path: root/arch/arm/mach-pxa/trizeps4.c
2011-07-12ARM: pxa: enable MULTI_IRQ_HANDLER for all boardsEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-24ARM / PXA: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by the PXA platform code with struct syscore_ops objects that are simpler. This reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-26Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable Conflicts: arch/arm/mach-pxa/tosa.c
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-16ARM: pxa: clean up set_pxa_fb_infoRussell King - ARM Linux
set_pxa_fb_info() has been a long-standing wart in the naming scheme of the pxa_set_xxx_info() functions. This renames the function, and combines set_pxa_fb_parent() with set_pxa_fb_info(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-07Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits) spi/omap: Fix DMA API usage in OMAP MCSPI driver spi/imx: correct the test on platform_get_irq() return value spi/topcliff: Typo fix threhold to threshold spi/dw_spi Typo change diable to disable. spi/fsl_espi: change the read behaviour of the SPIRF spi/mpc52xx-psc-spi: move probe/remove to proper sections spi/dw_spi: add DMA support spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs spi/dw_spi: Fix too short timeout in spi polling loop spi/pl022: convert running variable spi/pl022: convert busy flag to a bool spi/pl022: pass the returned sglen to the DMA engine spi/pl022: map the buffers on the DMA engine spi/topcliff_pch: Fix data transfer issue spi/imx: remove autodetection spi/pxa2xx: pass of_node to spi device and set a parent device spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add CE4100 support ...
2010-12-16ARM: pxa: Access SMEMC via virtual addressesMarek Vasut
This is important because on PXA3xx, the physical mapping of SMEMC registers differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx and PXA320, the PCMCIA driver was adjusted accordingly as well. Also, various places in the kernel had to be patched to use __raw_read/__raw_write. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-05[ARM] pxa: removing dead IDE_PXA_CFChristoph Egger
IDE_PXA_CF doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Acked-by: Juergen Schindele <schindele@nentec.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: make it clear by converting MMC 'delay_detect' to millisecondEric Miao
delay_detect in HZ is confusing, convert it to be millisecond based. And thus remove those unnecessary call to msecs_to_jiffies() at runtime for this field. Other constants are converted assuming HZ == 100, which are basically true for those platforms. The assignment in csb726.c was incorrect, and is fixed in this patch as a result. Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Marc Zyngier <maz@misterjones.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Daniel Mack <daniel@caiaq.de>
2010-03-02[ARM] pxa: add the missing AC97 pin configurationsEric Miao
Missing AC97 pin configurations are added where pxa_set_ac97_info() are called for all pxa25x/pxa27x platforms. Where no exact configuration is provided, use the default as in sound/arm/pxa2xx-ac97-lib.c Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-02[ARM] pxa: simplify the LCD pin configuration for pxa27x platformsEric Miao
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa: add gpio_pwdown(_inverted) into pxaficp_ir.cMarek Vasut
and convert PXA-based devices to gpio_pwdown where possible. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa: factor pxamci gpio handlingRobert Jarzmik
Several boards use always the same pattern with pxamci : request gpio, request irq for that gpio to detect MMC card insertion, request gpio for read-only mode detection, etc ... Now that pxamci provides platform_data to describe simple gpio management of the MMC external controls, use it. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: rpurdie@rpsys.net Cc: drwyrm@gmail.com Cc: sakoman@gmail.com Cc: marek.vasut@gmail.com Cc: s.hauer@pengutronix.de Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-06-05[ARM] pxa: move mach/i2c.h to plat/i2c.hEric Miao
Signed-off-by: Paul Shen <paul.shen@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-18[ARM] remove extra brace in arch/arm/mach-pxa/trizeps4.cMariusz Kozlowski
Hello, Introduced by: commit 642aa6637e46ae788f1f8916dc9aa5a68917e12e Author: J<C3><BC>rgen Schindele <linux@schindele.name> Date: Mon Aug 18 21:45:03 2008 +0100 Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] 5204/1: Trizeps4 SOM updateJürgen Schindele
- use MFP-API for GPIO - support TRIZEPS4WL module - cleanups Signed-off-by: Jrgen Schindele <linux@schindele.name> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helperDmitry Baryshkov
2008-07-09[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration modelMark Brown
As well as moving all the device declarations to a single one in devices.c this causes all platforms to register the I/O and interrupt resources for the AC97 controller. Cc: eric miao <eric.miao@marvell.com> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Jürgen Schindele <linux@schindele.name> Cc: Juergen Beisert <jbe@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: separate out power manager and clock registersRussell King
The power manager and core clock registers aren't present in PXA3 CPUs. Move them out of pxa-regs.h into pxa2xx-regs.h, and include pxa2xx-regs.h where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] pxa: fix mci_init functions returning -1Russell King
Fix all those PXA mci_init functions which return -1 rather than propagating the error code to the higher levels. Remove the silly set_irq_type() calls as well - use the flags for request_irq() instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: move platform devices to separate header fileRussell King
2007-07-12[ARM] 4450/1: pxa: add pxa25x_init_irq() and pxa27x_init_irq()Eric Miao
/* should be ok this time, I aligned this patch to your arm:pxa2.mbox */ 1. move pxa25x specific IRQ initialization code to pxa25x_init_irq() and pxa27x code to pxa27x_init_irq(), remove pxa_init_irq() 2. replace all pxa_init_irq() with their PXA25x or PXA27x specific functions Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4362/1: trizeps4 updateJürgen Schindele
This update for trizeps4 SoM contains: - support for new TFT on more recent ConXS evalboard - correct partition of flash device - update of "trizeps4_defconfig" Signed-off-by: Jrgen Schindele (linux@schindele.name) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-13[ARM] Remove empty fixup functionRussell King
Empty fixup functions are just a waste of code, and are not necessary. Remote them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[ARM] 3666/1: TRIZEPS4 [1/5] coreJürgen Schindele
Patch from Jürgen Schindele This patch adds support for Trizeps4 SoM and ConXS-evalboard from "Keith und Koep" This DIMM-module is based on PXA270. Signed-off-by: Jürgen Schindele <linux@schindele.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
