Modified board file to increase the speed of I2C connection
for Atmel touch driver from 100KHz to 400KHz
Bug 962710
Bug 950422
Change-Id: Ib0f08af35d84cfc1f33cc3771d2aa422f79d98d0
Signed-off-by: Ali Ekici <aekici@nvidia.com>
Reviewed-on: http://git-master/r/97744
Reviewed-by: Robert Collins <rcollins@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: David Jung <djung@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Modified touch setup and init calls to support DirectTouch
in E1198 19x12 system.
Change-Id: Ide208c4759af15200fb57530e7fbdc023d074c5c
Reviewed-on: http://git-master/r/91260
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 949759
Reduce DDC freq. The original freq is 100KHz, but some edid communication
at this rate on some monitors like acer H243HX may fail
Change-Id: Ib087025a35ff085b4bf618b70100fe6670c3eaec
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/88261
Do platform device registration for cardhu and E1186
& E1187 platforms only.
Bug 790141
Change-Id: I70a0144604631a0dd9499699f892f9fc7ec14d56
Signed-off-by: Jay Agarwal <jagarwal@nvidia.com>
Reviewed-on: http://git-master/r/93486
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Krishna Thota <kthota@nvidia.com>
add port id's for BT and HIFI and also disable(-1) the port id
for Baseband as Cardhu does not have a Baseband
Change-Id: I16914ce95c2153cd36691b1ef462d387e39d3fa5
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/90121
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug 941960
Removed CONFIG_TEGRA_INTERNAL_TSENSOR_EDP_SUPPORT.
Add internal tsensor on kai.
Change-Id: Iaefa43112fbbaa42d43a428ecb86ad821e683f85
Reviewed-on: http://git-master/r/84350
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
add support for maxim 98095 audio codec
Change-Id: I112130341363e18986158cd94a981a60a80fb0d0
Reviewed-on: http://git-master/r/75956
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/85485
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Moving clock source rate initialisation of debug ports in
common place from board files.
In this way, it does not need to call the same function from
all board files and so avoid duplicating.
Change-Id: I4e0292c7760488125c0dd8ee5fa23f50faca3436
Reviewed-on: http://git-master/r/85174
Change-Id: Idc0261b937471499dc5e3c549eae6dff43ca9118
Reviewed-on: http://git-master/r/84543
Just set the opt in booleans in the platform data instead of checking
which function to register for pm_power_off.
Change-Id: If336ff69e4b61b4220e6766b2643c5fba74d01cc
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83597
Clock audio from clkm as
a pre-condition of disabling pllp_out1 and plla
when I2S is in slave mode.
Change-Id: I1706c2989cf7ad9045526ceba3326777b702868a
Reviewed-on: http://git-master/r/76391
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Change-Id: I243508cc553ebf22bb5594a9461019abfec24b65
Reviewed-on: http://git-master/r/77753
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-on: http://git-master/r/76691
Change-Id: I0134c46c5fceb1ee863f97a6b6e1aed9608b842f
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/77739
Tegra3 platform may boot with one of the predefined fixed PLLP
(peripheral PLL) output rates: 216MHz, 408MHz, or 204MHz. This
commit implements auto-detection of PLLP rate, and debug uart
configuration during kernel uart initialization.
Bug 928260
Change-Id: I3fac4c462f28ac3dc1c72c0cc0f8f87fa0a809c4
Reviewed-on: http://git-master/r/75849
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/77294
Using fixed regulator in place of gpio-switch regulator.
Fixed regulator is very similar to gpio-switch regulator
and it is available by default in linux kernel.
gpio-switch-regulator will be used only for the open
collector load switches.
bug 923713
Change-Id: I42480cb314135d475b4d4b56bb5e8e73eba2f77e
Reviewed-on: http://git-master/r/74536
Reviewed-on: http://git-master/r/76465
remove CONFIG_USB_HOTPLUG and add default_enable into tegra_ehci_platform_data
We can't use different def_config because whistler & ventana source code
is merged in same tree.
BUG 923705
Change-Id: I3dfdf237d80865831264f02104c89c8088101905
Reviewed-on: http://git-master/r/74574
Signed-off-by: Kurt Yi <kyi@nvidia.com>
Reviewed-on: http://git-master/r/75888
Added dtv device to cardhu board
Fixed Bug 904626
Fixed Bug 881303
Change-Id: If1560cc8101403720c46b318c76326621c889154
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/68145
Reviewed-on: http://git-master/r/74892
cleanup ram console related source codes and move most of the
implementation in board files to common.c since ram console is a common
debug mechanism.
bug 873307
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/54598
Reviewed-on: http://git-master/r/66588
(cherry picked from commit 119ce36b7bed370a528dfebc80bd79698118248d)
Change-Id: I8b769b422305101a97f1fbc99db4af48dc7d4f25
Reviewed-on: http://git-master/r/71961
Reviewed-on: http://git-master/r/74552
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
This platform_device will be used for struct iommu_ops for SMMU in
addition to iovmm-smmu exclusively.
Change-Id: I8a15ba5ce40cd4bd5df255ecbe70a79a33fe8209
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/72216
Enable uarte as loopback interface for Cardhu and Enterprise boards.
Bug 845036
Bug 921090
Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Change-Id: Ib27a9dadeefec11fdf5a31ecd887eb2d788350d0
Reviewed-on: http://git-master/r/73178
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Add watchdog recovery mechanism to protect against hangs during
driver suspend/resume sequence
Bug 857748
Change-Id: I03d540b38318a5a953b1a697af123291b48991e9
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/65986
Change-Id: Idb51349471414b4ab6eb84de51a449077865021e
Reviewed-on: http://git-master/r/69872
Registering SPI1 as slave device which will be used in
loopback tests on E1198
Bug 903874
Reviewed-on: http://git-master/r/66790
(cherry picked from commit 87d7bc65a43dbb3a745c1bcb03e53ba44f8e80e9)
Change-Id: I22aeca2457dcb38125de48275e00c268fbe8792b
Reviewed-on: http://git-master/r/69189
Set i2s_sync clocks as parent of audio clocks in tegra_clk_init_table.
Entries are added only for active I2s ports for corresponding Tegra30
board.
Bug 911332
Change-Id: I86440cbff6432fcec3de249c9baf46aab785122f
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/69757
Enabling PCIE support in cardhu board.
Fixes bug: 637871
Reviewed-on: http://git-master/r/34474
(cherry picked from commit bde3e58d998b6e76934152219b8803327cea2fad)
Change-Id: I18c548b458ad3d17ec07d2ec5b16fd83897b44b1
Signed-off-by: Krishna Kishore <kthota@nvidia.com>
Reviewed-on: http://git-master/r/62072
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Added tc1, tc2, and passive delay to thermal framework
parameters.
Made thermal offsets more explicit and clean.
In throttling code, instead of using one 10 second 640000 entry,
split this into five 2 second entries. This will give better
temperature stability.
bug 877359
Change-Id: Idc463ab18bdabb7a0472f4f6572195bf76067bd4
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/68029
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Refactored Thermal module so that thermal device
drivers themselves are agnostic of the thermal
framework. Also separated throttle limit constraints
from EDP table.
Reviewed-on: http://git-master/r/57990
Reviewed-on: http://git-master/r/63338
Cherry-picked from 8d0610bdd03c3490b718f11bc2108f45cd868533.
Change-Id: I4f87889c9cdc88daac1e6173043bab1f2e7cebfd
Reviewed-on: http://git-master/r/66551
Modifies the bluesleep and rfkill platform driver registration to be more concise
and mirror the style of other similar code.
Change-Id: If5100248d0fe9cf00c1b78acbc72e3f45d173fa9
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/64601
Rebase-Id: R0ec1bc987d0286bfdff3a5db5ccd142050a38872
XMM modem requires GPIO power on sequence before modem
software can be downloaded to it.
BUG 828389
Change-Id: Ib8cf2a16a8b05a586d2f0b3bb57bad106a889cd1
Reviewed-on: http://git-master/r/46801
(cherry picked from commit 675f98979d6c6a281631d6590be5c7b6e5352b6f)
Reviewed-on: http://git-master/r/65958
Rebase-Id: Red280cdd7669487e2368b75d4e1cd1c2130b3829
sdmmc3 and sdmmc4 clocks need not be enabled by default.
Change-Id: I8b691ae6d906fd487e31e1fe5b764a37546e1eb5
Reviewed-on: http://git-master/r/62972
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Rebase-Id: R116ae11bba8880444eaf0b104f5ad84c66fb54d0
Implemented HSIC phy ready and phy off callabacks for
cardhu board.
BUG 828389
Reviewed-on: http://git-master/r/52883
(cherry picked from commit 9d2e1e07c00d1f84dc24ccb861c5fb9ca751cb9c)
Change-Id: I56e0fb118efb7670080355760eb05108b7d1f45a
Reviewed-on: http://git-master/r/58564
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Rebase-Id: Rba43e610309a58a96c9fcb208338a7124f4310b9
Various cleanup including removing two unneeded static variables and
an unneeded function, as well as reserving the ram console after the
carveout and framebuffer.
Reviewed-on: http://git-master/r/51214
(cherry-picked from commit cb64054a12aca84b097556c7c4f4e7c67916fd93)
Change-Id: I2b950a6a8637beed3910cc59f1e8028dc3c10562
Reviewed-on: http://git-master/r/55086
Rebase-Id: Rf58d7de18ab7714a58d3acb79e5cbec60e4294f9
fix for Bug 867991
Change-Id: I6213bbc53493179a177b65ab597f196653df712a
Reviewed-on: http://git-master/r/50483
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R8975279ac5d0d21cdcbf2a54e32a64e59797307e
Avoid power down HSIC phy during L2 suspend state.
Triggered postsuspend and preresume actions for xmm modem.
BUG 828389
Original-Change-Id: I2cd862361d5ba0fedf7e7bffac02c0dfbf5cf0c8
Reviewed-on: http://git-master/r/46654
Rebase-Id: R07b042064157d92b288da906c040b083d62df743
ram console will buffer kmsg in reserved memory block, which
will be written to file /proc/last_ksmg on bootup.
Original-Change-Id: I6be8b9d22ce08040bbd95bf740a84b565e2300cf
Reviewed-on: http://git-master/r/37104
Tested-by: Alon Farchy <afarchy@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Rebase-Id: R367cb265f487736c91fdcb0548d10a4b13f2f293
Added configuration option TEGRA_PLLM_RESTRICTED - when enabled,
PLLM - memory PLL - usage may be restricted to modules with dividers
capable of dividing maximum PLLM frequency at minimum voltage. When
disabled, PLLM is available as a clock source with no restrictions
(current configuration), which may effectively increase lower limit
for core voltage if high grade SDRAM is used.
Implemented PLLM restrictions in Tegra3 clock framework and DVFS, but
keep them disabled by default.
Bug 884419
(cherry picked from commit 5313ebcae92839146870d5865bc0f4cd08b35c61)
(cherry picked from commit 634647a9d2a8c1e03c8d98d0b2199950c947acc3)
Change-Id: I012452d92830ad6b63ec407350568b8c316b3caa
Reviewed-on: http://git-master/r/66512
Rebase-Id: R22de0f09e7af2640499ec8cd96e974328d78bace
Bug 872652
Change-Id: I89e505f6dedbb9de1a457f797362265cf06e76bb
Reviewed-on: http://git-master/r/59631
Rebase-Id: R32ad00191e44737732e40c3710077069dee7946c
1) configuring pinmux
2) create pn544_i2c_platform_data
3) register i2c device info using i2c_register_board_info
Bug 846684
Bug 873017
Change-Id: I6cc370d3ee6cc5df6b75db19bb719275e465f344
Reviewed-on: http://git-master/r/62746
Rebase-Id: R334a9cc8f86c90214b2415b3b855d5f234ad7a11
OTG host register/unregister functions were duplicated identically
across all board files, making the code difficult to maintain (and
actually some boards did not get all some code fixes leading to the same
bug being met again and again). This patch moves this common code into
tegra-otg.c.
Bug 884315
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Change-Id: I99b118664f0481f6c5470411b43f36609e0feb52
Reviewed-on: http://git-master/r/61763
Rebase-Id: R0f6060514c017946cc9ae2ba2f04a1c134d14d9b
Enable i2s3 and bluetooth dit device for cardhu. Also add i2s2 clock in
clock table. It is needed to support BT SCO playback/record.
Bug 872652
Change-Id: I3b702bbbd360db966447b099e982891383db27cd
Reviewed-on: http://git-master/r/62049
Rebase-Id: R035bff07f147e9100956df6c238bf7df60d89e93
Selecting debug console from linux command line.
bug 795847
Reviewed-on: http://git-master/r/51723
(cherry picked from commit ce5675f5a7607f9e549f84c42bea3df6f14c9008)
Change-Id: Ia242b6b0fed0b9d2fad6c66a14895e5574f6f5b9
Reviewed-on: http://git-master/r/61422
Rebase-Id: R3fd2b06fefa1b153d2c739c5d7c55b2265659225
Bug: 862023
Change-Id: I62a66cdf12fb78132d78b2e6853d32c3f8a8d68a
Reviewed-on: http://git-master/r/58675
Rebase-Id: Rfa42d87cff0a75794fe69ffbecba6e501448509e
Bug: 862023
Change-Id: Ibdb12ce9ae50b30e4c25ea43adc4c8c7e6516858
Reviewed-on: http://git-master/r/59863
Rebase-Id: R780104b6f8c11bc22c95245989ff517977244267
Set GPIO direction to high on main k39 branch.
bug 817238
Change-Id: I2960b4a325d8013295528790a28daea4a58e10cd
Reviewed-on: http://git-master/r/58020
Rebase-Id: R3a80bfd11cd3959fd2c760eda277f6db42ecb333
Removed Tegra3 pll_m refcount from common and board initialization.
As a result pll_m is turned off when all client clocks are disabled.
Added pll_m disable/enable control via PMC registers - this one
actually works on Tegra3; kept clock register control in place, just
in case.
Originally implemented in dee91eaf47a7e6b392e9663170dcfdcdde73446c.
Bug 888476
Change-Id: Ifa70d25ce8d93abc12c741d3a51b32110db3f7dd
Reviewed-on: http://git-master/r/60129
Rebase-Id: Rf4201b6244e1dc202793730afa900a6b15b658b9
This change supports PM313 with 19X12 panel.
The change uses PM313 in "Single input to Dual output" mode
Bug ID : 822980
Reviewed-on: http://git-master/r/50215
(cherry picked from commit b83e795747fa860b5b7fb66b2067ebe4f15bcfd0)
Change-Id: Iabf707ded2976e9877481c215d0b1f1940781f14
Reviewed-on: http://git-master/r/60085
Rebase-Id: Re8eadc35c75fa21b0a5f3cb3bee0e8cb77dc3238
Change the pll source of i2c from CLK_M to PLL_P_OUT0.
Bug 856468
Change-Id: I0865d0679fcc7ae2b862b9f68900275ab05da5ec
Reviewed-on: http://git-master/r/57505
Rebase-Id: R04fd8dd082ad497a7ca7673f593fb4e309b3a2da
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
Rebase-Id: R7fadbdc30bdca30e41e0b7fdb88628dbc8c32e82
The w_disable pin is connected to different gpio in
E1198-A02 compare to E1198-A01. Making related changes
to support E1198-A02.
bug 864282
Reviewed-on: http://git-master/r/48877
(cherry picked from commit 009e0b9ccf776e658c27df59716cc1cce075ad31)
Change-Id: I85b7f0b10dd3549f07c48e71ffca1a304afc753d
Reviewed-on: http://git-master/r/57790
Rebase-Id: Rbf1f0f4775d536ba198f3c5a3ff3088c75d988fb
Hotplug on usb is supported when hotplug flag is set in platform data
Bug 869745
(cherry picked from commit I57ba0b18a2d4232b2df2074c91aff97c6e639e7d)
Reviewed-on: http://git-master/r/54588
Change-Id: I24e5ddf49cead14d3eebe30da0f92402015c95c7
Reviewed-on: http://git-master/r/57725
Tested-by: Artiste Hsu <chhsu@nvidia.com>
Rebase-Id: Rdf4296a0b0e04733832b8b60b347a3da9cc67413
On cardhu and ventana WM8903 GPIO1 is used for digital mic lrclk
output and GPIO2 is used for digital mic data input. Pass corresponding
WM8903 gpio configuration through platform data to enable cardhu and
ventana digital mic support.
Bug 872652
Change-Id: I410265f1b4f9a8c5e43e5437ed6bac4122709178
Reviewed-on: http://git-master/r/55654
Rebase-Id: Rb47b7afe17013d4a0d5d73a15ba19c12dab0efbf
