Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
After converting the PXA driver to use GPIO descriptors for
card detect and write protect it is relatively simple to
convert it to also use a descriptor for getting the optional
power control GPIO.
The polarity inversion flag can also go away from the platform
data since this is indicated in the GPIO machine descriptor
table.
Cc: Daniel Mack <daniel@zonque.org>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Bartosz Golaszewski <brgl@bgdev.pl>
Cc: Andrea Adami <andrea.adami@gmail.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
This deletes the platform data passed for card detect and
write protect from various PXA machines.
Make sure to keep .gpio_card_ro_invert as this is still in
use by some machines and needed to set the right flag to
the MMC core (will be cleaned up later).
This adds GPIO descriptor look-up tables for a whole bunch
of PXA boards with MMC card detect (CD) and write protect (WP)
GPIO lines, so we can move away from the hard-coded GPIO
numberspace.
In some cases the platforms were compulsively including the
<linux/gpio.h> header even if they weren't actually using
it, and in these cases I simply replaced that inclusion with
the more appropriate <linux/gpio/machine.h> which is what
board files should be including most of the time.
Lots of header files are never included outside of a mach-pxa
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Use a PWM lookup table to provide the PWM to the pwm-backlight device.
The driver has a legacy code path that is required only because boards
still use the legacy method of requesting PWMs by global ID. Replacing
these usages allows that legacy fallback to be removed.
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
The GPIO API defines 0 as being a valid GPIO number, so this field needs
to be initialized explicitly.
A special case is the Palm Tungsten|C board. Since it doesn't use any
quirks that would require the existing .init() or .exit() hooks it can
simply use the new enable_gpio field.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
Gcc prints a harmless warning about palmte2_pxa_keys not being used
when the gpio keyboard driver is disabled. The solution is to use
the same #ifdef that is already present in the place where the
symbol is used.
Without this patch, building palmz72_defconfig results in:
/home/arnd/linux-arm/arch/arm/mach-pxa/palmte2.c:128:31: warning: 'palmte2_pxa_keys' defined but not used [-Wunused-variable]
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Cc: Carlos Eduardo Medaglia Dyonisio <cadu@nerdfeliz.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
Remove NR_IRQS and add a per machine .nr_irqs setting.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
Use gpio_request_array() / gpio_free_array() in backlight init and exit
functions. This makes the code cleaner and less error prone.
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
This file is scheduled for removal, therefore fix all devices that use this
file to use the suggested wm97xx.h and pass platform data properly.
Acked-by: Tomas Cech <sleep_walker@suse.cz>
There are only limited possible LCD pin configurations for pxa25x
platforms, simplify this by macro.
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
Acked-by: Mike Rapoport <mike@compulab.co.il>
and convert PXA-based devices to gpio_pwdown where possible.
Several boards use always the same pattern with pxamci :
request gpio, request irq for that gpio to detect MMC card
insertion, request gpio for read-only mode detection, etc
Now that pxamci provides platform_data to describe simple
gpio management of the MMC external controls, use it.
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: rpurdie@rpsys.net
Cc: drwyrm@gmail.com
Cc: sakoman@gmail.com
Cc: marek.vasut@gmail.com
Cc: s.hauer@pengutronix.de
Signed-off-by: Eric Miao <eric.miao@marvell.com>
This contains support for keypad, MMC, AC97, LCD and backlight.
