- Add cl-dvfs platform data
- Add function call to get cpu clock switch cooling
device trip points.
Bug 1563635
Change-Id: I07e0a9e8d170543906f91979fb35b98c02fe18cb
Signed-off-by: sreenivasulu velpula <svelpula@nvidia.com>
Reviewed-on: http://git-master/r/437195
(cherry picked from commit 55321cec6a72dd9b2e0ad6fb94ff2cc42937a14a)
Reviewed-on: http://git-master/r/559393
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Re-named, and re-arranged trip-points installation interfaces, so that
interface name reflects module/parameter subject to thermal control,
instead of designated thermal zone (the latter may change on different
platforms creating a confusion with old names).
Change-Id: Ie3714d14103b85720598cf9da44e0abf51326ac5
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/344606
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
This change adds wrapper functions for setting vmin trips
of CPU, GPU and PLL.
Bug 1364450
Change-Id: I2457798bed4b5f6e5307058320920733e3a9ce8a
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/338975
Added core rail Vmax trip-points to PLL thermal zone on Tegra12
platforms. Made sure pid governor is installed in PLL zone (for
consistency with all other SOC-THERM zones, and to avoid incorrect
cooling device state reporting by default step-wise governor).
Bug 1413311
Change-Id: Ib06fd98ab39dc9a4411b571778600569d801b242
Reviewed-on: http://git-master/r/335923
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Provide userspace with an interface to dynamically adjust
CPU <voltage, temperature> cap. Userspace must respect datasheet-imposed
limits.
Bug 1349095
Change-Id: Ie6d5834d56ad0f1d325bdfbb294c5d9189a8ea2f
Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/327986
Added common interfaces to set GPU scaling trip-points.
Bug 1273253
Change-Id: I25f5870c00b1e3b8fb4fdcd685900512954a9125
Reviewed-on: http://git-master/r/280079
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
(cherry picked from commit 840ed28c2d5f35b3c6c8f8ce9c6a044a4bc57705)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
This reverts commit c68ce785a90086ac931eddaf8f7273525c63d20b.
CPU Voltage capping driver is not used by any user space
Module. So removing driver.
Bug 1340826
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Change-Id: I9011db3f253f53c72fdab3107d2ce22d783125dc
Reviewed-on: http://git-master/r/278250
Voltage capping needs to use soc therm sensors to accurately measure
temperatures. This change adds voltage capping related trip points
before registering to the soc_therm driver.
bug 1042409
Change-Id: I9bebaa39f88f0142c3b8ba7e07a70d86fdbc675e
Signed-off-by: Amit Kamath <akamath@nvidia.com>
Reviewed-on: http://git-master/r/208014
(cherry picked from commit dbd872140e5be5d4a358dd77de790f17c78b1594)
Reviewed-on: http://git-master/r/214972
Functions moved are vdd_cpu, core edp. Raised shutdown limit for nct.
Added two higher temps for cpu_edp to support higher soc_therm temps.
Doing this only for Dalmore, Pluto, Ceres, Pismo.
No real changes to Roth.
Bug 1200075
Change-Id: I2b4ac4ba7cd933bd47c30ab2ad9eabb3a3da5fbe
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/195331
(cherry picked from commit 2af79db3c5763d3a0b6e78663ccf1ad6c04be134)
Reviewed-on: http://git-master/r/197096
Bug 1200075
Change-Id: I96b01b1caa468c0d376e79b416aeb329e1cb0390
Reviewed-on: http://git-master/r/190820
(cherry picked from commit bedff5775d6dab5870a777a1b5a1abfc9e23b033)
Reviewed-on: http://git-master/r/193896
Moved repetitive platform initalization of edp features to common
areas in preparation for handling these cdevs from soc_therm.
Bug 1200075
Change-Id: I8f7fe45d8f0797c72272e5ee1db3707493ec90a5
Reviewed-on: http://git-master/r/190765
(cherry picked from commit f36a20dd1bce7314a97f48213f2180b0a7440a97)
Reviewed-on: http://git-master/r/192538
Added core EDP thermal layer as active cooling device, and updated
core EDP limits when temperature threshold are tripped.
Bug 1165638
Change-Id: I37cd8ab0a94909d198f21ba02e9308ca4d23bcb6
Reviewed-on: http://git-master/r/168929
Reviewed-by: Simone Willett <swillett@nvidia.com>
Added MAX1749 vibrator platform device in cardhu board file
Bug 1154522
Change-Id: I6464c0cf9739bae91d9c4d8b86b86be5a57a5b57
Signed-off-by: Sumit Sharma <sumsharma@nvidia.com>
Reviewed-on: http://git-master/r/144518
Rebase-Id: R0ab3f3e775d50ff33de06210660eb370c70568d8
There is lots of duplicate code for initializing
the debug port for all platform.
Move this to board-common file so that duplicate code
can be avoided.
Change-Id: I3e8a10cd3db4db21d6752a0b689136bfe9828197
Reviewed-on: http://git-master/r/143721
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Rebase-Id: R0ee5cb4caae5d563a0a9df9a1d69b1846b974ebd
