These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Now that __cpuinit has been removed, the __ref markings on these
functions are useless. Remove them. This also reduces the size of
the multi_v7_defconfig image:
$ size before after
12683578 1470996 348904 14503478 dd4e36 before
12683274 1470996 348904 14503174 dd4d06 after
presumably because now we don't have to jump to code in the
.ref.text section and/or the noinline marking is removed.
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: <linux-omap@vger.kernel.org>
Cc: <linux-arm-msm@vger.kernel.org>
Cc: <spear-devel@list.st.com>
Cc: <linux-tegra@vger.kernel.org>
Acked-by: Barry Song <baohua@kernel.org>
Acked-by: Andy Gross <agross@codeaurora.org>
Acked-by: Viresh Kumar <vireshk@kernel.org>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
We dont need to export the SCM specific cold boot flags to the platform
code. Export only a function to set the cold boot address.
Signed-off-by: Lina Iyer <lina.iyer@linaro.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Architectural changes in the ARM Linux kernel tree mandate the eventual
removal of the mach-* directories. Move the scm driver to
drivers/firmware and the scm header to include/linux to support that
removal.
Add qcom prefix to functions, etc to create a unique name space for the
scm code as it gets ready to move out of qcom specific mach dir.
Put all scm related code into a single file as a first step in cleaning
up the scm interface to just expose functional behavior insteam of making
direct scm calls.
On qcom platforms we always enter the kernel in ARM mode,
regardless of the kernel being compiled for THUMB mode. Use
secondary_startup_arm() to properly switch the mode to what the
kernel expects if required.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Implement support for the Krait CPU release sequence when the
CPUs are part of the second version of the Krait processor
subsystem.
Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org>
CPUs are part of the first version of the krait processor
subsystem.
This makes it easy to add SMP support for new devices by keying
on a device node for the release sequence. We add the
enable-method property for the cpus property to specify that we
want to use the gcc-msm8660 release sequence (which is going to
look for the global clock controller device node to map some
Scorpion specific power and control registers). We also remove
the nr_cpus detection code as that is done generically in the DT
CPU detection code.
[sboyd: Port to CPU_METHOD_OF_DECLARE]
As mach-qcom will support a number of different Qualcomm SoC platforms
we replace the msm prefix on function names with qcom to be a bit more
generic.
Introduce a new mach-qcom that will support SoCs that intend to be
multiplatform compatible while keeping mach-msm to legacy SoC/board
support that will not transition over to multiplatform.
As part of this, we move support for MSM8X60, MSM8960 and MSM8974 over
to mach-qcom.
