path: root/arch/arm/mach-sa1100/Makefile
2008-04-10[ARM] 4961/1: gpiolib support for SA-1100 architectureDmitry Baryshkov
This adds gpiolib support for the SA-1100 arch: - Move all GPIO API functions from generic.c into gpio.c - Convert all gpio functions into gpiolib callbacks. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4506/1: HP Jornada 7XX: Addition of SSP Platform DriverKristoffer Ericson
These patches add full SSP/MCU support for the HP Jornada 720 machine. Its needed to handle keyboard, touchscreen, battery and backlight/lcd. The main driver exports functions and the header file exports the command values. When talking to the MCU the general procedure is to start MCU, send command (using ssp_inout(command)), the proper reply is always TXDUMMY. After receiving TXDUMMY you can send the value you wish pushed (for example brightness level). End with ssp_end() so the spinlock gets unlocked. Drivers using this havent been implemented yet, but will shortly. Signed-off-by: Kristoffer Ericson <Kristoffer.ericson@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert SA1111 to use clock architectureRussell King
