Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits)
spi/omap: Fix DMA API usage in OMAP MCSPI driver
spi/imx: correct the test on platform_get_irq() return value
spi/topcliff: Typo fix threhold to threshold
spi/dw_spi Typo change diable to disable.
spi/fsl_espi: change the read behaviour of the SPIRF
spi/mpc52xx-psc-spi: move probe/remove to proper sections
spi/dw_spi: add DMA support
spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs
spi/dw_spi: Fix too short timeout in spi polling loop
spi/pl022: convert running variable
spi/pl022: convert busy flag to a bool
spi/pl022: pass the returned sglen to the DMA engine
spi/pl022: map the buffers on the DMA engine
spi/topcliff_pch: Fix data transfer issue
spi/imx: remove autodetection
spi/pxa2xx: pass of_node to spi device and set a parent device
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add CE4100 support
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits)
[media] af9015: Fix max I2C message size when used with tda18271
[media] IR: initialize ir_raw_event in few more drivers
[media] Guard a divide in v4l1 compat layer
[media] imon: fix nomouse modprobe option
[media] imon: remove redundant change_protocol call
[media] imon: fix my egregious brown paper bag w/rdev/idev split
[media] cafe_ccic: Configure ov7670 correctly
[media] ov7670: allow configuration of image size, clock speed, and I/O method
[media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016]
[media] af9015: map DigitalNow TinyTwin v2 remote
[media] DigitalNow TinyTwin remote controller
[media] af9015: RC fixes and improvements
videodev2.h.xml: Update to reflect the latest changes at videodev2.h
[media] v4l: document new Bayer and monochrome pixel formats
[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028
[media] firedtv: add parameter to fake ca_system_ids in CA_INFO
[media] tm6000: fix a macro coding style issue
tm6000: Remove some ugly debug code
[media] Nova-S-Plus audio line input
[media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, remove the module names hardcoded in platform data
and pass a NULL module name to those functions.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the soc_camera
platform data uses.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
pxa_camera init() is ambiguous, it's better to statically configure the sensor.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Several boards use always the same pattern with pxamci :
request gpio, request irq for that gpio to detect MMC card
insertion, request gpio for read-only mode detection, etc
Now that pxamci provides platform_data to describe simple
gpio management of the MMC external controls, use it.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: rpurdie@rpsys.net
Cc: drwyrm@gmail.com
Cc: sakoman@gmail.com
Cc: marek.vasut@gmail.com
Cc: s.hauer@pengutronix.de
If CONFIG_APM_EMULATION=n em-x270 build fails with linker error:
arch/arm/mach-pxa/built-in.o: In function `em_x270_battery_critical': em-x270.c:(.text+0x12c0): undefined reference to `apm_queue_event'
arch/arm/mach-pxa/built-in.o: In function `em_x270_battery_low': em-x270.c:(.text+0x12c8): undefined reference to `apm_queue_event'
make: *** [.tmp_vmlinux1] Error 1
Fix it.
After commit 6b849bcff0004aa5dd216b4d3eb56f51c9df8a72 (ASoC: Convert PXA
AC97 driver to probe with the platform device) AC97 controller device
should be registered explicitly for both ASoC and generic AC97 drivers
Register userspace-consumer devices to allow userspace control of
voltage regulators supplying GPS and GPRS modules
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Paul Shen <paul.shen@marvell.com>
Remove duplicated #include in arch/arm/mach-pxa/em-x270.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
After commit a7bb3909b3293d503211d7f6af8ed62c1644b686 ("spi: pxa2xx_spi:
introduce chipselect GPIO to simplify the common cases") the .gpio_cs
field in pxa2xx_spi_chip has to be set explicitly.
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
Change several GPIO assignment from static to run-time
Split MFP table to common and EM-X270 specific parts
Introduce em_x270_module_init
The patch includes the following updates to EM-X270:
- Added DA9030 support
- Added NOR flash support
- Added QCI with mt9m112 sensor support
- Updated LCD support
Direct access to USB host controller registers is considered to be not
portable, and is usually a bad sign for poorly abstracted interface.
Introduce .flags and .power_on_delay to "struct pxaohci_platform_data"
so that most platforms don't bother to write their own .init/.exit()
sequences.
This just leaves include/asm-arm/plat-* to deal with.
Convert EM-X270 pin configuration to use MFP tables and gpio library
Make device initialization dependent on respective driver CONFIG_ value (like
in zylonite)
Add keypad and gpio_key devices
As well as moving all the device declarations to a single one in devices.c
this causes all platforms to register the I/O and interrupt resources for
the AC97 controller.
Cc: eric miao <eric.miao@marvell.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Jürgen Schindele <linux@schindele.name>
Cc: Juergen Beisert <jbe@pengutronix.de>
The PXA25x and PXA27x USB device controller register definitions are
different. Currently, they live side by side in pxa-regs.h, but only
one set is available depending on the setting of PXA25x or PXA27x.
This means that if we build to support both PXA25x and PXA27x, the
PXA27x definitions are unavailable, even to PXA27x specific code.
Remove these definitions from pxa-regs.h, and place them in separate
files. Include these files where appropriate.
Note: according to the dependencies in drivers/usb/gadget/Kconfig,
we do not support the UDC on PXA27x nor PXA3xx CPUs, so remove the
platform devices from pxa27x.c and pxa3xx.c.
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
