path: root/arch/arm/mach-s3c2412/mach-smdk2413.c
2011-03-07ARM: s3c24xx: Switch to common GPIO controlled UDC pullup implementationLars-Peter Clausen
Currently all boards using the s3c2410_udc driver use a GPIO to control the state of the pullup, as a result the same code is reimplemented in each board This patch changes these boards to use the common implementation for GPIO controlled pullup in the UDC driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-07-16ARM: Remove DISCONTIGMEM supportRussell King
Everything should now be using sparsemem rather than discontigmem, so remove the code supporting discontigmem from ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-19ARM: Merge for-2635/gpio2Ben Dooks
Merge branch 'for-2635/gpio2' into for-linus/samsung2
2010-05-12ARM: SAMSUNG: Remove old email address for ben-linux@fluff.orgBen Dooks
The address ben@fluff.org is old, ben-linux@fluff.org has been in use for a long time, and we should fixup all the occasions of the older address to avoid confusion. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-06ARM: H1940: Change mach-h1940 to use gpiolib APIBen Dooks
Change mach-h1940 to use the gpiolib calls instead of s3c2410_gpio directly. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-15ARM: S3C2412: Fixup commented out device in SMDK2413Ben Dooks
The SMDK2413 has a commented out device that does not have any setup data for it, so remove it for now. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-15ARM: S3C: Rename s3c_device_usb to s3c_device_ohciBen Dooks
Prepare for the forthcoming device changes by renaming s3c_device_usb to s3c_device_ohci as this is what the device represents. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-18[ARM] S3C24XX: GPIO: Change to macros for GPIO numberingBen Dooks
Prepare to remove the large number of S3C2410_GPxn defines by moving to S3C2410_GPx(n) in arch/arm. The following perl was used to change the files: perl -pi~ -e 's/S3C2410_GP([A-Z])([0-9]+)([^_^0-9])/S3C2410_GP\1\(\2\)\3/g' Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-18[ARM] S3C24XX: GPIO: Move gpio functions out of <mach/hardware.h>Ben Dooks
Move all the gpio functions out of <mach/hardware.h> as this file is for defining the generic IO base addresses for the kernel IO calls. Make a new header <mach/gpio-fns.h> to take this and include it via the chain from <linux/gpio.h> which is what most of these files should be using (and will be changed as soon as possible). Note, this does make minor changes to some drivers but should not mess up any pending merges. CC: Richard Purdie <rpurdie@rpsys.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C: Make i2c device definition common to plat-s3cBen Dooks
Make the device i2c0 common to plat-s3c and move the definitions from arch/arm/plat-s3c24xx/devs.c Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-30[ARM] S3C24XX: Movev udc headers to arch/arm/plat-s3c24xx/include/platBen Dooks
Move the udc headers to the proper home in arch/arm/plat-s3c24xx/include/plat ready to clean out the old include directories. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-14Merge branch 's3c-move' into develRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-07[ARM] S3C24XX: Additional include movesBen Dooks
Continue moving the include files into arch/arm Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-07[ARM] S3C24XX: Move files out of include/asm-arm/plat-s3c*Ben Dooks
First move of items out of include/asm-arm/plat-s3c* to their new homes under arch/arm/plat-s3c/include/plat and arch/arm/plat-s3c24xx/include/plat directories. Note, we have to create a dummy arch/arm/plat-s3c/Makefile to allow us to add arch/arm/plat-s3c/include/plat to the path. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410Ben Dooks
Move register and other definitions out of the include/asm-arm/arch-s3c2410 into the the arch directories of include/asm-arm/plat-s3c24xx and include/asm-arm/plat-s3c. This move is in preperation of the merging of s3c2400 and s3c6400. The following git mv commands are needed before this patch can be applied: git mv include/asm-arm/arch-s3c2410/regs-ac97.h include/asm-arm/plat-s3c/regs-ac97.h git mv include/asm-arm/arch-s3c2410/regs-adc.h include/asm-arm/plat-s3c/regs-adc.h git mv include/asm-arm/arch-s3c2410/regs-iis.h include/asm-arm/plat-s3c24xx/regs-iis.h git mv include/asm-arm/arch-s3c2410/regs-spi.h include/asm-arm/plat-s3c24xx/regs-spi.h git mv include/asm-arm/arch-s3c2410/regs-udc.h include/asm-arm/plat-s3c24xx/regs-udc.h git mv include/asm-arm/arch-s3c2410/udc.h include/asm-arm/plat-s3c24xx/udc.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4325/1: S3C24XX: remove s3c24xx_boardBen Dooks
Remove the use of struct s3c24xx_board as this is just as easily done by using the platform device registration functions to make the initialisation sequence easier. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4175/1: SMDK2413: add udc pull-up controlBen Dooks
USB gadget pull-up control and device addition for the SMDK2413/SMDK2412 board. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-12[ARM] 4164/1: S3C2412: Add SMDK2412 to SMDK2413Ben Dooks
Our current support for the SMDK2413 is the same as the SMDK2412 (which is very similar), so add SMDK2412 to the list of machines that mach-smdk2413.c supports Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
