path: root/arch/arm/mach-pxa/tosa.c
2013-12-11ARM: pxa: tosa: fix keys mappingDmitry Eremin-Solenikov
When converting from tosa-keyboard driver to matrix keyboard, tosa keys received extra 1 column shift. Replace that with correct values to make keyboard work again. Fixes: f69a6548c9d5 ('[ARM] pxa/tosa: make use of the matrix keypad driver') Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: arm: remove unused restart_mode fields from some arm subarchsRobin Holt
These restart_mode fields are not used at all. Remove them to make moving the reboot= cmdline options to the general kernel easier. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull GPIO changes from Grant Likely: "This branch contains the usual set of individual driver improvements and bug fixes, as well as updates to the core code. The more notable changes include: - Internally add new API for referencing GPIOs by gpio_desc instead of number. Eventually this will become a public API - ACPI GPIO binding support" * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (33 commits) arm64: select ARCH_WANT_OPTIONAL_GPIOLIB gpio: em: Use irq_domain_add_simple() to fix runtime error gpio: using common order: let 'static const' instead of 'const static' gpio/vt8500: memory cleanup missing gpiolib: Fix locking on gpio debugfs files gpiolib: let gpio_chip reference its descriptors gpiolib: use descriptors internally gpiolib: use gpio_chips list in gpiochip_find_base gpiolib: use gpio_chips list in sysfs ops gpiolib: use gpio_chips list in gpiochip_find gpiolib: use gpio_chips list in gpiolib_sysfs_init gpiolib: link all gpio_chips using a list gpio/langwell: cleanup driver gpio/langwell: Add Cloverview ids to pci device table gpio/lynxpoint: add chipset gpio driver. gpiolib: add missing braces in gpio_direction_show gpiolib-acpi: Fix error checks in interrupt requesting gpio: mpc8xxx: don't set IRQ_TYPE_NONE when creating irq mapping gpiolib: remove gpiochip_reserve() arm: pxa: tosa: do not use gpiochip_reserve() ...
2013-02-04arm: pxa: tosa: do not use gpiochip_reserve()Alexandre Courbot
GPIO address space reservation during early platform initialization is not needed anymore for Tosa. Remove the calls to gpiochip_reserve() which is due to be removed. Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-14ARM: pxa: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the pxa include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Acked-By: Stefan Schmidt <stefan@openezx.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Cc: Harald Welte <laforge@openezx.org> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Tomas Cech <sleep_walker@suse.cz> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: Dan Williams <djbw@fb.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: openezx-devel@lists.openezx.org
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2012-01-09Merge branch 'samsung/driver' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/common.h Pull in previous samsung conflict merges and do a trivial merge of an mxs double-add conflict. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-05ARM: restart: pxa: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-17ASoC: pxa: Convert tosa to use snd_soc_register_card()Axel Lin
Use snd_soc_register_card() instead of creating a "soc-audio" platform device. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-14ARM: pxa: rename gpio_to_irq and irq_to_gpioHaojian Zhuang
Avoid to define gpio_to_irq() and irq_to_gpio() for potential name confliction since multiple architecture will be built together. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2011-11-10ARM: restart: add default restart modes for PXA mioa701, spitz and tosaRussell King
Add a default restart mode to reflect the hard-coded restart mode found in these files. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-12ARM: pxa: enable MULTI_IRQ_HANDLER for all boardsEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-26Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable Conflicts: arch/arm/mach-pxa/tosa.c
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-16ARM: pxa/tosa: switch to using gpio-vbus transceiverDmitry Eremin-Solenikov
Switch from handling gpio-vbus in pxa25x_udc to using standard gpio-vbus tranceiver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-27ARM: pxa/tosa: register wm9712 codec deviceDmitry Eremin-Solenikov
Since f0fba2ad1b it's required to register platform devices even for AC'97 codecs. Register one on tosa (wm9712-codec). Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-07Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits) spi/omap: Fix DMA API usage in OMAP MCSPI driver spi/imx: correct the test on platform_get_irq() return value spi/topcliff: Typo fix threhold to threshold spi/dw_spi Typo change diable to disable. spi/fsl_espi: change the read behaviour of the SPIRF spi/mpc52xx-psc-spi: move probe/remove to proper sections spi/dw_spi: add DMA support spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs spi/dw_spi: Fix too short timeout in spi polling loop spi/pl022: convert running variable spi/pl022: convert busy flag to a bool spi/pl022: pass the returned sglen to the DMA engine spi/pl022: map the buffers on the DMA engine spi/topcliff_pch: Fix data transfer issue spi/imx: remove autodetection spi/pxa2xx: pass of_node to spi device and set a parent device spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add CE4100 support ...
2010-12-16ARM: pxa: Access SMEMC via virtual addressesMarek Vasut
This is important because on PXA3xx, the physical mapping of SMEMC registers differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx and PXA320, the PCMCIA driver was adjusted accordingly as well. Also, various places in the kernel had to be patched to use __raw_read/__raw_write. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-08ARM: pxa: encode IRQ number into .nr_irqsHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-07-16ARM: Remove DISCONTIGMEM supportRussell King
Everything should now be using sparsemem rather than discontigmem, so remove the code supporting discontigmem from ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-11[ARM] pxa: make it clear by converting MMC 'delay_detect' to millisecondEric Miao
delay_detect in HZ is confusing, convert it to be millisecond based. And thus remove those unnecessary call to msecs_to_jiffies() at runtime for this field. Other constants are converted assuming HZ == 100, which are basically true for those platforms. The assignment in csb726.c was incorrect, and is fixed in this patch as a result. Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Marc Zyngier <maz@misterjones.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Daniel Mack <daniel@caiaq.de>
2010-03-02[ARM] pxa/tosa: make use of the matrix keypad driverEric Miao
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa: add gpio_pwdown(_inverted) into pxaficp_ir.cMarek Vasut
and convert PXA-based devices to gpio_pwdown where possible. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa: factor pxamci gpio handlingRobert Jarzmik
Several boards use always the same pattern with pxamci : request gpio, request irq for that gpio to detect MMC card insertion, request gpio for read-only mode detection, etc ... Now that pxamci provides platform_data to describe simple gpio management of the MMC external controls, use it. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: rpurdie@rpsys.net Cc: drwyrm@gmail.com Cc: sakoman@gmail.com Cc: marek.vasut@gmail.com Cc: s.hauer@pengutronix.de Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-05[ARM] pxa: move mach/i2c.h to plat/i2c.hEric Miao
Signed-off-by: Paul Shen <paul.shen@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-18[ARM] pxa: allow gpio_reset drive high during normal workDaniel Ribeiro
I want to reuse tosa/spitz gpio_reset code, but my board needs the reset gpio to be driven high during normal operation. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-04-04[ARM] pxa: register AC97 controller devicesMark Brown
The tosa, e740, e750, e800 and mioa701 all use AC97 audio codecs but does not register the platform device for the AC97 controller. Doing so is now required by ASoC. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-24Merge branch 'devel' of ↵root
2009-03-23Merge branch 'fix' of ↵Eric Miao
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6.git into devel
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pxa: make second argument of clk_add_alias a name instead of the deviceDmitry Eremin-Solenikov
clk_add_alias is commonly called for platform devices that are not yet registered in the device tree. Thus the clock alias is associated with NULL device name. Fix this by passing the device name instead of just device pointer. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-02[ARM] pxa/tosa: add physmap mapping for ROMDmitry Baryshkov
Add mapping for system ROM using physmap-flash mapping. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-02[ARM] pxa/tosa: fix building w/o TC6393XB driverDmitry Baryshkov
2008-12-02[ARM] pxa/tosa: support tc6393xb/tmiofb.Dmitry Baryshkov
Add platform data necessary to support tmiofb on tosa. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-21tosa: add support for bl/lcd driverDmitry Baryshkov
2008-10-19mfd: do tcb6393xb state restore on resume only if requestedDmitry Baryshkov
As requested by Ian make state restore only if it's requested by platform data: some platforms do correctly save the state of the chip during suspend/resume, but some (like tosa) incorrectly power off the chip at suspend, so the driver supports restoring some bits of the tc6393xb state (not full, merely enough to support resume on tosa). With this patch this code is disabled by default. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-19mfd: provide and use setup hook for tc6393xbDmitry Baryshkov
Instead of using bitfields for initial gpio setup, provide generic setup/teardown hooks that can be used to set the gpio states, register child devices, etc. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-11[ARM] 5300/1: fixup spitz reset during bootDmitry Baryshkov
Some machines don't have the pullup/down on their reset pin, so configuring the reset generating pin as input makes them reset immediately. Fix that by making reset pin direction configurable. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-13[ARM] 5247/1: tosa: SW_EAR_IN supportDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-13[ARM] 5246/1: tosa: add proper clock alias for tc6393xb clockDmitry Baryshkov
Add clock alias for clock that is used by tc6393xb device on tosa. As that chip plays pretty major part in tosa life and is currently disabled, this is 2.4.27 material. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
