path: root/arch/arm/mach-shmobile
2016-10-07Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - We get support for running in big-endian mode on two platforms: sunxi (Allwinner) and s3c24xx (old Samsung). - The recently added Uniphier platform now uses standard PSCI methods for SMP booting and we remove support for old bootloader versions that did not support it yet. - In sunxi, we gain support for the "Nextthing GR8" SoC, which is a close relative of the Allwinner A13 and R8 chips. - PXA completes its move over to the generic dmaengine framework and removes its old private API - mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC with integrated 802.11ac wireless networking" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: imx legacy: pca100: move peripheral initialization to .init_late ARM: imx legacy: mx27ads: move peripheral initialization to .init_late ARM: imx legacy: mx21ads: move peripheral initialization to .init_late ARM: imx legacy: pcm043: move peripheral initialization to .init_late ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late ARM: imx legacy: vpr200: move peripheral initialization to .init_late ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late ARM: imx legacy: qong: move peripheral initialization to .init_late ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late ARM: imx legacy: pcm037: move peripheral initialization to .init_late ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late ARM: imx legacy: mx31ads: move peripheral initialization to .init_late ARM: imx legacy: mx31lite: move peripheral initialization to .init_late ARM: imx legacy: kzm: move peripheral initialization to .init_late MAINTAINERS: update list of Oxnas maintainers ARM: orion5x: remove extraneous NO_IRQ ARM: orion: simplify orion_ge00_switch_init ...
2016-10-07Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "The cleanups for v4.9 are a little larger that usual, but thankfully that is almost exclusively due to removing a significant number of files that have become obsolete after the still ongoing conversion of old board files to devicetree. - for mach-omap2, which is still the largest platform in arch/arm/, the conversion to DT is finally complete after the Nokia N900 is now fully supported there, along with the omap3 LDP, and we can remove those two board files. If no regressions are found, another large cleanup for the platform will happen as a follow-up, removing dead code and restructuring the platform based on being DT-only. - In mach-imx, similar work is ongoing, but has not come that far. This time, we remove the obsolete board file for the i.MX1 generation, which like i.MX25, i.MX5, i.MX6, and i.MX7 is now DT-only. The remaining board files are for i.MX2 and i.MX3 machines based on old ARM926 or ARM1136 cores that should work with DT in principle. - realview has just been converted from board files to DT, and a lot of code gets removed in the process. This is the last ARM/Keil/Versatile derived platform that was still using board files, the other ones being integrator, versatile and vexpress. We can probably merge the remaining code into a single directory in the near future. - clps711x had completed the conversion in v4.8, but we accidentally left the files in place that should have been deleted then" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits) ARM: select PCI_DOMAINS config from ARCH_MULTIPLATFORM ARM: stop *MIGHT_HAVE_PCI* config from being selected redundantly ARM: imx: (trivial) fix typo and grammar ARM: clps711x: remove extraneous files ARM: imx: use IS_ENABLED() instead of checking for built-in or module ARM: OMAP2+: use IS_ENABLED() instead of checking for built-in or module ARM: OMAP1: use IS_ENABLED() instead of checking for built-in or module ARM: imx: remove platform-mxc_rnga ARM: realview: imply device tree boot ARM: realview: no need to select SMP_ON_UP explicitly ARM: realview: delete the RealView board files ARM: imx: no need to select SMP_ON_UP explicitly ARM: i.MX: Move SOC_IMX1 into 'Device tree only' ARM: i.MX: Remove i.MX1 non-DT support ARM: i.MX: Remove i.MX1 Synertronixx SCB9328 board support ARM: i.MX: Remove i.MX1 Armadeus APF9328 board support ARM: mxs: remove obsolete startup code for TX28 ARM: i.MX31 iomux: remove duplicates with alternate name ARM: i.MX31 iomux: remove plain duplicates ARM: OMAP2+: Drop legacy board file for LDP ...
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-09-21ARM: select PCI_DOMAINS config from ARCH_MULTIPLATFORMKishon Vijay Abraham I
PCI_DOMAINS config should be selected for any SoCs having more than a single PCIe controller. Without PCI_DOMAINS config, only one PCIe controller gets registered. Select PCI_DOMAINS in ARCH_MULTIPLATFORM if PCI is selected, since it doesn't harm even if a platform has a single PCIe port. Also remove PCI_DOMAINS being selected from other platform specific configs. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-09-19ARM/shmobile: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine so the old notifier based cpuhotplug infrastructure can be removed. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: linux-sh@vger.kernel.org Cc: Peter Zijlstra <peterz@infradead.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Simon Horman <horms@verge.net.au> Cc: rt@linutronix.de Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/20160906170457.32393-3-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-15Merge tag 'renesas-soc-for-v4.9' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/soc Pull "Renesas ARM Based SoC Updates for v4.9" from Simon Horman: Clean-up: * Only use smp_init when SMP is selected Enablement: * Add debug-ll support for r8a7992 * tag 'renesas-soc-for-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7791: only use smp_init when SMP is selected ARM: shmobile: r8a7790: only use smp_init when SMP is selected ARM: debug-ll: Add support for r8a7992
2016-09-09Merge tag 'renesas-fixes-for-v4.8' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes Merge "Renesas ARM Based SoC Fixes for v4.8" from Simon Horman: * Correct R-Car Gen2 regulator quirk * tag 'renesas-fixes-for-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: fix regulator quirk for Gen2
2016-09-02ARM: shmobile: fix regulator quirk for Gen2Wolfram Sang
The current implementation only works if the da9xxx devices are added before their drivers are registered. Only then it can apply the fixes to both devices. Otherwise, the driver for the first device gets probed before the fix for the second device can be applied. This is what fails when using the IP core switcher or when having the i2c master driver as a module. So, we need to disable both da9xxx once we detected one of them. We now use i2c_transfer with hardcoded i2c_messages and device addresses, so we don't need the da9xxx client devices to be instantiated. Because the fixup is used on specific boards only, the addresses are not going to change. Fixes: 663fbb52159cca ("ARM: shmobile: R-Car Gen2: Add da9063/da9210 regulator quirk") Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> (r8a7791/koelsch) Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-08-24ARM: shmobile: r8a7791: only use smp_init when SMP is selectedWolfram Sang
We use the helper function which populates the smp_init pointer only in case of SMP. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-08-24ARM: shmobile: r8a7790: only use smp_init when SMP is selectedWolfram Sang
2016-08-02ARM: shmobile: don't call platform_can_secondary_boot on UPArnd Bergmann
For rcar-gen2, we build the SMP files even for UP configurations, and that just broke: arch/arm/mach-shmobile/built-in.o: In function `shmobile_smp_init_fallback_ops': pm-rcar-gen2.c:(.init.text+0x40c): undefined reference to `platform_can_secondary_boot' This adds an compile-time check before the call to platform_can_secondary_boot, turning the function into an empty stub for UP configurations. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: c21af444eace ("ARM: shmobile: smp: Add function to prioritize DT SMP") Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-08-01Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "Improved and new platform support for various SoCs: New SoC support: - Broadcom BCM23550 - Freescale i.MX7Solo - Qualcomm MDM9615 - Renesas r8a7792 Improvements: - convert clps711x to multiplatform - debug uart improvements for Atmel platforms - Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram - OMAP tweaks and improvements to hwmod - OMAP support for kexec on SMP" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits) ARM: davinci: fix build break because of undeclared dm365_evm_snd_data ARM: s3c64xx: smartq: Avoid sparse warnings ARM: sti: Implement dummy L2 cache's write_sec ARM: STi: Update machine _namestr to be more generic. arm: meson: explicitly select clk drivers ARM: tango: add Suspend-to-RAM support ARM: hisi: consolidate the hisilicon machine entries ARM: tango: fix CONFIG_HOTPLUG_CPU=n build MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry MAINTAINERS: Update BCM63XX entry MAINTAINERS: Add NS2 entry MAINTAINERS: Fix nsp false-positives MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs ARM: clps711x: Switch to MULTIPLATFORM ARM: clps711x: Remove boards support ARM: clps711x: Add basic DT support ARM: clps711x: Reduce static map size ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu ARM: oxnas: Change OX810SE default driver config ...
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-07-06Merge tag 'renesas-soc2-for-v4.8' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/soc Second Round of Renesas ARM Based SoC Updates for v4.8 * Add DT support to the APMU driver and prioritise DT APMU support * Obtain extal frequency from DT * Add support for r8a7792 * tag 'renesas-soc2-for-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7791: Prioritize DT APMU support ARM: shmobile: r8a7790: Prioritize DT APMU support ARM: shmobile: smp: Add function to prioritize DT SMP ARM: shmobile: apmu: Add APMU DT support via Enable method ARM: shmobile: apmu: Move #ifdef CONFIG_SMP to cover more functions ARM: shmobile: rcar-gen2: Correct arch timer frequency on R-Car V2H ARM: shmobile: rcar-gen2: Obtain extal frequency from DT ARM: shmobile: r8a7792: basic SoC support soc: renesas: rcar-sysc: Improve SYSC interrupt config in legacy wrapper soc: renesas: rcar-sysc: Move SYSC interrupt config to rcar-sysc driver soc: renesas: rcar-sysc: Make rcar_sysc_init() init the PM domains soc: renesas: rcar-sysc: Fix uninitialized error code in rcar_sysc_pd_init() soc: renesas: rcar-sysc: add R8A7792 support soc: renesas: rcar-sysc: Add support for R-Car M3-W power areas soc: renesas: Add r8a7796 SYSC PM Domain Binding Definitions soc: renesas: rcar-sysc: Document r8a7796 support Signed-off-by: Olof Johansson <olof@lixom.net>
2016-07-06Merge ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB changes into next/socArnd Bergmann
* commit '5c34a4e89c743339f78cafb2f2a826a010f0746a': ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB ARM: uniphier: drop code for old DT binding These cause a harmless conflict with the clps711x multiplatform support, and it's easy to resolve. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-06-29ARM: shmobile: r8a7791: Prioritize DT APMU supportMagnus Damm
Adjust the r8a7791 SoC support code to not configure any non-DT SMP code in case the DT-based enable-method has been installed already. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: r8a7790: Prioritize DT APMU supportMagnus Damm
Adjust the r8a7790 SoC support code to not configure any non-DT SMP code in case the DT-based enable-method has been installed already. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: smp: Add function to prioritize DT SMPMagnus Damm
Add a function to check if other DT based method is available, and if so return false to not hook up smp_ops from the machine vector. This results in that DT-based SMP support has priority over older C-based smp_ops code, and in case DT-based SMP support code does not exist in the DTB then the old smp_ops code will still work as-is. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: apmu: Add APMU DT support via Enable methodMagnus Damm
Allow DT configuration of the APMU hardware in the case when the APMU is pointed out in the DTB via the enable-method. The ability to configure the APMU via C code is still kept intact to prevent DTB breakage for older SoCs that do not rely on the enable-method for SMP support. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> [geert: Fix CONFIG_SMP=n build] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: apmu: Move #ifdef CONFIG_SMP to cover more functionsGeert Uytterhoeven
shmobile_smp_apmu_prepare_cpus() is used only if CONFIG_SMP=y. Hence move the #ifdef to cover shmobile_smp_apmu_prepare_cpus() and all functions only called by it (apmu_init_cpu() and apmu_parse_cfg()). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: rcar-gen2: Correct arch timer frequency on R-Car V2HGeert Uytterhoeven
According to the datasheet, the frequency of the ARM architecture timer on R-Car V2H depends on the frequency of the ZS clock, just like on R-Car E2. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Tested-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: rcar-gen2: Obtain extal frequency from DTGeert Uytterhoeven
On some R-Car Gen2 SoCs, the frequency of the ARM architecture timer depends on the frequency of the external clock crystal. Currently the latter is determined indirectly from the state of the mode pins, which is a relic predating DT. Obtain the external clock crystal frequency from DT instead, removing the dependency on the mode pins. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: shmobile: r8a7792: basic SoC supportSergei Shtylyov
Add minimal support for the R-Car V2H (R8A7792) SoC. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29Merge branch 'rcar-sysc-for-v4.8' into HEADSimon Horman
2016-06-29soc: renesas: rcar-sysc: Move SYSC interrupt config to rcar-sysc driverGeert Uytterhoeven
On R-Car H1 and Gen2, the SYSC interrupt registers are always configured using hardcoded values in platform code. For R-Car Gen2, values are provided for H2 and M2-W only, other SoCs are not yet supported, and never will be. Move this configuration from SoC-specific platform code to the rcar_sysc_init() wrapper, so it can be skipped if the SYSC is configured from DT. This would be the case not only for H1, H2, and M2-W using a modern DTS, but also for other R-Car Gen2 SoCs not supported by the platform code, relying purely on DT. There is no longer a need to return the mapped register block, hence make the function return void. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-23arm: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Ray Jui <rjui@broadcom.com> Cc: Lee Jones <lee@kernel.org> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Kukjin Kim <kgene@kernel.org> Cc: Rob Herring <robh@kernel.org> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Cc: Tony Prisk <linux@prisktech.co.nz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-05-30ARM: shmobile: rcar-gen2: Use ICRAM1 for jump stub on all SoCsGeert Uytterhoeven
Currently the different SoCs in the R-Car Gen2 family use different types of on-chip RAM for the jump stub: - R-Car H2 uses Media RAM, - R-Car M2-W uses another type of optional On-chip RAM, as it doesn't have Media RAM, - R-Car M2-N uses Inter Connect RAM in Magnus Damm's "ARM: shmobile: r8a7793 boot address update". As all R-Car Gen2 SoCs have 4 KiB of Inter Connect RAM, consolidate the code by always using that. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-30ARM: shmobile: pm-rmobile: Postpone call to pm_genpd_init()Geert Uytterhoeven
All local setup of the generic_pm_domain structure should have been completed before calling pm_genpd_init(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-18Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "Driver updates for ARM SoCs, these contain various things that touch the drivers/ directory but got merged through arm-soc for practical reasons. For the most part, this is now related to power management controllers, which have not yet been abstracted into a separate subsystem, and typically require some code in drivers/soc or arch/arm to control the power domains. Another large chunk here is a rework of the NVIDIA Tegra USB3.0 support, which was surprisingly tricky and took a long time to get done. Finally, reset controller handling as always gets merged through here as well" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) arm-ccn: Enable building as module soc/tegra: pmc: Add generic PM domain support usb: xhci: tegra: Add Tegra210 support usb: xhci: Add NVIDIA Tegra XUSB controller driver dt-bindings: usb: xhci-tegra: Add Tegra210 XUSB controller support dt-bindings: usb: Add NVIDIA Tegra XUSB controller binding PCI: tegra: Support per-lane PHYs dt-bindings: pci: tegra: Update for per-lane PHYs phy: tegra: Add Tegra210 support phy: Add Tegra XUSB pad controller support dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding phy: core: Allow children node to be overridden clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs drivers: firmware: psci: make two helper functions inline soc: renesas: rcar-sysc: Add support for R-Car H3 power areas soc: renesas: rcar-sysc: Add support for R-Car E2 power areas soc: renesas: rcar-sysc: Add support for R-Car M2-N power areas soc: renesas: rcar-sysc: Add support for R-Car M2-W power areas soc: renesas: rcar-sysc: Add support for R-Car H2 power areas ...
2016-05-18Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "We get support for three new 32-bit SoC platforms this time. The amount of changes in arch/arm for any of them is miniscule, as all the interesting code is in device driver subsystems (irqchip, clk, pinctrl, ...) these days. I'm listing them here, as the addition of the Kconfig statement is the main relevant milestone for a new platform. In each case, some drivers are are shared with existing platforms, while other drivers are added for v4.7 as well, or come in a later release. - The Aspeed platform is probably the most interesting one, this is what most whitebox servers use as their baseboard management controller. We get support for the very common ast2400 and ast2500 SoCs. The OpenBMC project focuses on this chip, and the LWN article about their ELC 2016 presentation at https://lwn.net/Articles/683320/ triggered the submission, but the code comes from IBM's OpenPOWER team rather than the team at Facebook. There are still a lot more drivers that need to get added over time, and I hope both teams can work together on that. - OXNAS is an old platform for Network Attached Storage devices from Oxford Semiconductor. There are models with ARM10 (!) and ARM11MPCore cores, but for now, we only support the original ARM9 based versions. The product lineup was subsequently part of PLX, Avago and now the new Broadcom Ltd. https://wiki.openwrt.org/doc/hardware/soc/soc.oxnas has some more information. - V2M-MPS2 is a prototyping platform from ARM for their Cortex-M cores and is related to the existing Realview / Versatile Express lineup, but without MMU. We now support various NOMMU platforms, so adding a new one is fairly straightforward. http://infocenter.arm.com/help/topic/com.arm.doc.100112_0100_03_en/ has detailed information about the platform. Other noteworthy updates: - Work on LPC32xx has resumed, and Vladimir Zapolskiy and Sylvain Lemieux are now maintaining the platform. This is an older ARM9 based platform from NXP (not Freescale), but it remains in use in embedded markets. - Kevin Hilman is now co-maintaining the Amlogic Meson platform for both 32-bit and 64-bit ARM, and started contributing some patches. - As is often the case, work on the OMAP platforms makes up the bulk of the actual SoC code changes in arch/arm, but there isn't a lot of that either" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits) MAINTAINERS: ARM/Amlogic: add co-maintainer, misc. updates MAINTAINERS: add ARM/NXP LPC32XX SoC specific drivers to the section MAINTAINERS: add new maintainers of NXP LPC32xx SoC MAINTAINERS: move ARM/NXP LPC32xx record to ARM section arm: Add Aspeed machine ARM: lpc32xx: remove duplicate const on lpc32xx_auxdata_lookup ARM: lpc32xx: remove leftovers of legacy clock source and provider drivers ARM: lpc32xx: remove reboot header file ARM: dove: Remove CLK_IS_ROOT ARM: orion5x: Remove CLK_IS_ROOT ARM: mv78xx0: Remove CLK_IS_ROOT ARM: davinci: da850: use clk->set_parent for async3 ARM: davinci: Move clock init after ioremap. MAINTAINERS: Update ARM Versatile Express platform entry ARM: vexpress/mps2: introduce MPS2 platform MAINTAINERS: add maintainer entry for ARM/OXNAS platform ARM: Add new mach-oxnas irqchip: versatile-fpga: add new compatible for OX810SE SoC ARM: uniphier: correct the call order of of_node_put() MAINTAINERS: fix stale TI DaVinci entries ...
2016-05-16Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (63 commits) intel_pstate: Clean up get_target_pstate_use_performance() intel_pstate: Use sample.core_avg_perf in get_avg_pstate() intel_pstate: Clarify average performance computation intel_pstate: Avoid unnecessary synchronize_sched() during initialization cpufreq: schedutil: Make default depend on CONFIG_SMP cpufreq: powernv: del_timer_sync when global and local pstate are equal cpufreq: powernv: Move smp_call_function_any() out of irq safe block intel_pstate: Clean up intel_pstate_get() cpufreq: schedutil: Make it depend on CONFIG_SMP cpufreq: governor: Fix handling of special cases in dbs_update() cpufreq: intel_pstate: Ignore _PPC processing under HWP cpufreq: arm_big_little: use generic OPP functions for {init, free}_opp_table cpufreq: tango: Use generic platdev driver cpufreq: Fix GOV_LIMITS handling for the userspace governor cpufreq: mvebu: Move cpufreq code into drivers/cpufreq/ cpufreq: dt: Kill platform-data mvebu: Use dev_pm_opp_set_sharing_cpus() to mark OPP tables as shared cpufreq: dt: Identify cpu-sharing for platforms without operating-points-v2 cpufreq: governor: Change confusing struct field and variable names cpufreq: intel_pstate: Enable PPC enforcement for servers ...
2016-04-25cpufreq: shmobile: Use generic platdev driverViresh Kumar
The cpufreq-dt-platdev driver supports creation of cpufreq-dt platform device now, reuse that and remove similar code from platform code. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-22soc: renesas: Move pm-rcar to drivers/soc/renesas/rcar-syscGeert Uytterhoeven
Move the pm-rcar driver from arch/arm/mach-shmobile/ to drivers/soc/renesas/, and its header file to include/linux/soc/renesas/, so it can be shared between arm32 (R-Car H1 and Gen2) and arm64 (R-Car Gen3). Rename it to rcar-sysc as it's really a driver for the R-Car System Controller (SYSC). Kill the intermediate PM_RCAR config symbol, as it's not user configurable anymore, and to prepare for SoC-specific make rules. Add the missing #include <linux/types.h> to rcar-sysc.h, which was exposed by different include order. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-04-20ARM: shmobile: timer: Drop support for Cortex A8Geert Uytterhoeven
Commit edf4100906044225 ("ARM: shmobile: sh7372 dtsi: Remove Legacy file") removed the DTS for the last shmobile SoC with a Cortex A8 CPU core (sh7372 aka SH-Mobile AP4), hence drop support for it in the loops-per-jiffy preset code. As "div" is always 1 for supported contemporary ARM processors, we can simplify the code: - Absorb shmobile_setup_delay_hz(), which was always called with mult = div = 1, - Return earlier if the Cortex A7/A15 arch timer exists and support is enabled. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-04-20ARM: shmobile: timer: Fix preset_lpj leading to too short delaysGeert Uytterhoeven
On all shmobile ARM SoCs, loop-based delays may complete early, which can be after only 1/3 (Cortex A9) or 1/2 (Cortex A7 or A15) of the minimum required time. This is caused by calculating preset_lpj based on incorrect assumptions about the number of clock cycles per loop: - All of Cortex A7, A9, and A15 run __loop_delay() at 1 loop per CPU clock cycle, - As of commit 11d4bb1bd067f9d0 ("ARM: 7907/1: lib: delay-loop: Add align directive to fix BogoMIPS calculation"), Cortex A8 runs __loop_delay() at 1 loop per 2 instead of 3 CPU clock cycles. On SoCs with Cortex A7 and/or A15 CPU cores, this went unnoticed, as delays use the ARM arch timer if available. R-Car Gen2 doesn't work if the arch timer is disabled. However, APE6 can be used without the arch timer. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-03-23Merge tag 'clk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clk updates from Stephen Boyd: "The clk changes for this release cycle are mostly dominated by new device support in terms of LoC, but there has been some cleanup in the core as well as the usual minor clk additions to various drivers. Core: - parent tracking has been simplified - CLK_IS_ROOT is now a no-op flag, cleaning up drivers has started - of_clk_init() doesn't consider disabled DT nodes anymore - clk_unregister() had an error path bug squashed - of_clk_get_parent_count() has been fixed to only return unsigned ints - HAVE_MACH_CLKDEV is removed now that the last arch user (ARM) is gone New Drivers: - NXP LPC18xx creg - QCOM IPQ4019 GCC - TI dm814x ADPLL - i.MX6QP Updates: - Cyngus audio clks found on Broadcom iProc devices - Non-critical fixes for BCM2385 PLLs - Samsung exynos5433 updates for clk id errors, HDMI support, suspend/resume simplifications - USB, CAN, LVDS, and FCP clks on shmobile devices - sunxi got support for more clks on new SoCs and went through a minor refactoring/rewrite to use a simpler factor clk construct - rockchip added some more clk ids and added suport for fraction dividers - QCOM GDSCs in msm8996 - A new devm helper to make adding custom actions simpler (acked by Greg)" * tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (197 commits) clk: bcm2835: fix check of error code returned by devm_ioremap_resource() clk: renesas: div6: use RENESAS for #define clk: renesas: Rename header file renesas.h clk: max77{686,802}: Remove CLK_IS_ROOT clk: versatile: Remove CLK_IS_ROOT clk: sunxi: Remove use of variable length array clk: fixed-rate: Remove CLK_IS_ROOT clk: qcom: Remove CLK_IS_ROOT doc: dt: add documentation for lpc1850-creg-clk driver clk: add lpc18xx creg clk driver clk: lpc32xx: fix compilation warning clk: xgene: Add missing parenthesis when clearing divider value clk: mb86s7x: Remove CLK_IS_ROOT clk: x86: Remove clkdev.h and clk.h includes clk: x86: Remove CLK_IS_ROOT clk: mvebu: Remove CLK_IS_ROOT clk: renesas: move drivers to renesas directory clk: si5{14,351,70}: Remove CLK_IS_ROOT clk: scpi: Remove CLK_IS_ROOT clk: s2mps11: Remove CLK_IS_ROOT ...
2016-03-20Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "Newly added support for additional SoCs: - Axis Artpec-6 SoC family - Allwinner A83T SoC - Mediatek MT7623 - NXP i.MX6QP SoC - ST Microelectronics stm32f469 microcontroller New features: - SMP support for Mediatek mt2701 - Big-endian support for NXP i.MX - DaVinci now uses the new DMA engine dma_slave_map - OMAP now uses the new DMA engine dma_slave_map - earlyprintk support for palmchip uart on mach-tango - delay timer support for orion Other: - Exynos PMU driver moved out to drivers/soc/ - Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP, uniphier" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: uniphier: rework SMP code to support new System Bus binding ARM: uniphier: add missing of_node_put() ARM: at91: avoid defining CONFIG_* symbols in source code ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1 ARM: imx: Make reset_control_ops const ARM: imx: Do L2 errata only if the L2 cache isn't enabled ARM: imx: select ARM_CPU_SUSPEND only for imx6 dmaengine: pxa_dma: fix the maximum requestor line ARM: alpine: select the Alpine MSI controller driver ARM: pxa: add the number of DMA requestor lines dmaengine: mmp-pdma: add number of requestors dma: mmp_pdma: Add the #dma-requests DT property documentation ARM: OMAP2+: Add rtc hwmod configuration for ti81xx ARM: s3c24xx: Avoid warning for inb/outb ARM: zynq: Move early printk virtual address to vmalloc area ARM: DRA7: hwmod: Add custom reset handler for PCIeSS ARM: SAMSUNG: Remove unused register offset definition ARM: EXYNOS: Cleanup header files inclusion drivers: soc: samsung: Enable COMPILE_TEST MAINTAINERS: Add maintainers entry for drivers/soc/samsung ...
2016-03-15clk: renesas: Rename header file renesas.hSimon Horman
This is part of an ongoing process to migrate from ARCH_SHMOBILE to ARCH_RENESAS the motivation for which being that RENESAS seems to be a more appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs. Along with the above mentioned Kconfig changes it seems appropriate to also rename files. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2016-02-26Merge tag 'renesas-cleanup2-for-v4.6' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/cleanup Merge "Second Round of Renesas ARM Based SoC Cleanup for v4.6" from Simon Horman: * Remove stale comment from Kconfig * Consolidate SCU mapping code * tag 'renesas-cleanup2-for-v4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: Kconfig: Get rid of old comment ARM: shmobile: Consolidate SCU mapping code
2016-02-19ARM: shmobile: Enable PM and PM_GENERIC_DOMAINS for SoCs with PM DomainsGeert Uytterhoeven
All supported Renesas ARM SoCs (except for Emma Mobile EV2) have clock domains. Some SoCs also have power domains. To ensure proper operation of on-SoC modules, module clocks must be ungated, and power domains must be powered up when needed. Currently the user can choose to build a kernel with power management enabled or disabled: - If CONFIG_PM=y, power domains and/or module clocks are handled dynamically by Runtime PM and the generic power domain. - If CONFIG_PM=n, power domains are assumed to be powered up by reset state or by the boot loader, and module clocks are handled by the legacy clock domain on driver (un)bind. The latter is implemented using a platform bus notifier, which applies not only to all on-SoC devices, but to all platform devices present in the system. To remove the dependency on implicit assumptions, and to get rid of the peculiarities of the legacy clock domain, enable CONFIG_PM and CONFIG_PM_GENERIC_DOMAINS unconditionally, for all Renesas ARM SoCs with clock and/or power domains. This does cause an increase in kernel size. Given bloat-o-meter reports a modest increase of 26 KiB for an RZ/A1H kernel, this should not be a problem, even when used on RZ/A1H with XIP and internal RAM only. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-19ARM: shmobile: emev2: Move declaration of emev2_smp_ops to emev2.hGeert Uytterhoeven
make C=1: arch/arm/mach-shmobile/smp-emev2.c:51:29: warning: symbol 'emev2_smp_ops' was not declared. Should it be static? To fix this, move the forward declaration of emev2_smp_ops to a header file, and include it where appropriate. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-19ARM: shmobile: emev2: Remove legacy machine_desc.map_io() callbackGeert Uytterhoeven
Commit FIXME ("ARM: shmobile: Consolidate SCU mapping code") removed the last user of the static mapping on emev2-based systems. Remove the mapping and the legacy machine_desc.map_io() callback. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-19ARM: shmobile: r8a7740: Remove legacy machine_desc.map_io() callbackGeert Uytterhoeven
Commit 37201ba5c99d0be8 ("ARM: shmobile: r8a7740: Migrate to generic l2c OF initialization") removed the last user of the legacy "IOMEM()" macro on r8a7740-based systems. Hence there's no longer a need to set up a transparent mapping of system I/O registers. Remove the mapping and the legacy machine_desc.map_io() callback. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-19ARM: shmobile: r8a7740: Remove mapping of L2 cache controller registersGeert Uytterhoeven
Now all r8a7740-based platforms have been migrated to the generic l2c OF initialization, it's no longer needed to map the L2 cache controller registers from .map_io(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-19ARM: shmobile: r8a7740: Migrate to generic l2c OF initializationGeert Uytterhoeven
Migrate the generic r8a7740 platform from calling l2x0_of_init() to the generic l2c OF initialization. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-17ARM: shmobile: Kconfig: Get rid of old commentMagnus Damm
Remove comment that used to be part of non-multiplatform kernel support. Now with multiplatform-only we have no Renesas-specific System Configuration entries. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Acked-by: by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-17ARM: shmobile: Consolidate SCU mapping codeGeert Uytterhoeven
Currently the SCU registers are mapped in SoC-specific code, using different methods, all involving the static mapping set up from machine_desc.map_io(): - On emev2, a static (non-identity) mapping is used, with ioremap(). As the static mapping uses the MT_DEVICE type, ioremap() reuses it, and the returned virtual address is suitable for passing to shmobile_smp_hook(), - On sh73a0 and r8a7779, a static identity mapping is used, with the legacy IOMEM() macro. As the static mapping uses the MT_DEVICE_NONSHARED type, replacing IOMEM() by ioremap() would create a new mapping, whose virtual address cannot be passed to shmobile_smp_hook(). Move the mapping of the SCU registers from SoC-specific code to common code, always using ioremap(). To work in the absence of a static mapping, this requires passing the physical SCU base address to shmobile_smp_hook(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-17ARM: shmobile: Remove shmobile_boot_argGeert Uytterhoeven
CPU boot configuration writes to shmobile_boot_arg, which is located in the .text section, and thus should not be written to. As of commit 1d33a354bbb618ba ("ARM: shmobile: Per-CPU SMP boot / sleep code for SCU SoCs"), and ignoring accidental remainings, shmobile_boot_arg is always set to MPIDR_HWID_BITMASK by C code. Hence we can just hardcode this in the assembler code, and remove the variable, and thus also remove the need to write to this variable. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-17ARM: shmobile: Move shmobile_smp_{mpidr, fn, arg}[] from .text to .bssGeert Uytterhoeven
If CONFIG_DEBUG_RODATA=y, the kernel crashes during system suspend: Freezing user space processes ... (elapsed 0.004 seconds) done. Freezing remaining freezable tasks ... (elapsed 0.002 seconds) done. PM: suspend of devices complete after 111.948 msecs PM: late suspend of devices complete after 1.086 msecs PM: noirq suspend of devices complete after 11.576 msecs Disabling non-boot CPUs ... Kernel panic - not syncing: Attempted to kill the idle task! 1014ec ---[ end Kernel panic - not syncing: Attempted to kill the idle task! CPU0: stopping This happens because the .text section is marked read-only, while the arrays shmobile_smp_mpidr[], shmobile_smp_fn[], and shmobile_smp_arg[] are being written to. Fix this by moving these arrays from the .text to the .bss section. This requires accessing them through PC-relative offsets. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
