As PHYS_OFFSET will be becoming a variable, we can't have it used in
initializers nor assembly code. Replace those in generic code with
a run-time initialization. Replace those in platform code using the
individual platform specific PLAT_PHYS_OFFSET.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Since f0fba2ad1b it's required to register platform devices even for
AC'97 codecs. Register one on tosa (wm9712-codec).
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
pxa25x platforms were left out of major ASoC Update patch.
Since f0fba2ad1b a registration of pxa-pcm-audio device is required for
ASoC to function on pxa platforms. Register one also for pxa210/pxa25x.
Since 2e48928d8a0f38c1b5c81eb3f1294de8a6382c68 it's no longer possible to set
the name of the LED trigger for RFKILL events. Drop respective code from tosa-bt.c
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: John W. Linville <linville@tuxdriver.com>
Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com>
The use of wrong SD detect pin was introduced by this commit:
ARM: pxa: Push Colibri evalboard MFP into module files
This fixes it.
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits)
ARM: pxa: fix building issue of missing physmap.h
ARM: mmp: PXA910 drive strength FAST using wrong value
ARM: mmp: MMP2 drive strength FAST using wrong value
ARM: pxa: fix recursive calls in pxa_low_gpio_chip
AT91: Support for gsia18s board
AT91: Acme Systems FOX Board G20 board files
AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h
ARM: pxa: fix suspend/resume array index miscalculation
ARM: pxa: use cpu_has_ipr() consistently in irq.c
ARM: pxa: remove unused variable in clock-pxa3xx.c
ARM: pxa: fix warning in zeus.c
ARM: sa1111: fix typo in sa1111_retrigger_lowirq()
ARM mxs: clkdev related compile fixes
ARM i.MX mx31_3ds: Fix MC13783 regulator names
ARM: plat-stmp3xxx: irq_data conversion.
ARM: plat-spear: irq_data conversion.
ARM: plat-orion: irq_data conversion.
ARM: plat-omap: irq_data conversion.
ARM: plat-nomadik: irq_data conversion.
ARM: plat-mxc: irq_data conversion.
Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert
Buytenhek's irq_data conversion clashing with some omap irq updates)
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: fix missing branch in __error_a
ARM: fix /proc/$PID/stack on SMP
ARM: Fix build regression on SA11x0, PXA, and H720x targets
ARM: 6625/1: use memblock memory regions for "System RAM" I/O resources
ARM: fix wrongly patched constants
ARM: 6624/1: fix dependency for CONFIG_SMP_ON_UP
ARM: 6623/1: Thumb-2: Fix out-of-range offset for Thumb-2 in proc-v7.S
ARM: 6622/1: fix dma_unmap_sg() documentation
ARM: 6621/1: bitops: remove condition code clobber for CLZ
ARM: 6620/1: Change misleading warning when CONFIG_CMDLINE_FORCE is used
ARM: 6619/1: nommu: avoid mapping vectors page when !CONFIG_MMU
ARM: sched_clock: make minsec argument to clocks_calc_mult_shift() zero
ARM: sched_clock: allow init_sched_clock() to be called early
ARM: integrator: fix compile warning in cpu.c
ARM: 6616/1: Fix ep93xx-fb init/exit annotations
ARM: twd: fix display of twd frequency
ARM: udelay: prevent math rounding resulting in short udelays
Tested-by: Marek Vasut <marek.vasut@gmail.com>
Build errors similar this appeared in todays kautobuild for the above
targets:
In file included from arch/arm/include/asm/pgtable.h:461,
from arch/arm/mach-pxa/generic.c:26:
include/asm-generic/pgtable.h: In function 'ptep_test_and_clear_young':
include/asm-generic/pgtable.h:29: error: dereferencing pointer to incomplete type
None of the .c files including asm/pgtable.h with this error is using
this header, so simply remove the include.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits)
spi/omap: Fix DMA API usage in OMAP MCSPI driver
spi/imx: correct the test on platform_get_irq() return value
spi/topcliff: Typo fix threhold to threshold
spi/dw_spi Typo change diable to disable.
spi/fsl_espi: change the read behaviour of the SPIRF
spi/mpc52xx-psc-spi: move probe/remove to proper sections
spi/dw_spi: add DMA support
spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs
spi/dw_spi: Fix too short timeout in spi polling loop
spi/pl022: convert running variable
spi/pl022: convert busy flag to a bool
spi/pl022: pass the returned sglen to the DMA engine
spi/pl022: map the buffers on the DMA engine
spi/topcliff_pch: Fix data transfer issue
spi/imx: remove autodetection
spi/pxa2xx: pass of_node to spi device and set a parent device
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add CE4100 support
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
arch/arm/mach-pxa/clock.c
arch/arm/mach-pxa/clock.h
arch/arm/Kconfig
arch/arm/common/Makefile
arch/arm/kernel/Makefile
arch/arm/kernel/smp.c
arch/arm/kernel/entry-armv.S
arch/arm/mm/ioremap.c
arch/arm/mach-vexpress/v2m.c
arch/arm/plat-omap/counter_32k.c
arch/arm/plat-versatile/Makefile
Before this patch, the following error would sometimes occur after a
resume on pxa3xx:
/path/to/mm/memory.c:144: bad pmd 8040542e.
The problem was that a temporary page table mapping was being improperly
restored.
The PXA3xx resume code creates a temporary mapping of resume_turn_on_mmu
to avoid a prefetch abort. The pxa3xx_resume_after_mmu code requires
that the r1 register holding the address of this mapping not be
modified, however, resume_turn_on_mmu does modify it. It is mostly
correct in that r1 receives the base table address, but it may also
get other bits in 13:0. This results in pxa3xx_resume_after_mmu
restoring the original mapping to the wrong place, corrupting memory
and leaving the temporary mapping in place.
Signed-off-by: Matt Reimer <mreimer@sdgsystems.com>
As arch/arm/mach-pxa/eseries.c references w100fb_gpio_{read,write}()
directly.
* 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/next
spi/pxa2xx: register driver properly
spi/pxa2xx: add support for shared IRQ handler
spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbers
arm/pxa2xx: reorgazine SSP and SPI header files
flush_scheduled_work() is deprecated and scheduled to be removed.
Directly flush toggle_charger and sharpsl_bat works on suspend
instead.
Convert pxa to use the new sched_clock() infrastructure for extending
32bit counters to full 64-bit nanoseconds.
Tested-by: Eric Miao <eric.y.miao@gmail.com>
ftrace requires sched_clock() to be notrace. Ensure that all
implementations are so marked. Also make sure that they include
linux/sched.h
Also ensure OMAP clocksource read functions are marked notrace as
they're used for sched_clock() too.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Olof Johansson <olof@lixom.net>
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
The new FPGA firmware in Balloon3 uses different methods to control it's bus
control lines. In the new version, there are separate registers to set/clear
bus control lines. This patch updates affected places.
Tested on a Colibri Evaluation Board Rev.2.1 with a Colibri PXA310 module.
Signed-off-by: Bjorn Forsman <bjorn.forsman@gmail.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Acked-by: Daniel Mack <daniel@caiaq.de>
Rename colibri-pxa270-evalboard to colibri-evalboard as this board is used with
all Colibri modules.
This change -- pushing the MFP configuration back into Module files -- is
necessary because some evalboards can be used with multiple modules, where MFP
differs from module to module. Therefore MFP isn't board-specific, but
module-specific and the module should preconfigure itself for the board.
(And there is also the C preprocesor limitation and conflicting #define-s)
This driver also contains structures to eventually support PXA320. This is
planned to be added in a later patch.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Saarb platform is a handheld platform that supports Marvell PXA955 silicon.
The core of PXA955 is PJ4. Add new PJ4 support. And add new macro
CONFIG_PXA95x.
