In an old commit, we worked around the duplicate definition of
GPIO24_SSP1_SFRM in cm-x2xx.c, which includes files for both
pxa25x and pxa27x. Apparently the problem has come back and we
now have four additional duplicate symbols that cause warnings:
In file included from /git/arm-soc/arch/arm/mach-pxa/pxa27x.h:7:0,
from /git/arm-soc/arch/arm/mach-pxa/cm-x2xx.c:27:
/git/arm-soc/arch/arm/mach-pxa/mfp-pxa27x.h:21:0: warning: "GPIO86_GPIO" redefined
#define GPIO86_GPIO MFP_CFG_IN(GPIO86, AF0)
This uses the same hack as before and undefines all symbols that
are defined more than once. Fortunately, cm-x2xx does not need
any of these.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Lots of header files are never included outside of a mach-pxa
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Since dm9000 driver added support for a vcc regulator, platform data
based platforms have their ethernet broken, as the regulator claiming
returns -EPROBE_DEFER and prevents dm9000 loading.
This patch fixes this for all pxa boards using dm9000, by using the
specific regulator_has_full_constraints() function.
This was discovered and tested on the cm-x300 board.
Fixes: 7994fe55a4a2 ("dm9000: Add regulator and reset support to dm9000")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
The symbol "GPIO24_SSP1_SFRM" is defined in both mfp-pxa27x.h and
mfp-pxa25x.h. Since the macro is not actually used in the cm-x2xx.c
file, but it includes both headers, a safe workaround should be
to just undefine it from the .c file. This is a bit hacky and
the headers should be fixed to not both define it, but for now
it gets us around an annoying warning.
Without this patch, building cm_x2xx_defconfig results in:
In file included from arch/arm/mach-pxa/include/mach-pxa/pxa27x.h:7:0,
from arch/arm/mach-pxa/cm-x2xx.c:25:
arch/arm/mach-pxa/include/mach-pxa/mfp-pxa27x.h:215:0: warning: "GPIO24_SSP1_SFRM" redefined [enabled by default]
arch/arm/mach-pxa/include/mach-pxa/mfp-pxa25x.h:111:0: note: this is the location of the previous definition
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
arch/arm/mach-mxs/include/mach/common.h
Pull in previous samsung conflict merges and do a trivial
merge of an mxs double-add conflict.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Avoid potential naming confliction since multiple architecture will be built
in a single kernel.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Fix up all conflicts between the memory.h cleanup and bug fixes.
This tries to clear up the confusion between integers and iomem pointers
in the marvell pxa platform. MMIO addresses are supposed to be __iomem*
values, in order to let the Linux type checking work correctly. This
patch moves the cast to __iomem as far back as possible, to the place
where the MMIO virtual address windows are defined.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
Replace sysdev classes and struct sys_device objects used for "core"
power management by the PXA platform code with struct syscore_ops
objects that are simpler.
This reduces the code size and the kernel memory footprint. It also
is necessary for removing sysdevs entirely from the kernel in the
future.
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
This is important because on PXA3xx, the physical mapping of SMEMC registers
differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx
and PXA320, the PCMCIA driver was adjusted accordingly as well.
Also, various places in the kernel had to be patched to use
__raw_read/__raw_write.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Acked-by: Antonio Ospite <ospite@studenti.unina.it>
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
Acked-by: Mike Rapoport <mike@compulab.co.il>
This patch fixes cm-x2xx not registering the ucb1400. This is
because of the splitting of ucb1400 driver half year ago.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Ian Molton <spyro@f2s.com>
Cc: pHilipp Zabel <philipp.zabel@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Juergen Schindele <linux@schindele.name>
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
Signed-off-by: Russ Dill <russ.dill@gmail.com>
CM-X255
- Change CM-X255 and CM-X270 common function prefix from cmx270 to cmx2xx
- Split cmx2xx_init to common and CM-X270-specific parts
- Use dynamic assignement for DM9000 resources and led GPIOs.
Acked-by: Eric Miao <eric.miao@marvell.com>
support
