path: root/arch/arm/mach-realview/realview_eb.c
2006-12-10i2c: New ARM Versatile/Realview bus driverRussell King
Add support for the I2C bus found on the ARM Versatile and Realview platforms. The I2C bus has a RTC and optionally some EEPROMs attached. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-05-16[ARM] 3527/1: MPCore Boot Lockup FixHarry Fearnhamm
Patch from Harry Fearnhamm This patch fixes the occasional lockup seen in early boot stage on RealView MPCore system. Signed-off-by: Harry Fearnhamm <Harry.Fearnhamm@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[ARM] Add support for Realview with MPcore tileRussell King
Add uniprocessor support for Realview platform fitted with the MPcore (SMP) tile. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-02[ARM] Fix Realview machine for patch 3016/1Russell King
3016/1 changed the map_desc structure to take a PFN instead of a physical address. Fixup Realview machine support for this change. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31[ARM] Fixup platform device.h includes for realview boardRussell King
2005-10-31[ARM] Add support for ARM RealView boardCatalin Marinas
Support for RealView EB. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
