This change contains the following changes due to e450 modem FW change:
1) Change modem BB_RST_OUT polarity and move the wake_lock_timeout where
BB_RST_OUT is low.
2) Disable the AP pullup on BB_RST_OUT.
3) To increase the wake lock timeout to ensure the modem enumeration is
complete before system suspend.
Bug 867501
Change-Id: I8e6638fa8dd8c7af0893ad31693959794e8a4afe
Reviewed-on: http://git-master/r/49743
Reviewed-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
Reviewed-by: Frederic Bossy <fbossy@nvidia.com>
Tested-by: Frederic Bossy <fbossy@nvidia.com>
RIL and FIL require GPIOs access from user space.
This is possible with this change using sysfs.
Bug 866051
Change-Id: Ie6ee4e305ae709a4eae467e27b269b9327031a17
Reviewed-on: http://git-master/r/49206
Tested-by: Alexandre Berdery <aberdery@nvidia.com>
Reviewed-by: Szming Lin <stlin@nvidia.com>
The ULPI spec mandates that there's a pullup on ULPI_STP when the link
is not driving it.
Bug 862561
Change-Id: I9bfa720f19fb776fea8d2fe19bef9755bcaf51a3
Reviewed-on: http://git-master/r/46411
Tested-by: Szming Lin <stlin@nvidia.com>
Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Adding pre_phy_off and post_phy_off callback functions in null_phy_power_off
function. So that the modem handshaking GPIO is set to reflect the real phy
status.
Bug 856096
Bug 854339
Change-Id: Ia39a84d3958b9dd078f93ab5be20387fb1ed9103
Reviewed-on: http://git-master/r/44840
Support modem reboot and re-enumeration.
Support modem remote wakeup.
Bug 814261
Bug 814271
Bug 846135
Change-Id: I103722d0248bcb1565d5f5799a2e4317c2579a95
Reviewed-on: http://git-master/r/31441
Init baseband modems according to the modem_id passed from the bootloader.
Bug 842870
Change-Id: Ib8cd37877eb50ac67a337ef20dd6c6f631169578
Reviewed-on: http://git-master/r/39273
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add PH450 modem init and reset functions for Tegra Enterprise.
Bug 800301
Change-Id: I7068fa87118c2388badb664da3d1a83a3eb49dae
Reviewed-on: http://git-master/r/30920
