also
removes the dependency on the reset controller framework
by using "if (IS_ENABLED(CONFIG_RESET_CONTROLLER))". This
will cause all code that is used for the reset controller
to be dropped by the compiler if the framework is disabled.
git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux into next/cleanup
ARM: sirf: machine update for 3.15 from Barry Song:
Most of the below are some minor fixes for coding style. "ARM: prima2:
move to generic reset controller driver framework" has been ready near
3.14 merge window, but it was late to merge in 3.14, so move this one
to 3.15.
* tag 'sirf-soc-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux:
ARM: prima2: move to generic reset controller driver framework
ARM: prima2: staticize sirfsoc_init_late function
ARM: prima2: rtciobrg: fix the typo about license
ARM: prima2: common: fix checkpatch issues
ARM: prima2: platsmp: fix checkpatch issues
ARM: prima2: l2x0: fix checkpatch issues
this moves to generic IP module reset framework, and make other drivers
use common device_reset() API.
Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Signed-off-by: Bin Shi <Bin.Shi@csr.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
sirfsoc_init_late() is a local function not an extern interface to anyone.
we are marking GPL v2 in head comments, but MODULE_LICENSE is declaring GPL.
fix the below checkpatch issues:
ERROR: Use of const init definition must use __initconst
30: FILE: common.c:30:
+static const char *atlas6_dt_match[] __initdata = {
45: FILE: common.c:45:
+static const char *prima2_dt_match[] __initdata = {
61: FILE: common.c:61:
+static const char *marco_dt_match[] __initdata = {
ERROR: code indent should use tabs where possible
141: FILE: platsmp.c:141:
+ .smp_prepare_cpus = sirfsoc_smp_prepare_cpus,$
WARNING: please, no spaces at the start of a line
142: FILE: platsmp.c:142:
+ .smp_secondary_init = sirfsoc_secondary_init,$
143: FILE: platsmp.c:143:
+ .smp_boot_secondary = sirfsoc_boot_secondary,$
Fix the below checkpatch issues:
ERROR: open brace '{' following struct go on the same line
15: FILE: l2x0.c:15:
+struct l2x0_aux
ERROR: Use of __initconst requires a separate use of const
20: FILE: l2x0.c:20:
+static struct l2x0_aux prima2_l2x0_aux __initconst = {
25: FILE: l2x0.c:25:
+static struct l2x0_aux marco_l2x0_aux __initconst = {
31: FILE: l2x0.c:31:
+static struct of_device_id sirf_l2x0_ids[] __initconst = {
Many V6 and V7 platforms have an L2x0 cache, so make
CONFIG_MIGHT_HAVE_CACHE_L2X0 visible for V6 and V7 multi-platform
builds.
All V7 platforms can run SMP kernels, so make CONFIG_SMP visible for V7
multi-platform builds.
Multi-platform requires various kconfig options to be selected, so
platforms don't need to select them individually.
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
We have a handy macro to replace open coded __cpuc_flush_dcache_area(()
and outer_clean_range() sequences. Let's use it. No functional change.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
With arch/arm calling of_clk_init(NULL) from time_init(), we can now
remove custom .init_time hooks.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Barry Song <baohua.song@csr.com>
Common clock framework allows to register clock providers to get called
on of_clk_init() by using CLK_OF_DECLARE. This converts prima2 clock
provider to make use of it and get rid of the mach specific clk init
call.
Acked-by: Mike Turquette <mturquette@linaro.org>
"This branch contains mostly additions and changes to platform
enablement and SoC-level drivers. Since there's sometimes a
dependency on device-tree changes, there's also a fair amount of
those in this branch.
Pieces worth mentioning are:
- Mbus driver for Marvell platforms, allowing kernel configuration
and resource allocation of on-chip peripherals.
- Enablement of the mbus infrastructure from Marvell PCI-e drivers.
- Preparation of MSI support for Marvell platforms.
- Addition of new PCI-e host controller driver for Tegra platforms
- Some churn caused by sharing of macro names between i.MX 6Q and 6DL
platforms in the device tree sources and header files.
- Various suspend/PM updates for Tegra, including LP1 support.
- Versatile Express support for MCPM, part of big little support.
- Allwinner platform support for A20 and A31 SoCs (dual and quad
Cortex-A7)
- OMAP2+ support for DRA7, a new Cortex-A15-based SoC.
The code that touches other architectures are patches moving MSI
arch-specific functions over to weak symbols and removal of
ARCH_SUPPORTS_MSI, acked by PCI maintainers"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits)
tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE
PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource
ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list
ARM: dts: vf610-twr: enable i2c0 device
ARM: dts: i.MX51: Add one more I2C2 pinmux entry
ARM: dts: i.MX51: Move pins configuration under "iomuxc" label
ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog
ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator
ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX
ARM: dts: i.MX27: Disable AUDMUX in the template
ARM: dts: wandboard: Add support for SDIO bcm4329
ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template
ARM: dts: imx53-qsb: Make USBH1 functional
ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module
ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module
ARM: dts: imx6qdl-sabresd: Add touchscreen support
ARM: imx: add ocram clock for imx53
ARM: dts: imx: ocram size is different between imx6q and imx6dl
ARM: dts: imx27-phytec-phycore-som: Fix regulator settings
ARM: dts: i.MX27: Remove clock name from CPU node
we don't need nr_irqs in machine any more after we move to
linear irqdomain for sirfsoc irqchip, so drop them.
This will delete some redundant calling of sirfsoc_of_pwrc_init() and
sirfsoc_memc_init() for non-CSR platforms if we use multi-platform.
This patch also enables RTC alarm as wakeup source after system suspends.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
This removes all the ARM uses of the __cpuinit macros from C code,
and all __CPUINIT from assembly code. It also had two ".previous"
section statements that were paired off against __CPUINIT
(aka .section ".cpuinit.text") that also get removed here.
[1] https://lkml.org/lkml/2013/5/20/589
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Pull ARM SoC cleanups from Arnd Bergmann:
"This contains cleanups as preparation for other branches adding new
features, we pulled 16 branches for 9 platforms into this one.
Most notable here is the removal of support for ATAGS based OMAP4
systems. Since all OMAP4 machines are fully functional with DT based
booting in 3.10, we can remove a lot of code here.
Also noteworthy is Maxime Ripard's cleanup of the machine descriptors,
which means we need no machine descriptors in a lot more cases and can
boot additional machines by just having the respective device drivers
enabled."
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
ARM: picoxcell: remove .nr_irqs reference
ARM: s5p64x0: avoid build warning for uncompress.h
ARM: SAMSUNG: Remove unused plat/regs-watchdog.h header
ARM: SAMSUNG: Remove legacy watchdog reset code
ARM: SAMSUNG: Let platforms use the new watchdog reset driver
ARM: SAMSUNG: Add watchdog reset driver
ARM: SAMSUNG: Use local definitions of watchdog registers
watchdog: s3c2410_wdt: Use local register definitions
ARM: S5P64X0: Use common uncompress.h part for plat-samsung
ARM: SAMSUNG: Consolidate uncompress subroutine
ARM: at91: drop rm9200dk board support
ARM: dts: msm: Fix merge resolution
ARM: OMAP1: Remove dma.h
ARM: OMAP1: Remove legacy irda.h and irda setup from board files
ARM: OMAP1: Remove duplicated DMA channel definitions
ARM: OMAP1: Remove McBSP DMA channel definitions
ARM: OMAP2+: Remove dma.h
ARM: OMAP2+: hwmod: Remove remaining DMA channel definitions
ARM: OMAP2+: Remove duplicated DMA channel definitions
ARM: OMAP2+: Remove AES crypto device DMA channel definitions
Pull ARM SoC non-cricitical bug fixes from Arnd Bergmann:
"These are various bug fixes that were not considered important enough
for merging into 3.10.
The majority of the ARM fixes are for the OMAP and at91 platforms, and
there is another set of bug fixes for device drivers that resolve
'randconfig' build errors and that the subsystem maintainers either
did not pick up or preferred to get merged through the arm-soc tree."
* tag 'fixes-non-critical-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
ARM: at91/PMC: use at91_usb_rate() for UTMI PLL
ARM: at91/PMC: fix at91sam9n12 USB FS init
ARM: at91/PMC: at91sam9n12 family has a PLLB
ARM: at91/PMC: sama5d3 family doesn't have a PLLB
ARM: tegra: fix section mismatch in tegra_pmc_parse_dt
ARM: mxs: don't select HAVE_PWM
ARM: mxs: stub out mxs_pm_init for !CONFIG_PM
cpuidle: calxeda: select ARM_CPU_SUSPEND
ARM: mvebu: fix length of ethernet registers in mv78260 dtsi
ARM: at91: cpuidle: Fix target_residency
ARM: at91: fix at91_extern_irq usage for non-dt boards
ARM: sirf: use CONFIG_SIRF rather than CONFIG_PRIMA2 where necessary
clocksource: kona: adapt to CLOCKSOURCE_OF_DECLARE change
X.509: do not emit any informational output
mtd: omap2: allow bulding as a module
[SCSI] nsp32: use mdelay instead of large udelay constants
hwrng: bcm2835: fix MODULE_LICENSE tag
ARM: at91: Change the internal SRAM memory type MT_MEMORY_NONCACHED
ARM: at91: Fix link breakage when !CONFIG_PHYLIB
MAINTAINERS: Add exynos filename match to ARM/S5P EXYNOS ARM ARCHITECTURES
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
From Tony Lindgren:
PM voltage domain clean-up via Kevin Hilman <khilman@linaro.org>:
OMAP: PM: remove requirement for voltage domain data; remove dummy data
* tag 'omap-for-v3.11/pm-voltdomain-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: AM33xx: Remove the unused voltagedomain data
ARM: OMAP2+: Powerdomain: Remove the need to always have a voltdm associated to a pwrdm
Includes an update to Linux 3.10-rc6.
In prima2, some functions of checking DT is registered in initcall
level. If it doesn't match the compatible name of sirf, kernel
will panic. It blocks the usage of multiplatform on other verndor.
The error message is in below.
Knic - not syncing: unable to find compatible pwrc node in dtb
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-rc3-00006-gd7f26ea-dirty #86
[<c0013adc>] (unwind_backtrace+0x0/0xf8) from [<c0011430>] (show_stack+0x10/0x1)
[<c0011430>] (show_stack+0x10/0x14) from [<c026f724>] (panic+0x90/0x1e8)
[<c026f724>] (panic+0x90/0x1e8) from [<c03267fc>] (sirfsoc_of_pwrc_init+0x24/0x)
[<c03267fc>] (sirfsoc_of_pwrc_init+0x24/0x58) from [<c0320864>] (do_one_initcal)
[<c0320864>] (do_one_initcall+0x90/0x150) from [<c0320a20>] (kernel_init_freeab)
[<c0320a20>] (kernel_init_freeable+0xfc/0x1c4) from [<c026b9e8>] (kernel_init+0)
[<c026b9e8>] (kernel_init+0x8/0xe4) from [<c000e158>] (ret_from_fork+0x14/0x3c)
Signen-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
use of_platform_populate to populate platform devices, it is suitable
for creating devices which are children of the root node, then makes
things like pcm work.
this patch removes sirfsoc_mach_init() function and lets arm core do
of_platform_populate:
static int __init customize_machine(void)
* customizes platform devices, or adds new ones
* On DT based machines, we fall back to populating the
* machine from the device tree, if no callback is provided,
* otherwise we would always need an init_machine callback.
if (machine_desc->init_machine)
machine_desc->init_machine();
else
of_platform_populate(NULL, of_default_bus_match_table,
NULL, NULL);
return 0;
Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com>
42: FILE: common.c:42:
+ "sirf,prima2",$
43: FILE: common.c:43:
+ NULL$
include <linux/export.h> is the right to go here.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
Commit ebafed7a ("ARM: irq: Call irqchip_init if no init_irq function is
specified") removed the need to explictly setup the init_irq field in
the machine description when using only irqchip_init. Remove that
declaration for sirf as well.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
* late/fixes:
ARM: OMAP2+: Fix unmet direct dependencies for SERIAL_OMAP
ARM: ux500: always select ABX500_CORE
ARM: SIRF: select SMP_ON_UP only on SMP builds
ARM: SPEAr: conditionalize l2x0 support
ARM: imx: build CPU suspend code only when needed
ARM: OMAP: build SMP code only for OMAP4/5
ARM: tegra: Tegra114 needs CPU_FREQ_TABLE
ARM: default machine descriptor for multiplatform
