We should not dereference registers as pointers, so use readl/writel
instead for these registers.
The clock registers are accessed in multiple files, so we have to
change them all at once.
I stumbled over these registers while looking at something unrelated.
There are in fact other registers with the same problem, but I did
not try to address those at this point.
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Lots of header files are never included outside of a mach-pxa
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
* fixes: (28 commits)
ARM: ux500: add an SMP enablement type and move cpu nodes
ARM: dts: keystone: fix dt bindings to use post div register for mainpll
ARM: nomadik: disable UART0 on Nomadik boards
ARM: dts: i.MX35: Fix can support.
ARM: OMAP2+: hwmod: Fix _wait_target_ready() for hwmods without sysc
ARM: dts: add CPU OPP and regulator supply property for exynos4210
ARM: dts: Update video-phy node with syscon phandle for exynos3250
ARM: keystone: dts: rename pcie nodes to help override status
ARM: keystone: dts: fix dt bindings for PCIe
ARM: pxa: fix dm9000 platform data regression
ARM: DRA7: hwmod: fix gpmc hwmod
ARM: dts: Correct audio input route & set mic bias for am335x-pepper
ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX
MAINTAINERS: digicolor: add dts files
ARM: ux500: fix MMC/SD card regression
ARM: ux500: define serial port aliases
ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs
ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs
ARM: dts: Fix frequency scaling on Gumstix Pepper
ARM: dts: configure regulators for Gumstix Pepper
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next/cleanup
Merge "ARM: Interrupt cleanups and API change preparation" from Thomas
Gleixner:
The following patch series contains the following changes:
- Consolidation of chained interrupt handler setup/removal
- Switch to functions which avoid a redundant interrupt
descriptor lookup
- Preparation of interrupt flow handlers for the 'irq' argument
removal
* 'queue/irq/arm' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM/orion/gpio: Prepare gpio_irq_handler for irq argument removal
ARM/pxa: Prepare balloon3_irq_handler for irq argument removal
ARM/pxa: Prepare *_irq_handler for irq argument removal
ARM/dove: Prepare pmu_irq_handler for irq argument removal
ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal
ARM/locomo: Prepare locomo_handler for irq argument removal
ARM, irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc
ARM/LPC32xx: Use irq_set_handler_locked()
ARM/irq: Use access helper irq_data_get_affinity_mask()
ARM/locomo: Consolidate chained IRQ handler install/remove
ARM/orion: Consolidate chained IRQ handler install/remove
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
Since dm9000 driver added support for a vcc regulator, platform data
based platforms have their ethernet broken, as the regulator claiming
returns -EPROBE_DEFER and prevents dm9000 loading.
This patch fixes this for all pxa boards using dm9000, by using the
specific regulator_has_full_constraints() function.
This was discovered and tested on the cm-x300 board.
Fixes: 7994fe55a4a2 ("dm9000: Add regulator and reset support to dm9000")
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: Russell King <linux+kernel@arm.linux.org.uk>
This patch fix a typo in struct platform_device can_regulator_device.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Daniel Mack <daniel@zonque.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
This patch moves the pca953x.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
This patch replaces power callbacks to the regulator API. To improve
the readability of the code, helper for the regulator enable/disable
was added.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
arch/arm/mach-mxs/include/mach/common.h
Pull in previous samsung conflict merges and do a trivial
merge of an mxs double-add conflict.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Avoid to define gpio_to_irq() and irq_to_gpio() for potential name
confliction since multiple architecture will be built together.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Fix up all conflicts between the memory.h cleanup and bug fixes.
This tries to clear up the confusion between integers and iomem pointers
in the marvell pxa platform. MMIO addresses are supposed to be __iomem*
values, in order to let the Linux type checking work correctly. This
patch moves the cast to __iomem as far back as possible, to the place
where the MMIO virtual address windows are defined.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
The first and second arguments shouldn't concern platform code, so
hide them from each platforms caller.
Tested-by: Kevin Hilman <khilman@ti.com>
Acked-by: Jean Pihet <j-pihet@ti.com>
We don't need a veneer for cpu_suspend, it can be called directly from
C code now. Move it into the PXA CPU suspend functions, along with
the accumulator register saving/restoring.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits)
spi/omap: Fix DMA API usage in OMAP MCSPI driver
spi/imx: correct the test on platform_get_irq() return value
spi/topcliff: Typo fix threhold to threshold
spi/dw_spi Typo change diable to disable.
spi/fsl_espi: change the read behaviour of the SPIRF
spi/mpc52xx-psc-spi: move probe/remove to proper sections
spi/dw_spi: add DMA support
spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs
spi/dw_spi: Fix too short timeout in spi polling loop
spi/pl022: convert running variable
spi/pl022: convert busy flag to a bool
spi/pl022: pass the returned sglen to the DMA engine
spi/pl022: map the buffers on the DMA engine
spi/topcliff_pch: Fix data transfer issue
spi/imx: remove autodetection
spi/pxa2xx: pass of_node to spi device and set a parent device
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add CE4100 support
This is important because on PXA3xx, the physical mapping of SMEMC registers
differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx
and PXA320, the PCMCIA driver was adjusted accordingly as well.
Also, various places in the kernel had to be patched to use
__raw_read/__raw_write.
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Acked-by: Antonio Ospite <ospite@studenti.unina.it>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits)
qlcnic: adding co maintainer
ixgbe: add support for active DA cables
ixgbe: dcb, do not tag tc_prio_control frames
ixgbe: fix ixgbe_tx_is_paused logic
ixgbe: always enable vlan strip/insert when DCB is enabled
ixgbe: remove some redundant code in setting FCoE FIP filter
ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp
ixgbe: fix header len when unsplit packet overflows to data buffer
ipv6: Never schedule DAD timer on dead address
ipv6: Use POSTDAD state
ipv6: Use state_lock to protect ifa state
ipv6: Replace inet6_ifaddr->dead with state
cxgb4: notify upper drivers if the device is already up when they load
cxgb4: keep interrupts available when the ports are brought down
cxgb4: fix initial addition of MAC address
cnic: Return SPQ credit to bnx2x after ring setup and shutdown.
cnic: Convert cnic_local_flags to atomic ops.
can: Fix SJA1000 command register writes on SMP systems
bridge: fix build for CONFIG_SYSFS disabled
ARCNET: Limit com20020 PCI ID matches for SOHARD cards
Fix up various conflicts with pcmcia tree drivers/net/
{pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and
wireless/orinoco/spectrum_cs.c} and feature removal
(Documentation/feature-removal-schedule.txt).
Also fix a non-content conflict due to pm_qos_requirement getting
renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
Chip model can now be selected directly by matching the modalias name
(instead of filling the .model field in platform_data), and allows the
module to be auto-loaded. Previous behaviour is of course still supported.
Convert the two in-tree users to this feature (icontrol & zeus).
Tested on an Zeus platform (mcp2515).
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Christian Pellegrin <chripell@fsfe.org>
Cc: Edwin Peer <epeer@tmtservices.co.za>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Amit Walambe <amit.walambe@eurotech.com>
Add some safety check for CONFIG_PM around zeus_power_off(). Without
it linking can fail like this:
arch/arm/mach-pxa/built-in.o: In function `zeus_power_off':
e800.c:(.text+0x2bc8): undefined reference to `pxa27x_cpu_suspend'
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
