Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
Reported-by: Rafael Gandolfi <kaillasse91@hotmail.fr>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
This file is scheduled for removal, therefore fix all devices that use this
file to use the suggested wm97xx.h and pass platform data properly.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Tomas Cech <sleep_walker@suse.cz>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
and convert PXA-based devices to gpio_pwdown where possible.
This patch adds support for NAND chip found in PalmTX handheld. Support
is implemented through the gen_nand driver.
Several boards use always the same pattern with pxamci :
request gpio, request irq for that gpio to detect MMC card
insertion, request gpio for read-only mode detection, etc
Now that pxamci provides platform_data to describe simple
gpio management of the MMC external controls, use it.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: rpurdie@rpsys.net
Cc: drwyrm@gmail.com
Cc: sakoman@gmail.com
Cc: marek.vasut@gmail.com
Cc: s.hauer@pengutronix.de
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Firstly, this patch makes the palm27x asoc driver a little more sane. Also,
since all affected devices use GPIO95 as AC97_nRESET, this patch sets that
properly. Affected are PalmT5, TX and LifeDrive.
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
This patch adds generic battery driver for wm97xx chips.
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
This just leaves include/asm-arm/plat-* to deal with.
This patch adds battery monitoring driver for PalmTX.
It can read voltage from the battery and temperature.
It also monitors charging/discharging status.
This patch adds PCMCIA support for PalmTX handheld computer.
There is one chip hard-soldered to slot0, another slot is
not in use and not accessible.
PalmTX is PXA27x based device with wifi, bluetooth,
touchscreen, sdio slot, irda, keypad, nand flash,
pxa framebuffer, serial and usb gadget interface.
Supported by this patch is pxafb, touchscreen, irda,
keypad and sdio slot.
