path: root/arch/arm/mach-s3c2400
2011-07-18ARM: mach-s3c2400: deleteNicolas Pitre
On Tue, 28 Jun 2011, Ben Dooks wrote: > On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote: > > > On a related note, what about mach-s3c2400? It seems to be even more > > incomplete. > > Probably the same fate awaits that. It is so old that there's little > incentive to do anything with it. So out it goes as well. The PORT_S3C2400 definition in include/linux/serial_core.h is left there to prevent a reuse of the same number for another port type. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-01ARM: S3C: Update Simtec copyright statements from , to - [2]Ben Dooks
There are a number of statements of the form A, B or A, B, C where the numbers A,B,C are not consecutive. However, referencing [1] it is the correct thing to replace these with A-B or A-C as apropriate. [1] http://www.copyrightservice.co.uk/copyright/p03_copyright_notices section 4iii 'Year of publication' Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-18[ARM] S3C24XX: GPIO: Fix error returns from gpio functionsBen Dooks
Several GPIO functions have been returning -1 to indicate an error instead of returning a proper error code. Change to return -EINVAL for invalid argument(s). Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-18[ARM] S3C24XX: GPIO: Change to macros for GPIO numberingBen Dooks
Prepare to remove the large number of S3C2410_GPxn defines by moving to S3C2410_GPx(n) in arch/arm. The following perl was used to change the files: perl -pi~ -e 's/S3C2410_GP([A-Z])([0-9]+)([^_^0-9])/S3C2410_GP\1\(\2\)\3/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
