path: root/arch/arm/mach-s5pc100
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-03ARM: SAMSUNG: Add PWM backlight support on Samsung S5PC100Banajit Goswami
This patch adds support for LCD backlight using PWM timer for Samsung SMDKC100 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: S5PC100: Clenaup map.h fileKukjin Kim
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-05Merge branch 'dev/cleanup-clocks' into for-nextKukjin Kim
2011-01-04ARM: S5PC100: Tidy register and disable clock usageKukjin Kim
This patch changes the clock registration code to use the s3c_register_clocks() followed by s3c_disable_clocks() instead of the loops it was using. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30Merge branch 'next-s5p' into for-next-newKukjin Kim
2010-12-30ARM: S5P: Move SROM controller IO mapping to plat-s5p for S5P SoCsThomas Abraham
This patch modifies the following. 1. Moves the SROM controller mapping from S5PV210 specific code to S5P common code. The SROM controller mapping can be used for all S5P SoCs. 2. Define the SROM controller physical address for S5P64X0, S5P6442, S5PC100, S5PV210 and S5PV310. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-23ASoC: SMDK_WM8580: Enable for SMDKC100Jassi Brar
Enable the ASoC Machine driver to run on SMDKC100 as well. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename AC97 platform deviceJassi Brar
Call the AC97 controller devices found in S3C, S5P and newer SoCs as 'samsung-ac97' rather than 's3c-ac97'. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-19ARM: S5PC100: Upgrade platform device for I2SJassi Brar
Add more information to I2S platform_devices in order to prepare them for new controller driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-19ARM: SAMSUNG: Rename s3c64xx I2S platform deviceJassi Brar
Since the I2S of S3C64XX and newer SoCs are incremental versions of each other with changes managable in a single driver, rename the 's3c64xx-iis' -> 'samsung-i2s' Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-28Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-s3c64xx/dev-audio.c
2010-10-25ARM: S5P: Change VMALLOC_END to use more vmalloc()/ioremap() areaKukjin Kim
This patch changes VMALLOC_END from 0xE0000000 to 0xF6000000, because some systems want to use more vmalloc()/ioremap() area and now don't use from at 0xE0000000 to 0xF6000000 (the start of Samsung SoCs' VA space) Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Reorder DMA platform device idSeungwhan Youn
This patch is matched-up DMA platform device id to its clock id. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Fix Audio, Keypad and ADC clock sourcesJassi Brar
Audio, Keypad and ADC inherit PCLKD1 clock source. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> [kgene.kim@samsung.com: minor title fix] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Add EPLL rate change warningSeungwhan Youn
This patch adds warning about changing EPLL rate to notice that other driver that controls H/W, which is using EPLL, will has unknown effects by this EPLL rate change. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Reduce duplicated EPLL control codesSeungwhan Youn
S5P Samsung SoCs has a EPLL to support various PLL clock sources for other H/W blocks. Until now, to control EPLL, each of SoCs make their own functions in 'mach-s5pxxx/clock.c'. But some of functions, 'xxx_epll_get_rate()' and 'xxx_epll_enable()', are exactly same in all S5P SoCs, so this patch move these duplicated codes to common EPLL functions that use platform wide. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Add SCLK_SPDIF clockSeungwhan Youn
This patch add SCLK_SPDIF clock to support source clock of S/PDIF on S5PC100. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Modify SCLK_AUDIO{0,1,2} clock as sysclksSeungwhan Youn
This patch modify SCLK_AUDIO{0,1,2} to be initial as sysclks on boot-time. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Add S/PDIF platform deviceSeungwhan Youn
This patch add S/PDIF platform device to support S/PDIF PCM audio on S5PC100. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Change I2C2 and I2C3 IRQ namesKukjin Kim
This patch changes I2C2 and I2C3 interrupt name from IRQ_CANX to IRQ_IICX according other SoCs' I2C interrupt naming rule. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PC100: Cleanup the GPIOlib codeKukjin Kim
This patch clean up the GPIO code and removes useless GPIO addresses. It can be calculated with offset, the 'base' member of s3c_gpio_chip is also initialized in the init function. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25Merge branch 'next-gpio-update' into for-nextKukjin Kim
2010-10-23ARM: S5PC100: 2nd Change to using s3c_gpio_cfgrange_nopull()Kukjin Kim
This patch changes code setting special-function and no pull-up to use the s3c_gpio_cfgrange_nopull() wrapper. NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5PC100: Change to using s3c_gpio_cfgrange_nopull()Ben Dooks
Change code setting special-function and no pull-up to use the s3c_gpio_cfgrange_nopull() wrapper. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5PC100: 2nd Change to using s3c_gpio_cfgall_range()Kukjin Kim
This patch changes the code setting range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgpin_range(). NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5PC100: Change to using s3c_gpio_cfgall_range()Ben Dooks
Change the code setting a range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgall_range(). Mop up a few missed s3c_gpio_cfgpin_range() changes. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5PC100: Change to using s3c_gpio_cfgpin_range()Ben Dooks
Change the code setting ranges of GPIO pins using s3c_gpio_cfgpin() to use the recently introduced s3c_gpio_cfgpin_range(). Signed-off-by: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: Fixed wrong change] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5P: Unify defines for both gpio interrupt typesMarek Szyprowski
Samsung S5P SoCs have the same interrupt type defines for both external interrupts and gpio interrupts. This patch removes all duplicates from S5PC100 and S5PV210 specific includes as well as gpio interrupt code and put a common defines to plat/irqs.h NOTE: Do not use this for S5P6440 and S5P6450. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: add note for S5P64X0] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: SAMSUNG: Add common samsung_gpiolib_to_irq functionJoonyoung Shim
This patch adds a common callback for gpio_to_irq() for external and gpio interrupts for Samsung SoCs. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: moved samsung_gpiolib_to_irq() for s3c24xx build] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5PC100: Move External Interrupt definitionsJoonyoung Shim
This patch moves external interrupt definitions from mach/gpio.h to mach/regs-gpio.h for consistency with S5PV210. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5PC100: Use generic S5P GPIO Interrupt interfaceJoonyoung Shim
S5PC100 SoC can use common S5P GPIO interrupt code. This patch removes specific S5PC100 gpio interrupts code and adds required defines and code to make use of common S5P code. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5P: Remove redundant selection PLAT_S5P for S5PC100, S5PV210 and S5PV310Kyungmin Park
The selection PLAT_S5P is selected with plat-s5p/Kconfig. So remove it form each CPU_S5PXXXX config. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: edited title] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-18ARM: S5P: Moves initial map for merging S5P64X0Kukjin Kim
This patch moves some initial maps from plat-s5p to machine, so that can merge mach-s5p6440 and mach-s5p6450. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-08ARM: S5P: Bug fix on errors of build with CONFIG_PREEMPT_NONESeungChull Suh
This patch adds header <linux/sched.h> into the below files for build with CONFIG_PREEMPT_NONE. arch/arm/mach-s5p6440/cpu.c arch/arm/mach-s5p6442/cpu.c arch/arm/mach-s5pc100/cpu.c arch/arm/mach-s5pv210/cpu.c Following is error message of in case of s5pv210_defconfig with CONFIG_PREEMPT_NONE. arch/arm/mach-s5pv210/cpu.c:91: error: implicit declaration of function 'need_resched' Signed-off-by: SeungChull Suh <sc.suh@samsung.com> [kgene.kim@samsung.com: removed mach-s5p64x0/cpu.c] [kgene.kim@samsung.com: added fix mach-s5p6440/cpu.c] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits) ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions} ARM: 6324/1: cam60: move cam60_spi_devices to .init.data ARM: 6322/1: imx/pca100: Fix name of spi platform data ARM: 6321/1: fix syntax error in main Kconfig file ARM: 6297/1: move U300 timer to dynamic clock lookup ARM: 6296/1: clock U300 intcon and timer properly ARM: 6295/1: fix U300 apb_pclk split ARM: 6306/1: fix inverted MMC card detect in U300 ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID ARM: 6294/1: etm: do a dummy read from OSSRR during initialization ARM: 6292/1: coresight: add ETM management registers ARM: 6288/1: ftrace: document mcount formats ARM: 6287/1: ftrace: clean up mcount assembly indentation ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR" ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h> ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3 ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig ARM: S5PV210: Override FIMC driver name on Aquila board ARM: S5PC100: enable FIMC on SMDKC100 ... Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to different subsystem 'setname' calls, and trivial port types in include/linux/serial_core.h
2010-08-11arm: samsung: remove pixclock from several boardsMaurus Cuelenaere
Since "s3c-fb: Automatically calculate pixel clock when none is given", there's no need for manually calculating the pixel clock anymore so remove these lines and add the correct refresh rate where appropriately. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Cc: Pawel Osciak <p.osciak@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11s3c-fb: add device name initializationPawel Osciak
Add framebuffer device name initialization calls for S3C2443, S3C64xx and S5P machines. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11s3c-fb: initial move to unifying the header filesBen Dooks
Remove the various header files that configure this driver and use the platform device name to select the correct configuration at probe time. Currently this does not remove the header files, only updates the driver and the relevant platform files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: KyungMin Park <kyungmin.park.samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09ARM: S5PC100: enable FIMC on SMDKC100Sylwester Nawrocki
Add support for FIMC on Samsung SMDKC100 board. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-06Merge branch 'next-samsung' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s5p6440/Kconfig arch/arm/mach-s5p6442/Kconfig arch/arm/mach-s5pc100/Kconfig arch/arm/mach-s5pv210/Kconfig arch/arm/mach-s5pv210/cpu.c arch/arm/plat-samsung/include/plat/sdhci.h
2010-08-06Merge branch 'next-s5p' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s5pv210/mach-aquila.c arch/arm/mach-s5pv210/mach-goni.c
2010-08-06ARM: SAMSUNG: Fix on inclusion mach/gpio.h for Samsung SoCsKukjin Kim
This patch fixes on inclusion <mach/gpio.h> to <linux/gpio.h> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org>
2010-08-06ARM: SAMSUNG: Add platform definitions and helpers for FIMC driverSylwester Nawrocki
FIMC (CAMIF) device is a camera interface embedded in S3C/S5P Samsung SOC series. It supports ITU-R BT.601/656 and MIPI-CSI2 standards, memory to memory operations, color conversion, resizing and rotation. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
