path: root/arch/arm/mach-pxa
2017-01-15ARM: pxa: fix pxa25x interrupt initRobert Jarzmik
commit e413bd33ac44b6d0bebc0ef2ac19cbe7558a7303 upstream. In the device-tree case, the root interrupt controller cannot be accessed through the 6th coprocessor, contrary to pxa27x and pxa3xx architectures. Fix it to behave as in non-devicetree builds. Fixes: 32f17997c130 ("ARM: pxa: remove irq init from dt machines") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - We get support for running in big-endian mode on two platforms: sunxi (Allwinner) and s3c24xx (old Samsung). - The recently added Uniphier platform now uses standard PSCI methods for SMP booting and we remove support for old bootloader versions that did not support it yet. - In sunxi, we gain support for the "Nextthing GR8" SoC, which is a close relative of the Allwinner A13 and R8 chips. - PXA completes its move over to the generic dmaengine framework and removes its old private API - mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC with integrated 802.11ac wireless networking" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: imx legacy: pca100: move peripheral initialization to .init_late ARM: imx legacy: mx27ads: move peripheral initialization to .init_late ARM: imx legacy: mx21ads: move peripheral initialization to .init_late ARM: imx legacy: pcm043: move peripheral initialization to .init_late ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late ARM: imx legacy: vpr200: move peripheral initialization to .init_late ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late ARM: imx legacy: qong: move peripheral initialization to .init_late ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late ARM: imx legacy: pcm037: move peripheral initialization to .init_late ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late ARM: imx legacy: mx31ads: move peripheral initialization to .init_late ARM: imx legacy: mx31lite: move peripheral initialization to .init_late ARM: imx legacy: kzm: move peripheral initialization to .init_late MAINTAINERS: update list of Oxnas maintainers ARM: orion5x: remove extraneous NO_IRQ ARM: orion: simplify orion_ge00_switch_init ...
2016-10-05Merge tag 'gpio-v4.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.9 series: Subsystem improvements: - do away with the last users of the obsolete Kconfig options ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter always sounded like an item on a wishlist to Santa Claus to me). We can now select GPIOLIB and be done with it, for all archs. After some struggle it even work on UM. Not that it has GPIO, but if it wants to, it can select the library. - continued efforts to make drivers properly either tristate or bool. - introduce a warning for drivers assigning default triggers to their irqchip lines when probed from device tree, so we find and fix these ambigous drivers. It is agreed that in the OF config path, the device tree defines trigger characteristics. - the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips. - we introduce the ability to mark certain IRQ lines as "unusable" as they can be taken by BIOS/firmware, unrouted in silicon and generally nasty if you use them, and such things. This is put to good use in the STMPE driver and also in the Cherryview pin control driver. - a new "mockup" virtual GPIO device that can be used for testing. The plan is to add unit tests under tools/* for exercising this device and verify that the kernel code paths are working as they should. - make memory-mapped I/O-drivers depend on HAS_IOMEM. This was implicit all the time, but when people started building UM with allyesconfig or allmodconfig it exploded in their face. - move some stray bits of device tree and ACPI HW description callbacks down into their respective implementation silo. These were causing issues when compiling on !HAS_IOMEM as well, so now eventually UM compiles the GPIOLIB library if it wants to. New drivers: - new driver for the Aspeed GPIO front-end companion to the pin controller merged through the pin control tree. - new driver for the LP873x PMIC GPIO portions. - new driver for Technologic Systems' I2C FPGA GPIO such as TS4900, TS-7970, TS-7990 and TS-4100. - new driver for the Broadcom BCM63xx series including BCM6338 and BCM6345. - new driver for the Intel WhiskeyCove PMIC GPIO. - new driver for the Allwinner AXP209 PMIC GPIO portions. - new driver for Diamond Systems 48 line GPIO-MM, another of these port-mapped I/O expansion cards. - support the STMicroelectronics STMPE1600 variant in the STMPE driver. Driver improvements: - the STMPE driver now supports rising/falling edge detection properly for IRQs. - the PCA954x will now fetch and enable its VCC regulator properly. - major rework of the PCA953x driver with the goal of eventually switching it over to use regmap and thus modernize it even more. - switch the IOP driver to use the generic MMIO GPIO library. - move the ages old HTC EGPIO (extended GPIO) GPIO expander driver over to this subsystem from MFD, achieveing some separation of concerns" * tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits) gpio: add missing static inline gpio: OF: localize some gpiochip init functions gpio: acpi: separation of concerns gpio: OF: separation of concerns gpio: make memory-mapped drivers depend on HAS_IOMEM gpio: stmpe: use BIT() macro gpio: stmpe: forbid unused lines to be mapped as IRQs mfd/gpio: Move HTC GPIO driver to GPIO subsystem gpio: MAINTAINERS: Add an entry for GPIO mockup driver gpio/mockup: add virtual gpio device gpio: Added zynq specific check for special pins on bank zero gpio: axp209: Implement get_direction gpio: aspeed: remove redundant return value check gpio: loongson1: remove redundant return value check ARM: omap2: fix missing include gpio: tc3589x: fix up complaints on unsigned gpio: tc3589x: add .get_direction() and small cleanup gpio: f7188x: use gpiochip_get_data instead of container_of gpio: tps65218: use devm_gpiochip_add_data() for gpio registration gpio: aspeed: fix return value check in aspeed_gpio_probe() ...
2016-09-28Merge branch 'ib-move-htc-egpio' into develLinus Walleij
2016-09-28mfd/gpio: Move HTC GPIO driver to GPIO subsystemLinus Walleij
The HTC GPIO driver is a pure GPIO driver and I just can not see what it is doing inside MFD. Let's just move it to GPIO and take this opportunity to move the platform data to <linux/platform_data/gpio-htc-egpio.h> Cc: arm@kernel.org Cc: Russell King <linux@armlinux.org.uk> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-15Merge tag 'pxa-for-4.9' of https://github.com/rjarzmik/linux into next/socArnd Bergmann
Pull "This is the pxa changes for v4.9 cycle" from Robert Jarzmik: This cycle is covering : - the removal of the legacy DMA API This is the major contributor to the negative diffstat, as dmaengine have taken over in this area. - IDE subsystem defconfig fixes - preparation for pxa25x to be device-tree compliant - various irq related fixes * tag 'pxa-for-4.9' of https://github.com/rjarzmik/linux: ARM: pxa: pxa_cplds: fix interrupt handling ARM: pxa: remove irq init from dt machines ARM: pxa: Use kmalloc_array() in pxa_pm_init() ARM: pxa: magician: Remove duplicated I2C pins declaration ARM: pxa: fix GPIO double shifts arm: trizeps4_defconfig: disable IDE subsystem arm: pxa255-idp_defconfig: disable IDE subsystem arm: lpda270_defconfig: disable IDE subsystem arm: colibri_pxa270_defconfig: disable IDE subsystem ARM: pxa: add pxa25x device-tree support ARM: pxa: prepare pxa25x interrupts for device-tree platforms ARM: pxa: remove platform dma code ARM: pxa: remove devicetree boards from pxa_defconfig
2016-09-12ARM: pxa/lubbock: add pcmcia clockRussell King
Add the required PCMCIA clock for the SA1111 "1800" device. This clock is used to compute timing information for the PCMCIA interface in the SoC device, rather than the SA1111. Hence, the provision of this clock is a convenience for the driver and does not reflect the hardware, so this must not be copied into DT. Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2016-09-09ARM: pxa: pxa_cplds: fix interrupt handlingRobert Jarzmik
Since its initial commit, the driver is buggy for multiple interrupts handling. The translation from the former lubbock.c file was not complete, and might stall all interrupt handling when multiple interrupts occur. This is especially true when inside the interrupt handler and if a new interrupt comes and is not handled, leaving the output line still held, and not creating a transition as the GPIO block behind would expect to trigger another cplds_irq_handler() call. For the record, the hardware is working as follows. The interrupt mechanism relies on : - one status register - one mask register Let's suppose the input irq lines are called : - i_sa1111 - i_lan91x - i_mmc_cd Let's suppose the status register for each irq line is called : - status_sa1111 - status_lan91x - status_mmc_cd Let's suppose the interrupt mask for each irq line is called : - irqen_sa1111 - irqen_lan91x - irqen_mmc_cd Let's suppose the output irq line, connected to GPIO0 is called : - o_gpio0 The behavior is as follows : - o_gpio0 = not((status_sa1111 & irqen_sa1111) | (status_lan91x & irqen_lan91x) | (status_mmc_cd & irqen_mmc_cd)) => this is a N-to-1 NOR gate and multiple AND gates - irqen_* is exactly as programmed by a write to the FPGA - status_* behavior is governed by a bi-stable D flip-flop => on next FPGA clock : - if i_xxx is high, status_xxx becomes 1 - if i_xxx is low, status_xxx remains as it is - if software sets status_xxx to 0, the D flip-flop is reset => status_xxx becomes 0 => on next FPGA clock cycle, if i_xxx is high, status_xxx becomes 1 again Fixes: fc9e38c0f4d3 ("ARM: pxa: lubbock: use new pxa_cplds driver") Reported-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-09-09ARM: pxa: remove irq init from dt machinesRobert Jarzmik
The init_irq and handle_irq can be declared through standard irqchip declaration and are not necessary in machine descriptions. This is another step towards the generic kernel for the pxa architecture. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Arnd Bergmann <arnd@arndb.de>
2016-09-09ARM: pxa: Use kmalloc_array() in pxa_pm_init()Markus Elfring
* A multiplication for the size determination of a memory allocation indicated that an array data structure should be processed. Thus use the corresponding function "kmalloc_array". This issue was detected by using the Coccinelle software. * Replace the specification of a data type by a pointer dereference to make the corresponding size determination a bit safer according to the Linux coding style convention. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-09-09ARM: pxa: magician: Remove duplicated I2C pins declarationPetr Cvek
Magician has GPIO117_I2C_SCL and GPIO118_I2C_SDA pins declared twice. Signed-off-by: Petr Cvek <petr.cvek@tul.cz> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-09-09ARM: pxa: fix GPIO double shiftsRobert Jarzmik
The commit 9bf448c66d4b ("ARM: pxa: use generic gpio operation instead of gpio register") from Oct 17, 2011, leads to the following static checker warning: arch/arm/mach-pxa/spitz_pm.c:172 spitz_charger_wakeup() warn: double left shift '!gpio_get_value(SPITZ_GPIO_KEY_INT) << (1 << ((SPITZ_GPIO_KEY_INT) & 31))' As Dan reported, the value is shifted three times : - once by gpio_get_value(), which returns either 0 or BIT(gpio) - once by the shift operation '<<' - a last time by GPIO_bit(gpio) which is BIT(gpio) Therefore the calculation lead to a chained or operator of : - (1 << gpio) << (1 << gpio) = (2^gpio)^gpio = 2 ^ (gpio * gpio) It is be sheer luck the former statement works, only because each gpio used is strictly smaller than 6, and therefore 2^(gpio^2) never overflows a 32 bits value, and because it is used as a boolean value to check a gpio activation. As the xxx_charger_wakeup() functions are used as a true/false detection mechanism, take that opportunity to change their prototypes from integer return value to boolean one. Fixes: 9bf448c66d4b ("ARM: pxa: use generic gpio operation instead of gpio register") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-08-28net: smc91x: fix SMC accessesRussell King
Commit b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines") broke some ARM platforms through several mistakes. Firstly, the access size must correspond to the following rule: (a) at least one of 16-bit or 8-bit access size must be supported (b) 32-bit accesses are optional, and may be enabled in addition to the above. Secondly, it provides no emulation of 16-bit accesses, instead blindly making 16-bit accesses even when the platform specifies that only 8-bit is supported. Reorganise smc91x.h so we can make use of the existing 16-bit access emulation already provided - if 16-bit accesses are supported, use 16-bit accesses directly, otherwise if 8-bit accesses are supported, use the provided 16-bit access emulation. If neither, BUG(). This exactly reflects the driver behaviour prior to the commit being fixed. Since the conversion incorrectly cut down the available access sizes on several platforms, we also need to go through every platform and fix up the overly-restrictive access size: Arnd assumed that if a platform can perform 32-bit, 16-bit and 8-bit accesses, then only a 32-bit access size needed to be specified - not so, all available access sizes must be specified. This likely fixes some performance regressions in doing this: if a platform does not support 8-bit accesses, 8-bit accesses have been emulated by performing a 16-bit read-modify-write access. Tested on the Intel Assabet/Neponset platform, which supports only 8-bit accesses, which was broken by the original commit. Fixes: b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-11Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A couple of bug fixes have come in for v4.8 so far. Since the first few were originally meant to go into -rc1 (but didn't get sent in time for travel reasons), the branch is unfortunately based on top of a commit in the middle of the merge window rather than -rc1. Content-wise we have: - a fix for the last remaining broken build in kernelci, getting mach-shmobile to build again with SMP disabled - a fix for a realview regression that broke real hardware but not the qemu model that everyone uses in practice (needed for v4.7 as well) - a merge conflict fix for Tegra that also broke v4.7 - two Kconfig fixes for arm64 build regressions - a couple of arm32 build warning fixes (all harmless) - fix the RTC on Exynos7 Espresso (which apparently never worked right)" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Merge tag 'pxa-fixes-v4.8' of https://github.com/rjarzmik/linux into randconfig-4.8 arm64: Kconfig: select HISILICON_IRQ_MBIGEN only if PCI is selected arm64: Kconfig: select ALPINE_MSI only if PCI is selected ARM: dts: realview: Fix PBX-A9 cache description ARM: tegra: fix erroneous address in dts ARM: dts: add syscon compatible string for AP syscon ARM: dts: add syscon compatible string for CP syscon ARM: oxnas: select reset controller framework ARM: hide mach-*/ include for ARM_SINGLE_ARMV7M ARM: don't include removed directories Revert "ARM: aspeed: adapt defconfigs for new CONFIG_PRINTK_TIME" ARM: shmobile: don't call platform_can_secondary_boot on UP MAINTAINER: alpine: add a mailing list ARM: do away with final ARCH_REQUIRE_GPIOLIB arm64: dts: Fix RTC by providing rtc_src clock
2016-08-11Merge tag 'pxa-fixes-v4.8' of https://github.com/rjarzmik/linux into ↵Arnd Bergmann
randconfig-4.8 This is the pxa changes for v4.8 cycle. This is a tiny fix couple to enable changes in includes in gpio API without breaking pxa boards. * tag 'pxa-fixes-v4.8' of https://github.com/rjarzmik/linux: ARM: pxa: add module.h for corgi symbol_get/symbol_put usage ARM: pxa: add module.h for spitz symbol_get/symbol_put usage
2016-08-09ARM: pxa: add pxa25x device-tree supportRobert Jarzmik
Add a device-tree machine entry (DT_MACHINE_START) for pxa25x based platforms. Take the opportunity to sort the file machine descriptions by alphabetical order. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-08-09ARM: pxa: prepare pxa25x interrupts for device-tree platformsRobert Jarzmik
Add the device-tree interrupts initialization function required to have a generic pxa25x device-tree machine. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-08-09ARM: pxa: remove platform dma codeRobert Jarzmik
As the last pxa related driver was converted to dmaengine, it's time to kill the legacy dma code, which is not used anymore. This finishes the pxa dmaengine transition. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-08-05Merge tag 'rtc-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.8 Cleanups: - huge cleanup of rtc-generic and char/genrtc this allowed to cleanup rtc-cmos, rtc-sh, rtc-m68k, rtc-powerpc and rtc-parisc - move mn10300 to rtc-cmos Subsystem: - fix wakealarms after hibernate - multiples fixes for rctest - simplify implementations of .read_alarm New drivers: - Maxim MAX6916 Drivers: - ds1307: fix weekday - m41t80: add wakeup support - pcf85063: add support for PCF85063A variant - rv8803: extend i2c fix and other fixes - s35390a: fix alarm reading, this fixes instant reboot after shutdown for QNAP TS-41x - s3c: clock fixes" * tag 'rtc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (65 commits) rtc: rv8803: Clear V1F when setting the time rtc: rv8803: Stop the clock while setting the time rtc: rv8803: Always apply the I²C workaround rtc: rv8803: Fix read day of week rtc: rv8803: Remove the check for valid time rtc: rv8803: Kconfig: Indicate rx8900 support rtc: asm9260: remove .owner field for driver rtc: at91sam9: Fix missing spin_lock_init() rtc: m41t80: add suspend handlers for alarm IRQ rtc: m41t80: make it a real error message rtc: pcf85063: Add support for the PCF85063A device rtc: pcf85063: fix year range rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracy rtc: explicitly set tm_sec = 0 for drivers with minute accurancy rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq() rtc: s3c: Remove unnecessary call to disable already disabled clock rtc: abx80x: use devm_add_action_or_reset() rtc: m41t80: use devm_add_action_or_reset() rtc: fix a typo and reduce three empty lines to one rtc: s35390a: improve two comments in .set_alarm ...
2016-07-09rtc: v3020: move rtc-v3020.h to platform_dataAlexandre Belloni
rtc-v3020.h belongs to include/linux/platform_data/ Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-27arm: use the new LED disk activity triggerStephan Linz
- dts: rename 'ide-disk' to 'disk-activity' - platform: rename 'ide-disk' to 'disk-activity' - defconfig: rename 'LEDS_TRIGGER_IDE_DISK' to 'LEDS_TRIGGER_DISK' Signed-off-by: Stephan Linz <linz@li-pro.net> Acked-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2016-05-24Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "This is a first set of bug fixes on top of what was merged for 4.7. Two patches for lpc32xx address a harmless build warning that was just introduced, one patch for the mediatek soc driver fixes a warning for arm64, and the pxa changes are minor cleanups that should have been part of the original pull requests but that I forgot to apply to the cleanup-fixes branch earlier" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: lpc32xx: fix NR_IRQS confict ARM: lpc32xx: remove legacy irq controller driver soc: mtk-pmic-wrap: avoid integer overflow warning ARM: pxa: Remove CLK_IS_ROOT ARM: pxa: activate pinctrl for device-tree machines
2016-05-24Merge tag 'for-linus-20160523' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "First cycle with Boris as NAND maintainer! Many (most) bullets stolen from him. Generic: - Migrated NAND LED trigger to be a generic MTD trigger NAND: - Introduction of the "ECC algorithm" concept, to avoid overloading the ECC mode field too much more - Replaced the nand_ecclayout infrastructure with something a little more flexible (finally!) and future proof - Rework of the OMAP GPMC and NAND drivers; the TI folks pulled some of this into their own tree as well - Prepare the sunxi NAND driver to receive DMA support - Handle bitflips in erased pages on GPMI revisions that do not support this in hardware. SPI NOR: - Start using the spi_flash_read() API for SPI drivers that support it (i.e., SPI drivers with special memory-mapped flash modes) And other small scattered improvments" * tag 'for-linus-20160523' of git://git.infradead.org/linux-mtd: (155 commits) mtd: spi-nor: support GigaDevice gd25lq64c mtd: nand_bch: fix spelling of "probably" mtd: brcmnand: respect ECC algorithm set by NAND subsystem gpmi-nand: Handle ECC Errors in erased pages Documentation: devicetree: deprecate "soft_bch" nand-ecc-mode value mtd: nand: add support for "nand-ecc-algo" DT property mtd: mtd: drop NAND_ECC_SOFT_BCH enum value mtd: drop support for NAND_ECC_SOFT_BCH as "soft_bch" mapping mtd: nand: read ECC algorithm from the new field mtd: nand: fsmc: validate ECC setup by checking algorithm directly mtd: nand: set ECC algorithm to Hamming on fallback staging: mt29f_spinand: set ECC algorithm explicitly CRIS v32: nand: set ECC algorithm explicitly mtd: nand: atmel: set ECC algorithm explicitly mtd: nand: davinci: set ECC algorithm explicitly mtd: nand: bf5xx: set ECC algorithm explicitly mtd: nand: omap2: Fix high memory dma prefetch transfer mtd: nand: omap2: Start dma request before enabling prefetch mtd: nandsim: add __init attribute mtd: nand: move of_get_nand_xxx() helpers into nand_base.c ...
2016-05-20Merge tag 'pxa-for-4.7' of https://github.com/rjarzmik/linux into fixesArnd Bergmann
Merge "pxa changes for v4.7 cycle" from Robert Jarzmik: This is a minor cycle with : - cleanup fix from Stephen on clocks (CLK_ROOT deprecated) - pin control activation for device-tree platforms * tag 'pxa-for-4.7' of https://github.com/rjarzmik/linux: ARM: pxa: Remove CLK_IS_ROOT ARM: pxa: activate pinctrl for device-tree machines These should have been part of the original pull request but got accidentally dropped. Both changes in this branch can be considered bugfixes, so I'm putting them in the fixes branch now.
2016-05-06Merge back new device properties material for v4.7.Rafael J. Wysocki
2016-05-05mtd: nand: sharpsl: switch to mtd_ooblayout_opsBoris Brezillon
Implementing the mtd_ooblayout_ops interface is the new way of exposing ECC/OOB layout to MTD users. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2016-04-30ARM: pxa: Remove CLK_IS_ROOTStephen Boyd
This flag is a no-op now (see commit 47b0eeb3dc8a "clk: Deprecate CLK_IS_ROOT", 2016-02-02) so remove it. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2016-04-30ARM: pxa: activate pinctrl for device-tree machinesRobert Jarzmik
Pincontrol is not yet ready for all PXA platforms. For example, a legacy platform, if PINCTRL was activated, will fail its calls to gpio_request() or gpio_direction_output(), as the pinctrl driver might not be available, such as for pxa25x and pxa3xx. As a step forward, activate pincontrol for all device-tree available machines, ie. pxa27x device-tree based and pxa3xx device-tree based. If it appears later that pincontrol is also required for legacy platforms and if the mfp->pinctrl conversion can be achieved, then PINCTRL will be activated for the whole PXA architecture. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-09device property: don't bother the drivers with struct property_setHeikki Krogerus
Since device_add_property_set() now always takes a copy of the property_set, and also since the fwnode type is always hard coded to be FWNODE_PDATA, there is no need for the drivers to deliver the entire struct property_set. The function can just create the instance of it on its own and bind the properties from the drivers to it on the spot. This renames device_add_property_set() to device_add_properties(). The function now takes struct property_entry as its parameter instead of struct property_set. Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-03-29ARM: pxa: fix the number of DMA requestor linesRobert Jarzmik
The number of requestor lines was clamped to 0 for all pxa architectures in the requestor declaration. Fix this by using the value. Fixes: 72b195cb7162 ("ARM: pxa: add the number of DMA requestor lines") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-03-20Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "Newly added support for additional SoCs: - Axis Artpec-6 SoC family - Allwinner A83T SoC - Mediatek MT7623 - NXP i.MX6QP SoC - ST Microelectronics stm32f469 microcontroller New features: - SMP support for Mediatek mt2701 - Big-endian support for NXP i.MX - DaVinci now uses the new DMA engine dma_slave_map - OMAP now uses the new DMA engine dma_slave_map - earlyprintk support for palmchip uart on mach-tango - delay timer support for orion Other: - Exynos PMU driver moved out to drivers/soc/ - Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP, uniphier" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: uniphier: rework SMP code to support new System Bus binding ARM: uniphier: add missing of_node_put() ARM: at91: avoid defining CONFIG_* symbols in source code ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1 ARM: imx: Make reset_control_ops const ARM: imx: Do L2 errata only if the L2 cache isn't enabled ARM: imx: select ARM_CPU_SUSPEND only for imx6 dmaengine: pxa_dma: fix the maximum requestor line ARM: alpine: select the Alpine MSI controller driver ARM: pxa: add the number of DMA requestor lines dmaengine: mmp-pdma: add number of requestors dma: mmp_pdma: Add the #dma-requests DT property documentation ARM: OMAP2+: Add rtc hwmod configuration for ti81xx ARM: s3c24xx: Avoid warning for inb/outb ARM: zynq: Move early printk virtual address to vmalloc area ARM: DRA7: hwmod: Add custom reset handler for PCIeSS ARM: SAMSUNG: Remove unused register offset definition ARM: EXYNOS: Cleanup header files inclusion drivers: soc: samsung: Enable COMPILE_TEST MAINTAINERS: Add maintainers entry for drivers/soc/samsung ...
2016-03-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "The most notable item is addition of support for Synaptics RMI4 protocol which is native protocol for all current Synaptics devices (touchscreens, touchpads). In later releases we'll switch devices using HID and PS/2 protocol emulation to RMI4. You will also get: - BYD PS/2 touchpad protocol support for psmouse - MELFAS MIP4 Touchscreen driver - rotary encoder was moved away from legacy platform data and to generic device properties API, devm_* API, and can now handle encoders using more than 2 GPIOs - Cypress touchpad driver was switched to devm_* API and device properties - other assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) ARM: pxa/raumfeld: use PROPERTY_ENTRY_INTEGER to define props Input: synaptics-rmi4 - using logical instead of bitwise AND Input: powermate - fix oops with malicious USB descriptors Input: snvs_pwrkey - fix returned value check of syscon_regmap_lookup_by_phandle() MAINTAINERS: add devicetree bindings to Input Drivers section Input: synaptics-rmi4 - add device tree support to the SPI transport driver Input: synaptics-rmi4 - add SPI transport driver Input: synaptics-rmi4 - add support for F30 Input: synaptics-rmi4 - add support for F12 Input: synaptics-rmi4 - add device tree support for 2d sensors and F11 Input: synaptics-rmi4 - add support for 2D sensors and F11 Input: synaptics-rmi4 - add device tree support for RMI4 I2C devices Input: synaptics-rmi4 - add I2C transport driver Input: synaptics-rmi4 - add support for Synaptics RMI4 devices Input: ad7879 - add device tree support Input: ad7879 - fix default x/y axis assignment Input: ad7879 - move header to platform_data directory Input: ts4800 - add hardware dependency Input: cyapa - fix for losing events during device power transitions Input: sh_keysc - remove dependency on SUPERH ...
2016-03-15ARM: pxa/raumfeld: use PROPERTY_ENTRY_INTEGER to define propsArnd Bergmann
gcc-6.0 notices that the use of the property_entry in this file that was recently introduced cannot work right, as we initialize the wrong field: raumfeld.c:387:3: error: the address of 'raumfeld_rotary_encoder_steps' will always evaluate as 'true' [-Werror=address] DEV_PROP_U32, 1, &raumfeld_rotary_encoder_steps, }, ^~~~~~~~~~~~ raumfeld.c:389:3: error: the address of 'raumfeld_rotary_encoder_axis' will always evaluate as 'true' [-Werror=address] DEV_PROP_U32, 1, &raumfeld_rotary_encoder_axis, }, ^~~~~~~~~~~~ raumfeld.c:391:3: error: the address of 'raumfeld_rotary_encoder_relative_axis' will always evaluate as 'true' [-Werror=address] DEV_PROP_U32, 1, &raumfeld_rotary_encoder_relative_axis, }, ^~~~~~~~~~~~ The problem appears to stem from relying on an old definition of 'struct property', but it has changed several times since the code could have last been correct. This changes the code to use the PROPERTY_ENTRY_INTEGER() macro instead, which works fine for the current definition and is a safer way of doing the initialization. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: a9e340dce3c3 ("Input: rotary_encoder - move away from platform data structure") Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-03-15Merge tag 'v4.5' into nextDmitry Torokhov
Merge with Linux 4.5 to get PROPERTY_ENTRY_INTEGER() that is needed to fix pxa/raumfeld rotary encoder properties.
2016-03-04usb: gadget: pxa25x_udc: move register definitions from archArnd Bergmann
ixp4xx and pxa25x both use this driver and provide a slightly different set of register definitions for it. Aside from that, the definition in the ixp4xx-regs.h header conflicts with the on in the pxa27x device driver when compile-testing that: In file included from ../drivers/usb/gadget/udc/pxa27x_udc.c:37:0: ../drivers/usb/gadget/udc/pxa27x_udc.h:26:0: warning: "UDCCR" redefined #define UDCCR 0x0000 /* UDC Control Register */ ^ In file included from ../arch/arm/mach-ixp4xx/include/mach/hardware.h:27:0, from ../arch/arm/mach-ixp4xx/include/mach/io.h:18, from ../arch/arm/include/asm/io.h:194, from ../include/linux/io.h:25, from ../include/linux/irq.h:24, from ../drivers/usb/gadget/udc/pxa27x_udc.c:23: ../arch/arm/mach-ixp4xx/include/mach/ixp4xx-regs.h:415:0: note: this is the location of the previous definition #define UDCCR IXP4XX_USB_REG(IXP4XX_USB_BASE_VIRT+0x0000) This addresses both issues by moving all the definitions into the pxa25x_udc driver itself. It turns out the only difference between them was 'UDCCS_IO_ROF', and that could well be a mistake when it was incorrectly copied from pxa25x to ixp4xx. Acked-by: Krzysztof Halasa <khalasa@piap.pl> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Felipe Balbi <balbi@kernel.org>
2016-03-02Input: rotary_encoder - move away from platform data structureDmitry Torokhov
Drop support for platform data passed via a C-structure and switch to device properties instead, which should make the driver compatible with all platforms: OF, ACPI and static boards. Static boards should use property sets to communicate device parameters to the driver. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-03-02Input: rotary_encoder - convert to use gpiod APIDmitry Torokhov
Instead of using old GPIO API, let's switch to GPIOD API, which automatically handles polarity. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-02-26ARM: pxa: add the number of DMA requestor linesRobert Jarzmik
Declare the number of DMA requestor lines per platform : - for pxa25x: 40 requestor lines - for pxa27x: 75 requestor lines - for pxa3xx: 100 requestor lines This information will be used to activate the DMA flow control or not. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-20ARM: pxa: pxa3xx device-tree support cleanupRobert Jarzmik
Clocks, timer and several other drivers have well defined and working device-tree bindings. Clean-up the code to leave only the strict minimum. The final goal will be to remove the lookup array. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: don't select RFKILL if CONFIG_NET is disabledArnd Bergmann
Bluetooth is only supported when network support is part of the kernel, so it is a bit pointless to build the tosa-bt support without networking. If we try anyway, we get a Kconfig warning: warning: (TOSA_BT && H1940BT) selects RFKILL which has unmet direct dependencies (NET) This adds a dependency on CONFIG_NET to avoid that case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: fix building without IWMMXTArnd Bergmann
When CONFIG_IWMMXT, the pxa3xx and pxa27x suspend/resume code emits some xscale specific instructions, which are rejected by the assembler, because gcc is built with -march=armv5 -mtune=xscale and passes that option to the assembler: /tmp/cciHumzr.s:553: Error: selected processor does not support ARM mode `mra r2,r3,acc0' /tmp/cciHumzr.s:605: Error: selected processor does not support ARM mode `mar acc0,r2,r3' make[3]: *** [arch/arm/mach-pxa/pxa3xx.o] Error 1 /tmp/cci5MUNu.s:326: Error: selected processor does not support ARM mode `mra r2,r3,acc0' /tmp/cci5MUNu.s:367: Error: selected processor does not support ARM mode `mar acc0,r2,r3' make[3]: *** [arch/arm/mach-pxa/pxa27x.o] Error 1 Overriding with -Wa,-march=xscale no longer works, so instead I'm adding an explict ".arch_extension" directive in all four inline assembly statements, which should work even if they end up in a different order in the assembly output. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: move extern declarations to pm.hArnd Bergmann
When CONFIG_IWMMXT is disabled, we get a warning in pxa3xx.c: arch/arm/mach-pxa/pxa3xx.c: In function 'pxa3xx_cpu_pm_suspend': arch/arm/mach-pxa/pxa3xx.c:109:2: error: ISO C90 forbids mixed declarations and code [-Werror=declaration-after-statement] It turns out that there is an 'extern' declaration in the middle of a function. For consistency, this moves the declaration and two others from the same file into pm.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: don't select GPIO_SYSFS for MIOA701Arnd Bergmann
GPIO_SYSFS is a common kernel functionality, not something that a board specific Kconfig should have to worry about. In MIOA701, we get a warning about the select when CONFIG_SYSFS is disabled: warning: (MACH_MIOA701) selects GPIO_SYSFS which has unmet direct dependencies (GPIOLIB && SYSFS) This just removes the select and instead enables the symbol in the defconfig file. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: mark unused eseries code as __maybe_unusedArnd Bergmann
Two variables in eseries.c are used on multiple platforms, but are not referenced when those are all disabled: eseries.c:60:31: warning: 'e7xx_gpio_vbus' defined but not used [-Wunused-variable] eseries.c:129:20: warning: 'eseries_register_clks' defined but not used [-Wunused-function] Marking them __maybe_unused is the nicest way to ensure that we never get the warning or end up with missing symbols if we get it wrong. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: mark spitz_card_pwr_ctrl as __maybe_unusedArnd Bergmann
This function is only used when CONFIG_PCMCIA is enabled, otherwise we get a harmless warning: arch/arm/mach-pxa/spitz.c:204:13: warning: 'spitz_card_pwr_ctrl' defined but not used [-Wunused-function] Marking it as __maybe_unused keeps the logic simple and avoids the warning on randconfig builds. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: define clock registers as __iomemArnd Bergmann
We should not dereference registers as pointers, so use readl/writel instead for these registers. The clock registers are accessed in multiple files, so we have to change them all at once. I stumbled over these registers while looking at something unrelated. There are in fact other registers with the same problem, but I did not try to address those at this point. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-01-20Merge tag 'armsoc-multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform code updates from Arnd Bergmann: "This branch is the culmination of 5 years of effort to bring the ARMv6 and ARMv7 platforms together such that they can all be enabled and boot the same kernel. It has been a tremendous amount of cleanup and refactoring by a huge number of people, and creation of several new (and major) subsystems to better abstract out all the platform details in an appropriate manner. The bulk of this branch is a large patchset from Arnd that brings several of the more minor and older platforms we have closer to multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0 and realview Much of this is moving around header files from old mach directories, but there are also some cleanup patches of debug_ll (lowlevel debug per-platform options) and other parts. Linus Walleij also has some patchs to clean up the older ARM Realview platforms by finally introducing DT support, and Rob Herring has some for ARM Versatile which is now DT-only. Both of these platforms are now multiplatform. Finally, a couple of patches from Russell for Dove PMU, and a fix from Valentin Rothberg for Exynos ADC, which were rebased on top of the series to avoid conflicts" * tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits) ARM: realview: don't select SMP_ON_UP for UP builds ARM: s3c: simplify s3c_irqwake_{e,}intallow definition ARM: s3c64xx: fix pm-debug compilation iio: exynos-adc: fix irqf_oneshot.cocci warnings ARM: realview: build realview-dt SMP support only when used ARM: realview: select apropriate targets ARM: realview: clean up header files ARM: realview: make all header files local ARM: no longer make CPU targets visible separately ARM: integrator: use explicit core module options ARM: realview: enable multiplatform ARM: make default platform work for NOMMU ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location ARM: defconfig: use correct debug_ll settings ARM: versatile: convert to multi-platform ARM: versatile: merge mach code into a single file ARM: versatile: switch to DT only booting and remove legacy code ARM: versatile: add DT based PCI detection ARM: pxa: mark ezx structures as __maybe_unused ARM: pxa: mark raumfeld init functions as __maybe_unused ...
2016-01-13Merge tag 'for-linus-20160112' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "Generic MTD: - populate the MTD device 'of_node' field (and get a proper 'of_node' symlink in sysfs) This yielded some new helper functions, and changes across a variety of drivers - partitioning cleanups, to prepare for better device-tree based partitioning in the future Eliminate a lot of boilerplate for drivers that want to use OF-based partition parsing The DT bindings for this didn't settle yet, so most non-cleanup portions are deferred for a future release NAND: - embed a struct mtd_info inside struct nand_chip This is really long overdue; too many drivers have to do the same silly boilerplate to allocate and link up two "independent" structs, when in fact, everyone is assuming there is an exact 1:1 relationship between a NAND chips struct and its underlying MTD. This aids improved helpers and should make certain abstractions easier in the future. Also causes a lot of churn, helped along by some automated code transformations - add more core support for detecting (and "correcting") bitflips in erased pages; requires opt-in by drivers, but at least we kill a few bad implementations and hopefully stave off future ones - pxa3xx_nand: cleanups, a few fixes, and PM improvements - new JZ4780 NAND driver SPI NOR: - provide default erase function, for controllers that just want to send the SECTOR_ERASE command directly - fix some module auto-loading issues with device tree ("jedec,spi-nor") - error handling fixes - new Mediatek QSPI flash driver Other: - cfi: force valid geometry Kconfig (finally!) This one used to trip up randconfigs occasionally, since bots aren't deterred by big scary "advanced configuration" menus More? Probably. See the commit logs" * tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits) mtd: jz4780_nand: replace if/else blocks with switch/case mtd: nand: jz4780: Update ecc correction error codes mtd: nandsim: use nand_get_controller_data() mtd: jz4780_nand: remove useless mtd->priv = chip assignment staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers mtd: nand: make use of nand_set/get_controller_data() helpers ARM: make use of nand_set/get_controller_data() helpers mtd: nand: add helpers to access ->priv mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs mtd: nand: jz4740: remove custom 'erased check' implementation mtd: nand: diskonchip: remove custom 'erased check' implementation mtd: nand: davinci: remove custom 'erased check' implementation mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions mtd: nand: return consistent error codes in ecc.correct() implementations doc: dt: mtd: new binding for jz4780-{nand,bch} mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc mtd: spi-nor: wait until lock/unlock operations are ready mtd: tests: consolidate kmalloc/memset 0 call to kzalloc jffs2: use to_delayed_work mtd: nand: assign reasonable default name for NAND drivers ...
2016-01-11Merge branch 'patchwork' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (204 commits) [media] rc: sunxi-cir: Initialize the spinlock properly [media] rtl2832: do not filter out slave TS null packets [media] rtl2832: print reg number on error case [media] rtl28xxu: return demod reg page from driver cache [media] coda: enable MPEG-2 ES decoding [media] coda: don't start streaming without queued buffers [media] coda: hook up vidioc_prepare_buf [media] coda: relax coda_jpeg_check_buffer for trailing bytes [media] coda: make to_coda_video_device static [media] s5p-mfc: remove volatile attribute from MFC register addresses [media] s5p-mfc: merge together s5p_mfc_hw_call and s5p_mfc_hw_call_void [media] s5p-mfc: use spinlock to protect MFC context [media] s5p-mfc: remove unnecessary callbacks [media] s5p-mfc: make queue cleanup code common [media] s5p-mfc: use one implementation of s5p_mfc_get_new_ctx [media] s5p-mfc: constify s5p_mfc_codec_ops structures [media] au8522: Avoid memory leak for device config data [media] ir-lirc-codec.c: don't leak lirc->drv-rbuf [media] uvcvideo: small cleanup in uvc_video_clock_update() [media] uvcvideo: Fix reading the current exposure value of UVC ...
2015-12-17Merge branch 'fixes' into next/multiplatformArnd Bergmann
The 'fixes' branch contains d5d4fdd86f57 ("irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB") that is required for booting the versatile platform prior to the rework in this branch, but including both causes a build-time error. I'm doing an evil merge here to pull in the fixes branch so we have that commit included but at the same time revert the trivial change. This gives us a bisectable history. * fixes: (22 commits) fsl-ifc: add missing include on ARM64 ls2080a/dts: Add little endian property for GPIO IP block dt-bindings: define little-endian property for QorIQ GPIO ARM64: dts: ls2080a: fix eSDHC endianness ARM: dts: vf610: use reset values for L2 cache latencies ARM: pxa: use PWM lookup table for all machines ARM: dts: berlin: add 2nd clock for BG2Q sdhci0 and sdhci1 ARM: dts: berlin: correct BG2Q's sdhci2 2nd clock ARM: dts: am4372: fix clock source for arm twd and global timers ARM: at91: fix pinctrl driver selection ARM: at91/dt: add always-on to 1.8V regulator ARM: dts: vf610: fix clock definition for SAI2 ARM: imx: clk-vf610: fix SAI clock tree ARM: ixp4xx: fix read{b,w,l} return types irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB ARM: OMAP2+: enable REGULATOR_FIXED_VOLTAGE ARM: dts: add dm816x missing spi DT dma handles ARM: dts: add dm816x missing #mbox-cells cpufreq: s3c24xx: Do not mark s3c2410_plls_add as __init bus: sunxi-rsb: unlock on error in sunxi_rsb_read() ...
