path: root/arch/arm/mach-s3c2410
2008-05-22[ARM] 5041/1: VR1000: Fix DM9000 IRQ flags initialisationBen Dooks
Add the IRQF_TRIGGER_ type to the DM9000 IRQ resource to stop the driver itself complaining it was not given any flags to use. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] 5040/1: BAST: Fix DM9000 IRQ flags initialisationBen Dooks
2008-04-19[ARM] 5005/1: BAST: Fix kset_name initialiserBen Dooks
Fix the pm sys device .name initialiser which was missed when updating the last patch submission. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4963/1: S3C2410 - add basic machine support for the TCT HammerDavid Anders
Add the TinCanTools Hammer board to list of supported machines in the arch/arm/mach-s3c2410 directory, as well as a default config entry. the mach-tct_hammer.c file initializes basic i/o, clocks, irqs, as well as the mtd flash layout if enabled in the kernel configuration. Signed-off-by: David Anders <danders@amltd.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4986/1: S3C24XX: Simtec machines need UCLK as parent to DCLKBen Dooks
All current Simtec designs source the DCLK outputs from the UPLL. This means the DCLK's parent must be set to UPLL so that anything enabling and disabling an UPLL sourced clock does not shutdown the DCLK due to missing open counts. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4984/1: S3C24XX: Do not assert nRSTOUT on BAST over suspend.Ben Dooks
Change GPA21 to output over reset so that nRSTOUT is not asserted whilst suspended. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branches 'at91', 'ep93xx', 'iop', 'kprobes', 'ks8695', 'misc', 'msm', ↵Russell King
's3c2410', 'sa1100' and 'vfp' into devel * at91: (24 commits) [ARM] 4615/4: sam926[13]ek buttons updated [ARM] 4765/1: [AT91] AT91CAP9A-DK board support [ARM] 4764/1: [AT91] AT91CAP9 core support [ARM] 4738/1: at91sam9261: Remove udc pullup enabling in board initialisation [ARM] 4761/1: [AT91] Board-support for NEW_LEDs [ARM] 4760/1: [AT91] SPI CS0 errata on AT91RM9200 [ARM] 4759/1: [AT91] Buttons on CSB300 [ARM] 4758/1: [AT91] LEDs [ARM] 4757/1: [AT91] UART initialization [ARM] 4756/1: [AT91] Makefile cleanup [ARM] 4755/1: [AT91] NAND update [ARM] 4754/1: [AT91] SSC library support [ARM] 4753/1: [AT91] Use DMA_BIT_MASK [ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9 [ARM] 4751/1: [AT91] ISI peripheral on SAM9263 [ARM] 4750/1: [AT91] STN LCD displays on SAM9261 [ARM] 4734/1: at91sam9263ek: include IRQ for Ethernet PHY [ARM] 4646/1: AT91: configurable HZ, default to 128 [ARM] 4688/1: at91: speed-up irq processing [ARM] 4657/1: AT91: Header definition update ... * ep93xx: [ARM] 4671/1: ep93xx: remove obsolete gpio_line_* operations [ARM] 4670/1: ep93xx: implement IRQT_BOTHEDGE gpio irq sense type [ARM] 4669/1: ep93xx: simplify GPIO code and cleanups [ARM] 4668/1: ep93xx: implement new GPIO API * iop: [ARM] 4770/1: GLAN Tank: correct physmap_flash_data width field [ARM] 4732/1: GLAN Tank: register rtc-rs5c372 i2c device [ARM] 4708/1: iop: update defconfigs for 2.6.24 * kprobes: ARM kprobes: let's enable it ARM kprobes: special hook for the kprobes breakpoint handler ARM kprobes: prevent some functions involved with kprobes from being probed ARM kprobes: don't let a single-stepped stmdb corrupt the exception stack ARM kprobes: add the kprobes hook to the page fault handler ARM kprobes: core code ARM kprobes: instruction single-stepping support * ks8695: [ARM] 4603/1: KS8695: debugfs interface to view pin state [ARM] 4601/1: KS8695: PCI support * misc: [ARM] remove duplicate includes [ARM] CONFIG_DEBUG_STACK_USAGE [ARM] 4689/1: small comment wrap fix [ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fix [ARM] 4666/1: ixp4xx: fix sparse warnings in include/asm-arm/arch-ixp4xx/io.h [ARM] remove reference to non-existent MTD_OBSOLETE_CHIPS [SERIAL] 21285: Report baud rate back via termios [ARM] Remove pointless casts from void pointers, [ARM] Misc minor interrupt handler cleanups [ARM] Remove at91_lcdc.h [ARM] ARRAY_SIZE() cleanup [ARM] Update mach-types * msm: [ARM] msm: dma support for MSM7X00A [ARM] msm: board file for MACH_HALIBUT (QCT MSM7200A) [ARM] msm: irq and timer support for ARCH_MSM7X00A [ARM] msm: core platform support for ARCH_MSM7X00A * s3c2410: (33 commits) [ARM] 4795/1: S3C244X: Add armclk and setparent call [ARM] 4794/1: S3C24XX: Comonise S3C2440 and S3C2442 clock code [ARM] 4793/1: S3C24XX: Add IRQ->GPIO pin mapping function [ARM] 4792/1: S3C24XX: Remove warnings from debug-macro.S [ARM] 4791/1: S3C2412: Make fclk a parent of msysclk [ARM] 4790/1: S3C2412: Fix parent selection for msysclk. [ARM] 4789/1: S3C2412: Add missing CLKDIVN register values [ARM] 4788/1: S3C24XX: Fix paramet to s3c2410_dma_ctrl if S3C2410_DMAF_AUTOSTART used. [ARM] 4787/1: S3C24XX: s3c2410_dma_request() should return the allocated channel number [ARM] 4786/1: S3C2412: Add SPI FIFO controll constants [ARM] 4785/1: S3C24XX: Add _SHIFT definitions for S3C2410_BANKCON registers [ARM] 4784/1: S3C24XX: Fix GPIO restore glitches [ARM] 4783/1: S3C24XX: Add s3c2410_gpio_getpull() [ARM] 4782/1: S3C24XX: Define FIQ_START for any FIQ users [ARM] 4781/1: S3C24XX: DMA suspend and resume support [ARM] 4780/1: S3C2412: Allow for seperate DMA channels for TX and RX [ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() call [ARM] 4778/1: S3C2412: Add armclk and init from DVS state [ARM] 4777/1: S3C24XX: Ensure clk_set_rate() checks the set_rate method for the clk [ARM] 4775/1: s3c2410: fix compilation error if only s3c2442 cpu is selected ... * sa1100: [ARM] sa1100: add clock source support * vfp: [ARM] 4584/2: ARMv7: Add Advanced SIMD (NEON) extension support [ARM] 4583/1: ARMv7: Add VFPv3 support [ARM] 4582/2: Add support for the common VFP subarchitecture
2008-01-28[ARM] 4729/1: VR1000: Do not add IIS device on initialisationBen Dooks
The IIS device is being registered by the Simtec Audio driver, and thus registering here causes an error due to device tree naming collision. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4728/1: BAST: Do not add IIS device on initialisationBen Dooks
2008-01-28[ARM] 4723/1: BAST: Fix LCD driver default display settingBen Dooks
We have a default display set to 4, when we only have three registered displays. Fix this argument (a seperate patch has been generated to ensure that the LCD driver takes notice of this bug) Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] Remove pointless casts from void pointers,Jeff Garzik
mostly in and around irq handlers. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16s3c2410fb: removes lcdcon1 register value from s3c2410fb_displayKrzysztof Helt
This patch removes lcdcon1 register field from the s3c2410fb_display as all bits are calculated from other fields. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: adds pixclock to s3c2410fb_displayKrzysztof Helt
This patch adds pixelclock field to the s3c2410fb_display structure and make use of it in the driver. The Bast machine defined 9 modes but pixclock and margin values are defined only for the 640x480 modes so I removed other modes. This patch also fixes wrong display type constant for the SMDK2440 board. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: remove lcdcon2 and lcdcon3 register fieldsKrzysztof Helt
This patch removes unused lcdcon2 and lcdcon3 register value from the s3c2410fb_display structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: add pulse length fields to s3c2410fb_displayKrzysztof Helt
This patch adds synchronization pulse lenght fields to the s3c2410fb_display structure and makes use of them in the driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: add vertical margins fields to s3c2410fb_displayKrzysztof Helt
This patch adds vertical margins values to all s3c24xx platform. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: remove lcdcon3 register from s3c2410fb_displayKrzysztof Helt
This patch removes unused lcdcon3 register from the s3c2410fb_display structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: add margin fields to s3c2410fb_displayKrzysztof Helt
This patch adds margins fields to the s3c2410fb_display structure. It also sets display type and horizontal margins in all platform files that use the s3c2410fb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: multi-display supportKrzysztof Helt
This patch adds a new structure to describe and handle more than one panel (display mode) for the s3c2410 framebuffer. This structure is added after the pxafb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[ARM] 4566/1: s3c24xx: fix dma functions section mismatchKrzysztof Helt
This patch removes section mismatches related to DMA functions. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410Ben Dooks
Move register and other definitions out of the include/asm-arm/arch-s3c2410 into the the arch directories of include/asm-arm/plat-s3c24xx and include/asm-arm/plat-s3c. This move is in preperation of the merging of s3c2400 and s3c6400. The following git mv commands are needed before this patch can be applied: git mv include/asm-arm/arch-s3c2410/regs-ac97.h include/asm-arm/plat-s3c/regs-ac97.h git mv include/asm-arm/arch-s3c2410/regs-adc.h include/asm-arm/plat-s3c/regs-adc.h git mv include/asm-arm/arch-s3c2410/regs-iis.h include/asm-arm/plat-s3c24xx/regs-iis.h git mv include/asm-arm/arch-s3c2410/regs-spi.h include/asm-arm/plat-s3c24xx/regs-spi.h git mv include/asm-arm/arch-s3c2410/regs-udc.h include/asm-arm/plat-s3c24xx/regs-udc.h git mv include/asm-arm/arch-s3c2410/udc.h include/asm-arm/plat-s3c24xx/udc.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU supportBen Dooks
Update the Kconfig to create configuration options based on which CPUs are supported for the low level serial code. This means that the debug macros can be optimised for the type(s) of CPU that are being used. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4467/3: BAST: AX88796 device resourcesBen Dooks
Add resources for the AX88796 on the Simtec BAST. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-30[ARM] 4415/1: AML5900: fix sparse warnings from map_ioBen Dooks
The map_io function does not need to be exported from this file, and therefore should be declared static. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-26[ARM] remove unused header file: arch/arm/mach-s3c2410/bast.hRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] 4395/1: S3C24XX: add include of <linux/sysdev.h> to relevant machinesBen Dooks
Include <linux/sysdev.h> in any machines that use the PM functions which require struct sys_device. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4359/3: H1940: Add bluetooth supportArnaud Patard
This patch adds a small driver responsible for configuring the UART used for the bluetooth chip and for enabling the bluetooth chipset. Additionnaly, can trigger a led if the H1940 led driver is enabled. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-05[ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h headerArnaud Patard
linux/mmc/protocol.h header is gone, thus breaking the build of the mach-qt2410.c file. As this header is not used, I'm removing it. The right headers may still be added later if needed. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4325/1: S3C24XX: remove s3c24xx_boardBen Dooks
Remove the use of struct s3c24xx_board as this is just as easily done by using the platform device registration functions to make the initialisation sequence easier. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4324/1: S3C24XX: remove clocks from s3c24xx_boardBen Dooks
Remove the clocks from the s3c24xx_board as part of the process of simplifying the initialisation sequence by removing struct s3c24xx_board. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-20[ARM] 4272/1: Missing symbol h1940_pm_return fixKrzysztof Helt
Added missing ifdefs, to make kernel linkable without the PM support. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4220/1: S3C24XX: DMA system initialised from sysdevBen Dooks
This patch gets the DMA system for the S3C24XX ready for the S3C2443, which requires 6 dma channels at a different stride, and different base IRQ. The DMA system is now initialised from the same drivers which apply the DMA mappings, as well as removing the DMA sysdev intialisation out of the main init code (which is now being called from a sysdev probe, so cannot add a new sysdev) Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4214/2: S3C2410: Add Armzone QT2410Ben Dooks
Patch from: Harald Welte <laforge@openmoko.org> Add support for the Armzone QT2410 system, with basic peripheral support for TFT display, SPI and LEDs. Signed-off-by: Harald Welte <laforge@openmoko.org> Signed-off-by: Ben Dooks <ben-linux@fluf.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-16[ARM] 4209/1: S3C24XX: remove unnecessary includes of iomd.hBen Dooks
Machines in the S3C24XX architectures should not be including <asm/hardware/iomd.h> as this is not needed. Also remove commented out includes Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4178/1: S3C2410: DMA ordering listBen Dooks
Add DMA ordering list for S3C2410 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4176/1: H1940 ledsArnaud Patard
H1940 leds device addition. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4174/1: H1940 usb device definitionsArnaud Patard
This patch is adding the usb device controller to the h1940 device list. It's also adding the code to handle the usb pull-ups. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-12[ARM] 4169/1: S3C2410: align to a cache lineMatt Reimer
Align the code to the start of the next cache line, rather than the start of the next 256-byte page. (On i386 and ARM, the ".align" assembler directive takes its first argument as the number of low-order bits that must be zero, not the number of words comprising a cache line.) Supercedes patch 4166. Signed-off-by: Matt Reimer <mreimer@vpop.net> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-12[ARM] 4163/1: S3C2410: minor typo in init commentBen Dooks
Fix a reference to s3c2440 in the s3c2410 cpu file Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4159/1: S3C2410: fix compile of arch/arm/mach-s3c2410/mach-aml5900.cBen Dooks
Fix compile of arch/arm/mach-s3c2410/mach-aml5900.c due to missing fixes that have been applied to the rest of the tree. Include <linux/serial_core.h> to provide the upf_t type needed for the serial code, and remove the old static map of the SPI which is not needed for the new spi drivers. mach-amlm5900.c:51: include/asm/arch/regs-serial.h:200: error: parse error befo re "upf_t" mach-amlm5900.c:117: error: 'S3C24XX_VA_SPI' undeclared here (not in a function) Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4156/1: S3C24XX: Add CONFIG_S3C2410_GPIOBen Dooks
In preperation for splitting the arch-s3c2410 directory up, add a CONFIG_S3C2410_GPIO instead of implicitly making the .o for CONFIG_CPU_S3C2410 and CONFIG_CPU_S3C2440 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4155/1: S3C24XX: remove obj-dma-* from MakefileBen Dooks
In preperation for splitting the arch-s3c2410 directory up, remove the use of obj-dma-y in the Makefile and move to using CONFIG_S3C2440_DMA, CONFIG_S3C2412_DMA, etc. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-29[ARM] 4117/1: S3C2412: Fix writel() usage in selection codeBen Dooks
The S3C2412 DMA selection code has the arguments to writel() the wrong way around. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4096/1: S3C24XX: change return code form s3c2410_gpio_getcfg()Ben Dooks
The s3c2410_gpio_getcfg() currently returns a value which is dependant on the GPIO no passed in. Now we have more generic constants it is sensible to use those as return codes so that any function dealing with >1 GPIO does not need to do it's own number processing. Since this function is only currently used in pm.c, it is easy to fixup (and correct pm.c to use the generic constants) Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
