path: root/arch/arm/mach-s3c2410/mach-vr1000.c
2009-05-18[ARM] S3C24XX: GPIO: Change to macros for GPIO numberingBen Dooks
Prepare to remove the large number of S3C2410_GPxn defines by moving to S3C2410_GPx(n) in arch/arm. The following perl was used to change the files: perl -pi~ -e 's/S3C2410_GP([A-Z])([0-9]+)([^_^0-9])/S3C2410_GP\1\(\2\)\3/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-18[ARM] S3C24XX: GPIO: Move gpio functions out of <mach/hardware.h>Ben Dooks
Move all the gpio functions out of <mach/hardware.h> as this file is for defining the generic IO base addresses for the kernel IO calls. Make a new header <mach/gpio-fns.h> to take this and include it via the chain from <linux/gpio.h> which is what most of these files should be using (and will be changed as soon as possible). Note, this does make minor changes to some drivers but should not mess up any pending merges. CC: Richard Purdie <rpurdie@rpsys.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-17[ARM] S3C24XX: GPIO: Remove pin specific input and output definesBen Dooks
The use of S3C2410_GP[A-Z]x_INP and S3C2410_GP[A-Z]x_OUTP are very rare and are taking up large amounts of space in the regs-gpio.h header. The GPIO layer has had generic input and out defines called S3C2410_GPIO_INPUT and S3C2410_GPIO_OUTPUT for a while which work for all S3C24XX GPIOs. Do the following replacements: S3C2410_GP[A-Z][0-9]*_\OUTP => S3C2410_GPIO_OUTPUT S3C2410_GP[A-Z][0-9]*_\INP => /S3C2410_GPIO_INPUT S3C2410_GPA[0-9]*_OUT => S3C2410_GPIO_OUTPUT to remove any usages of these and prepare the header for the removal of these. The following command was used to acheive this: find . -type f -writable ! -name regs-gpio.h ! -name "*~" | xargs sed -i~ -e 's/S3C2410_GP[A-Z][0-9]*_\OUTP/S3C2410_GPIO_OUTPUT/g' -e 's/S3C2410_GP[A-Z][0-9]*_\INP/S3C2410_GPIO_INPUT/g' -e 's/S3C2410_GPA[0-9]*_OUT/S3C2410_GPIO_OUTPUT/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C: Make i2c device definition common to plat-s3cBen Dooks
Make the device i2c0 common to plat-s3c and move the definitions from arch/arm/plat-s3c24xx/devs.c Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-14Merge branch 's3c-move' into develRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-07[ARM] S3C24XX: Additional include movesBen Dooks
Continue moving the include files into arch/arm Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-07[ARM] S3C24XX: Move files out of include/asm-arm/plat-s3c*Ben Dooks
First move of items out of include/asm-arm/plat-s3c* to their new homes under arch/arm/plat-s3c/include/plat and arch/arm/plat-s3c24xx/include/plat directories. Note, we have to create a dummy arch/arm/plat-s3c/Makefile to allow us to add arch/arm/plat-s3c/include/plat to the path. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-08Merge http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm ↵Ben Dooks
into for-rmk
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-15[ARM] S3C24XX: s3c243xx_clock_register() data can be __initdataBen Dooks
Any data being passed to s3c243xx_clock_register() can be marked as __initdata as it is an array of pointers to 'struct clk' that are to be registered on initialisation. The s3c243xx_clock_register function uses this array to register clocks and does not require it to stay around after exit. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] VR1000: Add tmp101 to list of I2C devices on the boardBen Dooks
Add tmp101 support via the new style I2C driver registration on the VR1000. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] VR1000: Add i2c device list to Thorcom VR1000Ben Dooks
Add i2c board intialisers to specify the I2C devices attached on the Thorcom VR1000. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C24XX: Add physmap device for all Simtec NOR equiped boards.Ben Dooks
Move to using the physmap platform device code to attached NOR flash on Simtec boards so that the old bast-flash driver can be safely removed. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] BAST/VR1000: Move to using ata_platform (libata)Ben Dooks
Use the pata_platform driver to provide the IDE port drivers on the Simntec BAST and Thorcom VR1000 machines as a precursor to removing drivers/ide/arm/bast-ide.c This will mean that the system will need SCSI and SCSI disc support as a minimum, and any references to hdX will be changed to sdX. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] S3C2410: Fix flags on DM9000 resources on BAST and VR1000Ben Dooks
Fix the flags entries for the DM9000 IRQ entries on both the Simtec BAST and Thorcom VR1000 board. The current entries use the IRQF_ flags, but we should be using the IORESOURCE_IRQ_ definitions. Signed-off-by: Ben Dooks <ben-linux@fluff.org> PATCH FOLLOWS KernelVersion: 2.6.26-rc5
2008-05-22[ARM] 5041/1: VR1000: Fix DM9000 IRQ flags initialisationBen Dooks
Add the IRQF_TRIGGER_ type to the DM9000 IRQ resource to stop the driver itself complaining it was not given any flags to use. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4986/1: S3C24XX: Simtec machines need UCLK as parent to DCLKBen Dooks
All current Simtec designs source the DCLK outputs from the UPLL. This means the DCLK's parent must be set to UPLL so that anything enabling and disabling an UPLL sourced clock does not shutdown the DCLK due to missing open counts. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4729/1: VR1000: Do not add IIS device on initialisationBen Dooks
The IIS device is being registered by the Simtec Audio driver, and thus registering here causes an error due to device tree naming collision. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4325/1: S3C24XX: remove s3c24xx_boardBen Dooks
Remove the use of struct s3c24xx_board as this is just as easily done by using the platform device registration functions to make the initialisation sequence easier. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4324/1: S3C24XX: remove clocks from s3c24xx_boardBen Dooks
Remove the clocks from the s3c24xx_board as part of the process of simplifying the initialisation sequence by removing struct s3c24xx_board. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4059/1: VR1000: fix LED3's platform device numberBen Dooks
LED 3 should have been registered with the platform deviceid of 3, instead of 1 (which was used for LED 1). Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3998/1: VR1000: LED platform devicesBen Dooks
Support for the GPIO attached LEDs on the VR1000 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-06[ARM] 3767/1: S3C24XX: remove changelog comments from arch/arm/mach-s3c2410Ben Dooks
Patch from Ben Dooks Remove the pointless changelog comments from arch/arm/mach-s3c2410 files, as all this can be found from the revision control system. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3557/1: S3C24XX: centralise and cleanup uart registrationBen Dooks
Patch from Ben Dooks All the S3C24XX based devices currently have similar uart blocks, in the same location. Make the process of adding new uart blocks easier by commonising the device definitions and adding a new init function for the cpu code. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3125/2: VR1000: Fix map_decs initialiserBen Dooks
Patch from Ben Dooks Fix the initialisation of the map_desc fields in the Thorcom VR1000 machine support to use the new .pfn initialiser. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[ARM] 2979/2: S3C2410 - add static to non-exported machine itemsBen Dooks
Patch from Ben Dooks Do not export items that are not needed by symbol name elsewhere Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-20[ARM] 2928/1: S3C2410 - make machine init code staticBen Dooks
Patch from Ben Dooks This code is not being exported, declare it static Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2765/1: S3C24XX - small cleanups in arch/arm/mach-s3c2410Ben Dooks
Patch from Ben Dooks Re-tab the devs.c file, and change the initialiser for the mach-vr1000.c to use `.xxx = yyy` form. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] ARM: 2729/1: DM9000 platform support for S3C2410 machines (BAST, VR1000)Ben Dooks
Patch from Ben Dooks Add platform_device information for DM9000 chip(s) on the Simtec BAST and the VR1000 board. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
