path: root/arch/arm/mach-s5pc100/gpiolib.c
2010-05-20ARM: S5PC100: use common plat-s5p external interrupt codeMarek Szyprowski
Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20ARM: S5PC100: Add support for gpio interruptMarek Szyprowski
This patch moves support for gpio interrupts from plat-s5pc1xx to mach-s5pc100 directory. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20ARM: SAMSUNG: move S5PC100 support from plat-s5pc1xx to plat-s5p frameworkMarek Szyprowski
This patch moves S5PC100 SoC support to plat-s5p framework. Most periperal support code has been already moved from plat-s5pc1xx to mach-s5pc100. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: S5PC100: Move gpio support from plat-s5pc1xx to mach-s5pc100Marek Szyprowski
Move gpio-lib support from plat-s5pc1xx to mach-s5pc100. Only basic gpio functionality is now supported. Gpio interrupts are disabled temporarly and will be added later. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
