path: root/arch/arm/mach-pxa/lpd270.c
2011-07-12ARM: pxa: enable MULTI_IRQ_HANDLER for all boardsEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-24ARM / PXA: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by the PXA platform code with struct syscore_ops objects that are simpler. This reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-16ARM: pxa: clean up set_pxa_fb_infoRussell King - ARM Linux
set_pxa_fb_info() has been a long-standing wart in the naming scheme of the pxa_set_xxx_info() functions. This renames the function, and combines set_pxa_fb_parent() with set_pxa_fb_info(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-13ARM: PXA SoCs: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-12-16ARM: pxa: Access SMEMC via virtual addressesMarek Vasut
This is important because on PXA3xx, the physical mapping of SMEMC registers differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx and PXA320, the PCMCIA driver was adjusted accordingly as well. Also, various places in the kernel had to be patched to use __raw_read/__raw_write. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-08ARM: pxa: encode IRQ number into .nr_irqsHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-02[ARM] pxa: add the missing AC97 pin configurationsEric Miao
Missing AC97 pin configurations are added where pxa_set_ac97_info() are called for all pxa25x/pxa27x platforms. Where no exact configuration is provided, use the default as in sound/arm/pxa2xx-ac97-lib.c Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-02[ARM] pxa: use chip->ack() instead of accessing GEDR directlyEric Miao
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-09[ARM] pxa: move GPIO register definitions into <mach/gpio.h>Eric Miao
This makes gpio.c fully independent of pxa-regs.h (except for the virtual address of the registers). Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa/lpd270: use new .lcd_conn to specify LCD infoEric Miao
2008-09-26[ARM] pxa/lpd270: convert to use new MFP APIEric Miao
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration modelMark Brown
As well as moving all the device declarations to a single one in devices.c this causes all platforms to register the I/O and interrupt resources for the AC97 controller. Cc: eric miao <eric.miao@marvell.com> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Jürgen Schindele <linux@schindele.name> Cc: Juergen Beisert <jbe@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09Merge branches 'pxa-misc', 'pxa-pwm' and 'pxa-multi' into pxaRussell King
2008-07-03[ARM] pxa: make LogicPD 270 use the generic PWM backlight driverRussell King
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: don't register lpd270 cpld_irq sysdev if !lpd270Russell King
Don't register the LPD270 cpld_irq system device when we're not running on a LPD270 machine - "cpld_irq" is also registered (separately) by Lubbock and Mainstone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: move memory controller registers into pxa2xx-regs.hRussell King
PXA3 has a different memory controller from PXA2 platforms. Avoid clashing definitions by moving the PXA2 definitions to pxa2xx-regs.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12[ARM] pxa: move platform devices to separate header fileRussell King
2007-07-12[ARM] 4450/1: pxa: add pxa25x_init_irq() and pxa27x_init_irq()Eric Miao
/* should be ok this time, I aligned this patch to your arm:pxa2.mbox */ 1. move pxa25x specific IRQ initialization code to pxa25x_init_irq() and pxa27x code to pxa27x_init_irq(), remove pxa_init_irq() 2. replace all pxa_init_irq() with their PXA25x or PXA27x specific functions Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] 3673/1: lpd270: parse lcd= command line parameterLennert Buytenhek
Patch from Lennert Buytenhek The bootloader on the LogicPD PXA270 platform informs the kernel of which type of TFT screen is connected via an lcd=$FOO kernel command line parameter. Before this patch, we ignored this parameter and just hardcoded the use of the Sharp lq64d343 display kit. This patch implement parsing of the command line option, and chooses the right pxafb_mach_info to use (six choices) based on this command line option. Also fix the fb settings to correspond with those of the bootloader. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-28[ARM] 3417/1: add support for logicpd pxa270 card engineLennert Buytenhek
Patch from Lennert Buytenhek Add support for the LogicPD PXA270 Card Engine. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
